Results 1 to 15 of 15
    Reputation: WickedPhatChance's Avatar
    Shimano SL-M700 Deerhead shifter compatibility
    As some of you may know, I dig these old shifters, but have only every used them with older 5/6speed cassettes. Question: does anyone know their compatibility with modern cassettes running 8/9 speeds in back?
    thanks
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by WickedPhatChance View Post
    thanks
    Somebody stole my picture that I stole. I guess that makes me guilty too. Seriously, Someone here said there's enough pull to do at least 7 sp. Personally, all of mine are on 6 sp bikes.
    A garage full of steel frames means happiness.
    Reputation: Fillet-brazed's Avatar
    They should do a 9 speed cassette. My old boss used to use them with a 7 speed freewheel and he'd run lots of slack in the cable because he didn't like the small cog to point the shifter at 6 o'clock. So, in other words, there's room for plenty more pull. Semi-related, I had a front M700 shifter running 4 front chainrings (quadtamer).
    The M700s have a nice, overbuilt look, but I think the Suntours from that day work (and look) better. Suntour had a better and smoother ratchet mechanism I think.
    defender of bad taste
    Nov 2007
    I cant speak with authority on M700 shifters, but I have used an M730 6 speed shifter in friction mode with a 9 speed cassette, there is some cable-pull difference between Deerhead and apres Deerhead XT derailleurs though so I can't say for sure you're okay. I agree they're aesthetically very pleasing shifters (M700), though the unfortunate prevalence of the SunRace knock offs on the cheapest of the cheap dept. store bikes has lessened my liking of them.
    5 is the old new black; 6 is the new new black...
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Quote Originally Posted by Fillet-brazed View Post
    Wuss.
    -eric-
    http://www.rumpfy.com
    Quote Originally Posted by Rumpfy View Post
    Wuss.
    It was for pulling a trail a bike up steep trails. My 2 yr old son would never pull his own weight up those climbs!
    Stokeless Asshat
    Reputation: jeff's Avatar
    I took a Suntour shifter of the same era as a spare on The White Rim last year. I figured it could pull duty on any bike, front or rear. Low and behold my XO rear shifter took a powder on me 15 miles in. 30 minutes later I was back in action. It shifted a 9 speed with cable to spare.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    ong
    ong is offline
    Huh, was that replacing one of the 1:1 (long pull) shifters, Jeff? That's a lot of cable to wrap up!
    Maybe I should think about "upgrading" my remaining modern shifters... I can't ever seem to get indexing to work worth a damn anyway.
    gobsmacked Moderator
    I love indexed shifters. *click click click* makes me so happy!
    Love them friction shifters
    Reputation: Shogun700's Avatar
    I don't necessarily share the sentiment, but that was wicked freaking funny, almost spit coffee all over the keyboard!
    WANTED: Fisher Paragon, blue/green, Ritchey dropouts.
    Suntour Not Reversible
    "The M700s have a nice, overbuilt look, but I think the Suntours from that day work (and look) better. Suntour had a better and smoother ratchet mechanism I think."
    The Suntours unfortunately aren't reversible to the best of my knowledge. The beauty of the M700's is that they can be mounted under bar. We were riding with under bar shifting this way for years before it was put on the market and I still commute that way everyday. And yes to 8 speed at least.
    Quote Originally Posted by dexterrexter View Post
    Suntours will work under the bar.
    Do you have to run the front shifter on the right and the rear on the left with the suntours or are they truly reversible? I agree they are more elegant and would be happy to try a pair on my new Burley 'runabout' just bought this week and am just getting ready to convert to friction. I'm sitting on a pair of the Shimano's but they are a spare pair for a different bike I'd rather keep sitting on.
    oh, I see what you're saying. Yeah, the M700 has the reversible cable routing internally. The Suntour does not have this, but they are symmetrical and the rear can go on the left and vise versa. This goes for the M700 as well - no need to change the routing, just run them reversed.
  1. Bar end shifter compatibility question (Shimano)
    By Mr Pink57 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-07-2010, 09:21 AM
  2. Shimano rear der & shifter compatibility?
    By elder_mtber in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-11-2010, 05:01 AM
  3. Source for Shimano M700 "deerhead" rear derailleur?
    By el-cid in forum Vintage, Retro, Classic
    Last Post: 11-30-2006, 10:57 PM
  4. SRAM/Shimano Shifter Compatibility Question
    By paul99501 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-10-2006, 03:09 PM
  5. Shifter compatibility of Shimano XT rear derailleur
    By bobalouie76 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-12-2004, 10:59 AM
Members who have read this thread: 4
