    Reputation: fernandoj's Avatar
    Race Face Turbine bolt kit for inner chainring
    Hi!
    Let me open this thread to ask if someone knows where can I find a kit for this cranks.
    The bolt set should be something like this: 5 x 16mm bolts + 5 cylindrical washers (I guess these are 8mm each one)
    Any advice, link, or your own kit would be welcome . Thanks in advance.
    defender of bad taste
    Nov 2007
    A decent LBS should be able to put that together for you, or if they don't have the bolts/spacers in stock they can order them. I believe you are correct on the 8mm for the spacers - there was a thread over on RetroBike UK about this very issue a while back.
    5 is the old new black; 6 is the new new black...
    Feb 2005
    I got them quite easily through Race Face directly, about a month ago, should all other avenues fail....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    I'm going to ask for them to a dealer/distributor in Spain.
