Results 1 to 11 of 11
    I'm Done
    Reputation: Durga's Avatar
    Feb 2005
    What Stem Angles did Salsa Make for their Chromo Stems?
    The one I have appears to be 25 degrees, but I'm not 100%
    Just wondering if they only made a few degree variations as it would make identifying mine a little easier.
    Attached Thumbnails Attached Thumbnails What Stem Angles did Salsa Make for their Chromo Stems?-img_4433.jpg
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Durga View Post
    Looks like 25*, but that is not an old stem.
    mtbtires.com
    Reputation: laffeaux's Avatar
    Agree with Shiggy. That's an SUL model (Stiff Upper Lip) which was introduced and sold in the 2000s. It was made after Ross sold Salsa to QBP.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    gobsmacked Moderator
    Quote Originally Posted by shiggy View Post
    right on.
    You can measure it, Durga.
    Dec 1998
    Back-in-the-day of quill stems Salsa made dozens of sizes plus custom. Used the more useful reach/rise dimensions rather than reach/angle. I had two custom stems made for dropbars (1st for Cinelli bars, 2nd for Specialized dirt drops), reach 100mm / rise 150mm. Later became a stock size.
    mtbtires.com
    I'm Done
    Feb 2005
    Thanks (as always). I'm trying to determine if it is 25.4 or 25.8. The attached pic is with a 25.4 bar, the top bolt snugged down (SUL engaged), and the bottom bolt snugged, but not torqued to riding spec.
    Attached Thumbnails Attached Thumbnails What Stem Angles did Salsa Make for their Chromo Stems?-img_5676.jpg
    Dec 1998
    There is no 25.8 clamp.
    mtbtires.com
    I'm Done
    Feb 2005
    Oh, my mistake. I had seen one for sale described as having a 25.8 clamp. I must have the 25.4 then I assume?
    There is a 26.0mm clamp for use on road bike bars (25.8 and 26.0 models).
    If the clamp is holding a mountain bar tightly it's a 25.4 mm. Try and install a road bar and it should not fit.
    If however the mountain bar is not secure, it's a 26.0 mm stem.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    The bar clamp size is also stamped inside the faceplate on all the Salsa Cromoto stems I have.
    I'm Done
    Feb 2005
    Quote Originally Posted by 1 cog frog View Post
    I was hoping to find it on the faceplate (I checked before asking here), but surprisingly it is not stamped.
  1. When did the manufacture of Salsa quill stems move overseas?
    By classen in forum Vintage, Retro, Classic
    Last Post: 10-18-2012, 01:00 AM
  2. Recalled Salsa stems?
    By wesMAmyke in forum Salsa
    Last Post: 12-28-2011, 06:20 PM
  3. trying to decide on a chromo hardtail
    By kt42 in forum Bike and Frame discussion
    Last Post: 12-12-2011, 09:45 AM
  4. how are mtb stem angles measured?
    By happyriding in forum All Mountain
    Last Post: 09-26-2011, 08:09 AM
  5. salsa handlebar stems
    By MitchD in forum Bike and Frame discussion
    Last Post: 01-04-2011, 12:29 PM
