Results 1 to 5 of 5
    Dec 2013
    Need help with an older Stumpjumper
    My wife owns what appears to be a '99 Spec. Stumpjumper FSR XC that I bought new for her. It has been unused for several years.
    I would like to make sure what year it is and to locate a service manual/owner's manual so I can service the fork and shock and other items on the bike. I need to know air, oil, etc., specs.
    It is blue, with a red Manitou fork, the Fox Air Vanilla float shock, Avid brakes, etc. I have attached a photo.
    Any ideas where I can find an owner's manual? Is it a '99 ? Thanks.
    Reputation: mainlyfats's Avatar
    Bad weekend to be asking about Specialized IMO (unless you want to be told to cover it with gas and set it on fire).
    War vet forced to change bike shop?s name after threat from Specialized | Calgary Herald
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Looks like a 99 or 2K. But, the manual would have been a generic specialized manual that came with either all their bikes, or, all maybe one for all their FS bikes. It most likely had no specific info about servicing that exact shock or fork. Better to find the manual for the shock and the fork independently.
    If there are no other markings on the fork to indicate the specific model of the fork and shock, check out specs for different years on bikepedia to try to narrow down your guesses, then use the factory manuals for those forks to guide you in oil service, etc.
    2000: 2000 Specialized Stumpjumper FSR XC - BikePedia
    1999: 1999 Specialized Stumpjumper FSR XC - BikePedia
    Fork is probably a Manitou SX, manual here: http://www.spoke-n-word-cycles.com/T...e%20Manual.pdf
    Vanilla shock manual: http://www.birota.ru/manuals/foxflow...hox-manual.pdf
    Seals for those old forks can be hard to come by. Hope that helps.
    Dec 2013
    RE: Spec coming down on the Canadian store owner.
    Very true. A pretty heavy handed play by the big S.
    Dec 2013
    Quote Originally Posted by ddprocter View Post
    Many thanks!!!
  1. Need help with an older Stumpjumper
    By Walter Nash in forum Bike and Frame discussion
    Last Post: 12-29-2013, 04:44 AM
  2. 2007 Stumpjumper Expert or 2008 Stumpjumper Comp??
    By ParadiseRiding in forum All Mountain
    Last Post: 12-01-2013, 03:22 PM
  3. Older guy looking for Older bike parts for a 3x8 drivetrain.
    By Steel-is-real in forum Eastern Canada
    Last Post: 09-17-2012, 07:34 AM
  4. Replies: 7
    Last Post: 04-12-2012, 12:35 AM
  5. Replies: 0
    Last Post: 04-01-2012, 06:47 AM
