Results 1 to 5 of 5
    Reputation: commuter73's Avatar
    Schwinn Paramount PDG...Who knows about it?
    A friend of a friend has an early 90's Paramount PDG 30 for sale. From the paintjob (black and red) I think it's a 91. Also for sale is an early 90's Schwinn Impact Pro. Both are in pretty good condition and seem to fit pretty well.
    Does anyone have any experience with either of these rides? Any guess as to value (if any)? Thanks in advance for the help.
    A new old set of Mavic 231 rims would REALLY make my day.
    Reputation: grawbass's Avatar
    Quote Originally Posted by commuter73
    I know a little about them. The PDG 30 was the lowest end model of the Paramount series and had a standard welded cro-mo frame. The upper end Paramounts had Tange Prestige frames, some welded and some lugged.
    I happen to have an Impact Pro. Its basically an exact copy of a PDG 30. Its double butted 4130 MOS (mountain over sized) tubing. It has the G-Force stays also. The paint is definately different and the components might be. Mine has either Mountain LX or Exage 400, I can't remember. Cantis front and rear. 1 1/8" threaded headset. 7 speed cassette.
    In good condition, I'd say max $50 each if you like Schwinns and they fit. Personally I'd rather have the Impact Pro just because they're more rare than a PDG 30.
    Wanted: broken Titec 2 bolt seatpost, any size
    I have a PDG70 which is two steps above the PDG30 but its not the sought after one ie PDG90..
    Mines amazingly light, i think its 26 pounds with all stock components, could probably be less with a better seatpost/bar ends.
    Its all deore xt except for the lx rear derailler, which is getting old atm, but im too poor to replace it so.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    To be honest, neither is worth much. Not desirable as a collector bike...and even if they were...they're pretty low in the line up.
    Depending on condition, $30-50 each IMO. If that.
    -eric-
    http://www.rumpfy.com
    bcd
    bcd is offline
    Reputation: bcd's Avatar
    i raced for schwinn as a JR. i had a 30 and a 90. i road the 90
    till i broke the down tube. little fexy but way light! i liked then better
    than all the Cdales i had b/f it.
