Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
Results 151 to 175 of 225
  1. #151
    Saw these on the Flicker Back Road Bike Group. Cool pics all around but these levers are elegant. I didn't make them or know anything more about them. I just like them.
    Flickr: Back_road_bike
    Attached Thumbnails Attached Thumbnails A Vintage Parts Fab-screen-shot-2011-12-24-1.24.06-pm.jpg
  2. #152
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    The modern bolt pattern wasn't the only difference. The position of the rotor also had to be pushed more outboard to work with modern discs. The tricky part was figuring out how much, and then how to get the bolts to sit below the surface so the rotor would mount flush. It took machining off the bolt head a little to work. Not sure how well it will work, as it has yet to be tested.
  3. #153
    He be a moose too.
    Reputation: pinguwin's Avatar
    I had a Klein bearing press but not the attachments. Attachmentless no longer.
    Parts on the left I made. On the right are a friends parts I copied.
  4. #154
    Stokeless Asshat
    Reputation: jeff's Avatar
    Hot!!!!!
    Quote Originally Posted by Austin Dave View Post
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
  5. #155
    WOW, im amazed mates, your work is beautiful. I have also made some small parts for my bikes, this is a brake support for my STS.
  6. #156
    Reputation: DoubleCentury's Avatar
    More Parts for the Holidays
    Who needs a CNC machine if you have 3 hours to kill?
  7. #157
    VRC Hound
    Reputation: bushpig's Avatar
    Nice. Almost there!
  8. #158
    It is a beauty mate, and three hours is not too much for this part.
  9. #159
    Reputation: classen's Avatar
    I'm getting interested in trying my hand at some homemade rollercams, but do not have access to a reference set. I'm at work mucking around with the CAD system so can't measure the ones on my bike right now. Can someone please tell me the center to center distance of the mounting holes.
    80-90mm seems about the range.
    I have a frame with U-brake mounts on the rear seat stays and they are 87mm apart.
  11. #161
    Lever Me
  12. #162
    Stokeless Asshat
    Up late working on that? Damn! Wow.
    I said DAMN!!!!
    Want:
  13. #163
    Very nice set of lever links! Are those brass bushings press fit or loose fit?
  14. #164
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    Very impressive - the brass accents are a nice touch.
  15. #165
    Formerly Carlos9
    Reputation: Pool Boy's Avatar
    Aug 2010
    WOW! i'm by no means an expert but i'm amazed at the stuff in this thread. i'd love to be able to produce something like these from scratch but my brain just doesn't think in 3d...
    thanks all for sharing your work.
  16. #166
    Although not nearly as impressive as the other stuff in this thread I found a need to make some replacement crown race seats for a Bontrager Comp fork that the previous owner had pummeled. I had then anodized before installing them.
  17. #167
    Very nice crown race seats! I need to make a bunch of those myself.
    Quote Originally Posted by classen View Post
    Loose fit. The aluminum is 2024-T6 and may have enough hardness to act as its own bearing surface. Or it needs to be hard-anodized, we shall see.
  18. #168
    Reputation: Funrover's Avatar
    Great stuff! WOW!!!
  19. #169
    Devolution is real!
    Reputation: toyota200x's Avatar
    Love this thread. You do some amazing work. Thanks for posting !
  20. #170
    Mtn Biker Machinist
    Dec 2004
    The latest...
    Needed a canti cable hanger for a '96 Marzocchi fork (when they still had a removeable hanger you could bolt to the arch). Unfortunately, I only had a couple grainy pics and a pair of calipers. Took a bit of measuring, but the end result works. I may re-make it and move the stop up further, as the traddles cable is pretty close to the tire.
    1st pic is from the fork owners manual.
    frog
  21. #171
    Here are a few cable stops I made for a friend's FUNK.
    What a weird design to have the cable stops as separate screw in items
  22. #172
    Nice work guys!
    Classen, at one time those stops were a Suntour framebuilding catalog item, but sadly nowhere to be found these days. Trek used them a lot on the bonded frames. When installing it helps to use Loctite or a Nylon washer underneath (ala Mantis) to set the orientation. Nice threading to a shoulder.
    Mine for WTB multimounts,
    A Vintage Parts Fab
  23. #173
    DC, Do you have a picture of the jig you used to bend the steel for this spring?
    I have been totally inspired by Charlie Cunningham's modern take on the roller/toggle cam brakes so I pretty much plagiarized his design as best I could.
    These are from one of Mike's bikes at Black Mountain Cycles.
    Here is my version:
    I think I got a bit carried away with the 2000 grit sand paper, but it's kinda therapeutic.
    I'm still working on the springs and the brake booster (lots and lots of hand filing and sanding)
  24. #174
    Try bending them manually in a lathe after putting the 90 degree bend in them.
  25. #175
    Stokeless Asshat
    There's on thing I've never heard mentioned in these CC Roller/Toggle threads. How much do they weigh? With all the iterations/tweaking done over the years I can imagine the numbers are all over the map.
    Want:
