Results 1 to 13 of 13
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Retro Ryder klunker headset install
    If you're not familiar with the Retro Ryder headset, it allows you to run a fork with a 1 1/8" steer tube on a bike originally equipped with a 1" steerer fork. I posted in the cruisers thread that I had gotten one for a klunker project and someone asked me to document the install, so here it is.
    First, here's a link to the Genuine Bicycle Products website, where the RR headset is available. Genuine Bicycle Produsts: Parts and Accesories.
    As for the install, it was pretty much like any other headset I've done. The fork I used is not the one that will go on the bike, but it's all I have right now. I should add that the crown race on the fork is not the one that came with the kit. There was already a star nut in it so I didnt include that in the post.
    Here's everything that came in the box
    Cups & Bearings
    Crown Race, Compression Ring, Top Cap, Upper Bearing Cover
    Star Nut, Lower Seal, Upper Seal, Top Cap Bolt
    First, grease the bearing cups and install in the frame using a proper headset installation tool
    Install the crown race, dust seal and greased bearing on the fork
    Install the greased upper bearing in its cup and slide the steer tube through
    Slide the upper bearing cap and seal over the steer tube
    Then the compression ring
    Headset spacers and stem and top cap are next. When you tighten the top cap it will compress the upper seal under the compression ring so make sure you have enough spacers to allow for proper preload. Tighten the cap screw until all the play is gone and everything turns freely, then square up the stem and tighten its bolts.
    Enjoy your new klunker. Head angle with a 80mm fork sagged 20% is 69 degrees. Money
    No moss...
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    Thanks for the tutorial. Looks good. Where do I get the cup installation tool and how come it is not Park Tool Blue?
    Reputation: arcdesigns's Avatar
    Great job
    Master of the Face Plant
    Another option is to find yourself a used 1 1/8 inch sealed bearing headset like a King or Cane creek and send it to Products. For 17 bucks he will turn it down to the proper diameter. Maybe a better option than paying $45 bucks for a $10 dollar headset that some guy put on a lathe.
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
    The White Jeff W
    Good idea. We had an old metal lathe at work. One day I came in and it and a bunch of other stuff was gone. New owner cleaned house. Chucked it in a dumpster over the weekend, along with a drill press that also would've looked great in my garage.
    No moss...
    Sep 2013
    Thanks for the writeup! I have been looking for options to upgrade my Klein Pinnacle and this looks like it might be the ticket.
    1997 GT LTS-1
    1992 Klein Pinnacle
    1983 Specialized Stumpjumper
    2003 Bianchi Vigorelli
    gobsmacked Moderator
    Quote Originally Posted by AlexLep76 View Post
    Does your pinnacle have a rigid fork because if it does, then it's debatable whether it's an upgrade.
    Love those park tools.
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    I want to do this upgrade, but I can't find that tool in the park catalogue.
    Sep 2013
    "Upgrade" was probably the wrong word to use. Resurrection is probably more accurate. The frame was given to me by my co-worker that has a special talent for finding bikes at the landfill. He spotted it in the scrap pile and in an instant even with a coat of black spray paint and a coat of olive drab house paint on it. If it had the original fork and Mission Control Stem/bars I would be good to go.
    1997 GT LTS-1
    1992 Klein Pinnacle
    Ah yes, bummer about that.
    Reputation: Funrover's Avatar
    Awesome!!!
    Reputation: proline69's Avatar
    Nice .
    Reputation: PiasRoller's Avatar
    Sep 2012
    Sacrilege!...I don't mind a slack head angle, heck a DHR runs a 63*...But a modern sus fork on a PREWAR? I get heckled for running a freewheel round these parts.
    Ride that here and you would have declining produce thrown at you.
    Seriously, that is a cool headset! How about a replacement 1" fork though?
    Attached Thumbnails Attached Thumbnails Retro Ryder klunker headset install-img_20140330_165139-1-.jpg
  1. Headset reducer install ??
    By driver bob in forum Cannondale
    Last Post: 02-05-2015, 04:35 PM
  2. Jet 9 RDO V2 Integrated Headset Install
    By vtsteevo in forum Niner Bikes
    Last Post: 07-06-2013, 02:29 PM
  3. Jet 9 RDO V1.0 Headset install
    By tneker in forum Niner Bikes
    Last Post: 01-02-2013, 04:58 AM
  4. Headset Cup Install Question
    By drm31078 in forum Tooltime
    Last Post: 03-02-2012, 05:31 PM
  5. 2011 Sultan Headset DIY Install
    By nowshon in forum Turner
    Last Post: 03-31-2011, 04:27 PM
Members who have read this thread: 4
