Results 1 to 13 of 13
    -bustin punks
    Reputation: fatchanceti's Avatar
    Jan 2005
    Trying to salvage an XTR M900 rear hub
    Non drive side cup and cones are great. Drive side cup (on the freehub body) and cone both need replacing. Grrr.
    I've seen a few mentions that LX and XT stuff MIGHT work (but what gen LX/XT?) - wheels mfg doesn't list cone replacements for the M900 (interesting that the M732 and M737 XT hubs use the same drive side cone part #)
    Peter White sells M900 axle kits and freehub bodies but that's the VERY expensive way to get this thing functional again.
    Thanks guys.
    Sergeant Spandex
    Reputation: lewisfoto's Avatar
    Nov 2013
    hmmm, wish I knew for certain but is there any way you could just try the M700 stuff and see if it works? At least with the cone you could do a side by side comparison with the pitted one.
    Steven
    In Sur America we used to take the cone to a shop with a lathe to get the curve shape made again and add a washer of equal thickness to compensate for the material remove, shame nobody does that kind of jobs anymore around here..
    -bustin punks
    Jan 2005
    Yeah, pulling apart my M732 rear hub may be the next step (if nobody has been down this route before) although I don't really want to cannibilize one working wheel to fix another.
    So finding a donor hub would be choice #1.
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    Quote Originally Posted by patineto View Post
    The cup in the freehub body is shot too, so it needs to be replaced as well. I have a set of deore DX hubs I'm going to eyeball for the salvage parts..
    Plum
    This post is in 3B, three beers and it looks good eh!
    Sergeant Spandex
    Nov 2013
    Quote Originally Posted by fatchanceti View Post
    No I would not tear apart a perfectly good wheel. Maybe try to acquire a slightly beat up one off of the bay?
    Down South Yooper
    Sep 2004
    I finally tried the extra parts I had around, namely an exage level hub, FH-HG50. Freehub body appears to be interchangeable and more or less a direct replacement, at least fit wise. Not sure how much the quality varies from model to model, but it fits.
    Plum
    Sergeant Spandex
    Nov 2013
    Nice!
    Has anyone ever had any luck removing a bad race and pressing in a new one in one of these hubs? I am assuming it is doable just curious if anyone ever has and what the outcome was like. I have presses and what not and could make just about whatever tooling I needed to be able to get the old race out and the new one in, just curious if anyone had any luck doing this. And yes I realize that in many instances just sourcing another is far easier...... but what fun would that be?
    Jun 2010
    I've been getting new 105 freehubs (FH-1056-C) off E-bay dirt cheap. $10-15 shipped. Using them to modernize early '90's hubs. Works perfect, once you get some of the grease out. They are almost packed full & the pawls don't work well when it gets below 50. I didn't have to do anything else. Oh BTW Fatchance, weren't you looking for a Slingshot CX frame. If so PM me.
    You can replace the pressed in Race in a shimano rear hub. I did it this fall. I just used a punch to knock the races out. I put tape on the outside of the punch so it wouldn't mar the freehub threads. A bearing puller might work better. I tried to pound the Race in and that didn't work. The race got crooked and I had to knock it back out. I made a race press from the axle of my donor hub. If you pull the race in by the hole in the middle, you can crack the race. So go slow and don't overload/overtighten it.
    Nice, I figured it would be easy enough to do, just had never tried.........
    Quote Originally Posted by datmony View Post
    I suggest you get a couple junk hubs to practice on before you try to replace a cup in a good hub. Aso Google "campagnolo hub race" and variations. Some of the Campy hubs had replaceable races hubs so there are discussions and DIY instructions on the Web.
  1. Trying to salvage a cassette...what do yo think?
    By red bank rider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2013, 09:05 AM
  2. Any suggestions to salvage this setup?
    By Dan Zulu in forum Cyclocross
    Last Post: 09-08-2012, 09:28 PM
  3. Its been awhile..trying to salvage my L&M Cabeza Logic
    By namaSSte in forum Lights and Night Riding
    Last Post: 10-26-2011, 12:37 PM
  4. Sell my 26" I9s or salvage hubs to go 29
    By seventi14 in forum Wheels and Tires
    Last Post: 07-15-2011, 08:28 AM
  5. Should I salvage, or start over....
    By RideSmiles in forum Bike and Frame discussion
    Last Post: 07-07-2011, 03:29 PM
Members who have read this thread: 4
