Awesome break-down. Thanks for that! I no longer own a Klein, but I love this kind of step by step.
I enjoyed this thread too. Thanks
John Galt
Great stuff! Now, if only I had similar tools for my Ritchey with press-fit BB...
Ditto...
Seek: Old Mtn. Goat Bar Stem Combo.
Gary K went to MIT right?
Thanks for the post!
or use a hammer
"nothing stan likes more than.... wallowing in his obnoxious self-righteousness" 6-2-12 Bushpig
Mtn Biker Machinist
Holy CRAP!
No wonder they don't make press in bb's anymore! I love all things mechanical, and I love working on bikes, but that is ridiculous! How many times can you do that before the bb shell is too loose to hold the bearings in? Hopefully the bearings last a long time!
Your level of detail and documentation is outstanding. That took a lot of patience just to take all those pics. You should make a PDF and post it, I am sure all the Klein owners would love to have it!
frog
Thnx. Now when can I come over and borrow your tools?
John Galt
 Originally Posted by da'HOOV
or use a hammer
That might just happen today. Decals are in my possession and the frame is overdue to go in for new finish. Is it bad to powdercoat a 1983-84 Ritchey? I'm back and forth between local powdercoat and Cyclart.
no handle
looking for 20-21" P team
There's only one problem. The bearings aren't supposed to be counter-sunk in the bb shell. They're supposed to be flush.
Not a problem. The Klein tech manual specs a 3mm offside placement into the BB shell depending on what crankset you're using.
- Jeff
____________________________
'97 Adroit, '96 Adroit, two '93 Attitudes & '90 Attitude
Wow, the only thing Klein could have done to make that more difficult would be to place a couple small scorpions inside there to surprise you.
that's probably not too funny in the southwest
Nice work there. Your Avatar makes me want to throw up though.
2nded
Hammer takes about a mintue to do that job.
Retro Grouch
Wow, no chainsuck protector on that bike! Did someone actually drill a hole next to the ST where it meets the chainstay (non-drive side)?
No good in rock gardens..
Cool. I did my old Pinnacle a while back with a combination of "improvised" items I had lying around.
My Cannondale Lefty keeps failing....
Derailleur Cable Routing
That hole is for the f derailleur cable.
Apparently the anit-chainsuck plate is necessary.
Question-
I have a Rascal and I am restoring it. I recently tightened the cranks arms that are not the originals and now the bottom bracket is kind of tight. Any idea of how to loosen the BB or get a new one?
I've never owned a Klein but that was an excellent tutorial and I enjoyed going through it!
Wanted: Always something else ...
(like a younger brother for my Sig)
I think this is a good method for installation given that you have the adjust the chainline which is hard to do with a hammer, especially when the bearings aren't restrained. But for removal this is just, well... lengthy
What else will your restoration entail?
- You may not post replies
- You may not edit your posts
Forum Rules
