Results 1 to 16 of 16
    Reputation: arcdesigns's Avatar
    Re-painting a frame where the decals are under the clear coat?
    Hi All,
    Looking for advice on the best way to restore a frame that has the decals and makers badge under the clear coat?
    I was thinking of spraying a one stage with the decals masked off and then a clear over everything.
    Thanks in advance.
    Team Brooklyn
    Reputation: CCMDoc's Avatar
    I suspect you will put a lot of effort into doing that and ultimately be disappointed with the result because the transition from old to new paint will not be as seamless as you would like.
    You might consider having the decals reproduced and once you have what you need strip it to the metal and go from there.
    No less work but I believe you will be happier with the result.
    Wanted: more of the same ... but different
    Reputation: laffeaux's Avatar
    Quote Originally Posted by CCMDoc View Post
    Agreed.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Humanoid Lobster
    Reputation: Jak0zilla's Avatar
    May 2010
    It's hard to tell for sure from the photo, but that frame looks like all it needs is a buffing. (I know, I know ... I could be wrong.) I've had very good luck with some of the automotive liquid rubbing compounds such as "Scratch Out". In my experience you can get a paint job back to nearly new looking with a little bit of buffing.
    Don't call it a gooseneck.
    The good news is the name decals were designed to look as if a pin striper put them on by hand so to actually have them hand painted would be an upgrade.
    Bad new is the makers badge is to complex to duplicate by hand. Where and how would someone go about getting decals reproduced?
    Quote Originally Posted by Jak0zilla View Post
    This on needs a new pant job for sure
    One more thing: What advantage to stripping it to metal? I would generally feel that the new paint would cut into the existing paint and primer better then to raw aluminum?
    Certified Bike Junkie
    Reputation: muddybuddy's Avatar
    search "schwinn decals" on ebay. I'm guessing you'll be able to find something acceptable. You could even use some older style decals to give it more of a vintage vibe.
    Need: McMahon brake for roller cam mounts, Mountain Goat fork.
    Quote Originally Posted by muddybuddy View Post
    Not really interested in older decals and I have searched eBay and a half dozen classic Schwinn decal sites with no luck. Although cool to us MTBR folks because this Panther is lightweight and has mountain bike geometry the impression I got from my searches is "if it wasn't made in Chicago it isn't a Schwinn."
    Here is the pinstripe style lettering
    Attached Thumbnails Attached Thumbnails Re-painting a frame where the decals are under the clear coat?-schwinn-decal.jpg
    Here is the Makers Badge
    Attached Thumbnails Attached Thumbnails Re-painting a frame where the decals are under the clear coat?-schwinn-makers-badge.jpg
    Pretty cool that they put the frame angles on the bike.
    Reputation: DoubleCentury's Avatar
    For Salsa stems where the graphic isn't under the clear coat, I've had pretty good luck masking off. Maybe you can mask off and accent the transition with some pin striping around the tube.
    Anyone want to buy a used car?
    Re-painting a frame where the decals are under the clear coat?-salsastem1a.jpg
    Re-painting a frame where the decals are under the clear coat?-salsastem2a.jpg
    Quote Originally Posted by DoubleCentury View Post
    Sweet!
    Team Brooklyn
    Quote Originally Posted by arcdesigns View Post
    There are a few places that to exceptional decal reproductions. You take a number of measurements and a bunch of photos and they create them. I'll try to find the name and contact info of the place I've used.
    Team Brooklyn
    You never really know the integrity of the original paint application. It would be a terrible disappointment to go through the trouble and work to see your new paint job bubbling up over a previously poorly prepped section.
    But...
    Only you have to be satisfied with the result and feel its a good ROI.
  1. Clear coat over decals into a fresh Powder Coated frame.
    By Pepelepu in forum General Discussion
    Last Post: 01-23-2016, 12:23 PM
  2. Clear coat only on steel??
    By car bone in forum Frame Building
    Last Post: 01-22-2014, 06:58 PM
  3. Clear coat options on steel frame?
    By MiggySawdust in forum Frame Building
    Last Post: 06-03-2013, 10:42 PM
  4. Paint or clear coat an SC carbon frame?
    By BTTR in forum Santa Cruz
    Last Post: 06-15-2012, 09:24 AM
  5. Spray painting to hide decals on frame
    By roc865 in forum Bike and Frame discussion
    Last Post: 06-21-2011, 09:31 PM
