A few steps in the manual production process of this brake. There is a pattern involved, but it is still a very tedious process so I only make a brake if I really need it.
As I later learned, this design was done in the 1930's and was known as the Schultz brake. I call this one the linear-cross-bar-brake or LCBB.
Classen, at one time those stops were a Suntour framebuilding catalog item, but sadly nowhere to be found these days. Trek used them a lot on the bonded frames. When installing it helps to use Loctite or a Nylon washer underneath (ala Mantis) to set the orientation. Nice threading to a shoulder.
Syncros Steerhorns have an aluminum clamping wedge that snugs against the bar with a steel set screw. Eventually these wedges crack so I fabbed a few of them today.
The ones in back are experiments, ones in the middle are the real new deals, and the bottom is the original part. The other picture shows how they fit into the inside of the bar end. The new ones fit exactly as the original parts did. Not the most sophisticated part but something I needed.
Looks like the top of a flip flop stem? If so, I never would have gone to the trouble. There are people that have them in NOS for $9.95-$11.95 maybe not the right length though?
GT Flip Flop stem from 1991. They are commonly available on eBay for as little as $9.95-$15.95 but are always black. One seller has both 1" and 1-1/8" listed in his store quite often. Stop turning and start buying
Those are a dime a dozen too. Some of you guys need to learn to use google.
ferrule end-cap cadplate 6mm 10 pack ... $4.99 More common in motorcycle shops these days then bike shops.
There's also a ton of old Tioga 2.0mm innerwire brake cable sets out there that come with them.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
