Results 1 to 9 of 9
    Jan 2018
    specialized hardrock parts and upgrade help!
    hello all i just purchased a specialized hard rock. has broken trigger shifters and deraulier. was hoping to know if someone knows what is compatible with this mtb. thank you
    Attached Thumbnails Attached Thumbnails specialized hardrock parts and upgrade help!-img_20180110_224019.jpg
    Jan 2018
    also if you know of any sweet upgrades would be awesome
    Sneaker man
    Reputation: mik_git's Avatar
    7 or 8 speed? Guessing Shimano... depends do you want original stuff, or new compatable stuff? eg: if 7 speed then this could work: Shimano Altus M310 7 Speed Trigger Shifter | Chain Reaction Cycles
    Upgrade...well M900 XTR everything I guess...
    All the gear and no idea.
    Jan 2018
    7 speed. Either or would do. Everything looks good but the trigger shifters are broken and the derailleur doesnt look good either. I just want to get it up and running. Thanks. I'll check it out
    I think new 7 speed grip shifters would be compatible with your setup and the are very inexpensive.
    Jan 2018
    You know now that I think about it I think it's a 21speed. Someone told me it was a 7 but I have 3 front gears and 7 in back wheel
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    If you want to stay with a 7 speed drivetrain:
    Get the Shimano M310 7 speed triggers. They're worlds better than 7 speed grip shifters IMO.
    For derailleurs you can get the 7 speed tourney derailleur. I would prefer to get a vintage XT M732 or M735 but the tourney is easy to find and should work well.
    Definitely replace the cables and housing with high quality replacemens as well.
    If you want to upgrade, the biggest issue is the 7 speed drivetrain. Since the rear hub is a freewheel, you have to replace the hub or the rear wheel to really get anywhere. Your cost is going start running off in a hurry and most people wouldn't think it's worth it to put that into this bike. If you have a budget it would probably help for recommendations.
    With the condition you described, I would first figure out whether it's worth it to me to upgrade the drivetrain.
    But
    Shifters and Derailleurs and new Cables
    Brakes and Brake Cables
    Chain
    Then start looking into anything else.
    WTB: Med Bontrager Ti Lite, PM Me...
    Sometimes bike shops have left over/saved up parts that you can get for old bikes pretty cheap. No matter what you get for a bike, if you ride it, it will eventually need some new drive train parts, so is an old Hardrock worth an investment in new parts, maybe maybe not, but it is a cool looking retro paint color and if the frame isn't all beat up you should be able to get it back up and running for not much cash.
    Jan 2018
    Thanks alot. That's alot of useful information. I will definitely look into it. Frame is perfect as well as the paint. Everything looks good except those parts. I changed the cables already
  1. What makes a hardcore hardtail...hardcore?
    By l3rod in forum General Discussion
    Last Post: 12-15-2015, 01:02 PM
  2. Hardcore hardtail build from scratch help
    By milosdaboss in forum All Mountain
    Last Post: 09-02-2014, 12:56 PM
  3. Biking in 89mph winds and 13 foot swells = Hardcore
    By 007 in forum General Discussion
    Last Post: 11-09-2011, 09:02 PM
  4. Hardcore Icycle Group Training Ride
    By driftwood in forum North & South Carolina
    Last Post: 02-12-2011, 08:17 AM
