Results 1 to 12 of 12
    over researcher
    Reputation: royta's Avatar
    really light Ritchey Logic Prestige Super Tubing for single speed
    I have a '96 Mongoose IBOC Pro-SX frame that is built with Ritchey Logic Prestige Super Tubing that weighs, if I recall correctly, about 3.75 pounds. I built it up in '97 with a '97 Judy SL fork, XTR components, Syncros Pro titanium seat post, Race Face Turbine LP cranks, Mavic 217 rims, and White Industries hubs and it was a 23 pound bike back then. It has since been torn down and I ride a '06 Turner Flux now.
    I'd really like to build the frame up again, but as a single speed. How much more abuse does a frame receive when built up as a single speed? I know I would lose some pedal efficiency because of the fact that this frame flexes. Will the side to side rocking destroy it, or is that what these old steel frames are designed to do?
    Thanks.
    Sent from my DROID X2 using Tapatalk
    Attached Thumbnails Attached Thumbnails really light Ritchey Logic Prestige Super Tubing for single speed-uploadfromtaptalk1332622865657.jpg
    Stokeless Asshat
    Reputation: jeff's Avatar
    I have 0 experience with that tube set but I'd say do it. Sure you'll have some flex, especially if you're big and or a masher but not so much that you'll be throwing chains. Set it up with great chain line and I see no problems. A ridged fork is a must though, and wide risers, and fatties. JMHO of course. It should make for a great SS. Quality, vintage steel bikes are a blast to build and well suited for this purpose. Although built more stout, my 90 Ala Carte was SS'd for over 6 years with nary a whimper. That bike stole many a heart over the years and turned quite a few onto single speed riding. As far as breakage goes? Who knows. Steel's easy to fix if you do. Consider it a battle scar.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Reputation: laffeaux's Avatar
    Yep, it should be fine. SS doesn't put any more stress on the frame than a strong rider that likes to mash the pedals. The handlebars likely take more abuse though.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    over researcher
    I plan on changing out the stem and handlebars. The 135mm stem length was fine 15+ years ago on these XC geometry bikes, but they didn't do to well on technical downhill sections. Those Answer Hyperlites will be traded out for a riser bar of some sort.
    I'm about 5 pounds too heavy right now, at about 160, but I should be able to start shedding that starting in the next couple weeks.
    I have one of those frames that needs stripped and repainted then I may set it up as an SS. It was a great climber as I remember. Post some pictures and a ride report when you have yours together.
    over researcher
    I'm not sure what to do with the forks though. It's an old frame design, probably built for no more than an 80mm fork. I believe my Judy SL was 63mm. How are the rigid Dimension forks?
    Stokeless Asshat
    Quote Originally Posted by royta View Post
    160? Pfftt......FlyWeight.
    Want:
    I cannot read this post without "March of the S.O.D." filling my brain...
    over researcher
    Quote Originally Posted by Luther View Post
    That's a good thing.
    REALLY?
    Reputation: jeffgothro's Avatar
    Shortest song in history...
    <object width="420" height="315"><param name="movie" value="http://www.youtube.com/v/e0pNPmgBh8w?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/e0pNPmgBh8w?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    DJ, "Because I'm sure the world need's more dudes stalking the woods stoned out of their mind carrying a deadly weapon."
    artistic...
    Reputation: colker1's Avatar
    Friend of mine had one.. they are light and geometry is excellent. HIs broke at seatstays/seat tube. They were known for cracking there. Always lusted for one of those. Had a Mountain Bike mag w/ a test of one buuilt w/xt and judy sl.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    over researcher
    I think I have that magazine still.
