Results 1 to 13 of 13
    Sep 2012
    Sizing guide for Bridgestone MB-1
    I came across an offer for a Bridgestone MB-1, but I can't find any sizing information on line. The MB-1 is 49 cm. I stand 5'11" with a 33.5" inseam. The bike too small? Too large? Thanks.
    Phobia of petting zoos.
    I found this in about 4 seconds. I typed "bridgestone mb-1 geometry" into Google.
    http://farm4.static.flickr.com/3282/...a02f0cea_o.jpg
    There's 25.4mm to an inch.
    Grumps
    Edit: Sorry, there was 2 parts to your question. as for whether it's too big or too small, not sure. Measure what you have now as a guide, top tube length is more important than seat tube, provided you get enough stand over.
    Sep 2012
    Thanks... I've come across similar charts. What I was looking for were recommendations on what frame size fits you given basic body dimensions. I know Rivendell uses your PBH, so they have a chart with PBH vs bike size. And I know there are general guidelines out there for road bikes and MTBs. I was hoping there was something similar for Bridgestone bikes.
    Can't really help there, fit is a personal thing so what works for me might not work for you, but...
    FWIW, I'm 6" and I like a MTB with a top tube around the 580mm mark. I have some shorter and some longer than that, so saddle position and stem length come into it to fine tube the fit.
    MTBs are a bit different to road bikes. MTB has you moving around on the bike a bit more than road bikes. Roadies spend 3 pages of forum threads debating 6mm difference and knee placement over crank axle and blah blah.
    Competitive Cyclist has a comprehensive fit guide.
    Fit Calculator - Competitive Cyclist
    Mind you, I've used it out of interest for road bike sizing and wasn't totally satisfied with the recommendations based on what I'm riding quite happily now. So, try it but temper the results with other similar fit guides.
    Grumps
    Actually, according to the geo chart, the 49cm MB-1 has a top tube of 575mm, which is about right for me and at 5'11" would likely be fairly close on for you, depending on stem length and seat position.
    If you buy it and it doesn't work out, don't come hunting for me. Besides, I'm taller than you so watch out.
    Grumps
    Sep 2012
    Thanks... that helps give me some idea at least if I'm in the ballpark.
    By the way... you seem quite knowledgeable! Do you know of other bikes that might be similar to the Bridgestone MB, whether it be an old or newer bike? Thanks!
    Reputation: laffeaux's Avatar
    It would be a little small, but probably workable. I'm just over 6'0" and can fit a 52 or 55cm Bridgestone MB. At your height I'd guess a 52cm would be perfect, but you could make a 49cm (one frame size down) fit if you had to.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Reputation: aspreti's Avatar
    Apr 2013
    My MB-1 is 18', I am 5.6. It fits perfect with 5.5' stem (rise 6 degrees). With the stem you can compensate a lot.
    Anyway a MB-1 is a great bike.
    Same boat as Aspreti, I am 5'8" and I love my 46cm MBs. I find the 49cm to be a touch too large for my tastes. The way I would look at it is if you can get it for a good deal, buy it, build it up and try it out. If it doesn't fit well in your opinion then, sell it off to a good home. They are desirable bikes so you would not run the risk of being stuck with it. My 93 is still my favorite ride...... just feels so nimble........
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    All 4 of my MB-1s were 49cm and I am 5'-10". They felt fine at the time, but I had a lot of post showing and a 135-150mm stem on them. If I were going to buy one today I might buy the 52cm. I have not gotten any taller, but I have had all of the kids I want, so the stand over difference is not an issue.
    Feb 2006
    I think a 49 is the right call for 5'11" IMO. They have very quick steering so a long stem is not a bad thing.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Quote Originally Posted by sgltrak View Post
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Sep 2012
    Ah that's funny!
  1. TLD KG5450 - sizing guide? tips?
    By The Factory in forum Apparel and Protection
    Last Post: 04-05-2013, 12:38 PM
  2. Giant 2013 sizing guide
    By esblo in forum Giant
    Last Post: 10-07-2012, 11:19 PM
  3. Superfly Sizing Guide & Owner Impressions?
    By konaben in forum 29er Bikes
    Last Post: 06-12-2012, 06:53 PM
  4. Trek Top Fuel SSL sizing guide
    By Nrth in forum Trek
    Last Post: 03-23-2012, 09:44 AM
  5. 80's Bridgestone MB-2 vs 90's Bridgestone MB-4
    By Johnny Alien in forum Vintage, Retro, Classic
    Last Post: 09-06-2011, 11:03 AM
