Results 1 to 21 of 21
    Nov 2012
    My first thread...1990's Cannondale!
    I was lucky enough to be the one to save this beast from 10 or so years of neglect. I tore her down to the frame and got eveything thing back into shape. Now she is my go to for local single track and fire roads Any guesses as to the model/year?
    Attached Thumbnails Attached Thumbnails My first thread...1990's Cannondale!-011.jpg
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    52/46 big and middle rings and a roadie cassette!?
    Only possible explanations:
    You have massive piston legs and no hills.
    You only have wide open fire road down hills and no climbing anywhere.
    As for the bike, other than a 'Cannondale', not sure what we're lookin' at. Serial number would help.
    I like the stealth and (some) of the build.
    -eric-
    Wanted: White True Temper handlebar, uncut.
    Nov 2012
    Actually quite the opposite! I have alot of climbing where im at (reletively short I guess, very steep though) Its really not that bad considering im 6'1 and weigh 155lbs. Thanks for the compliment! and Ill be sure to check the SN whenever I get a chance
    Nov 2012
    Changes I plan to make:
    Swap the RD for a more fitting XRT or Deore XT
    Swap the seatpost for a Thomson
    Swap headset for Chris King
    Nov 2012
    Long time reader - first time poster etc
    Definitely a 2.8 series mountain frame, possibly a 1995 M900 originally which is a wild guess due to the anodised grey CODA seatpost clamp, can't remember seeing that on any other one at the time (and I owned one way back when). Edit - If that paint is original, will be a M2000.
    Check out the serial number, this guide will help (can't link it as I have less than 10 posts):
    w w w.vintagecannondale.com/info.html
    It's a 'bitsa'! Has bits of everything on it! Great frame to ride, very quick and light.
    Reputation: broomhandle's Avatar
    its later. like a 97ish. CAAD frame.
    you can check the date here:
    Vintage Cannondale - Information and Catalogs for Cannondales
    and ask at the same place for decals if your going that direction.
    Likely a 1995 2.8 series, it has a wishbone seat stay (appeared in 1994) but without the cantilever dropouts. I tend to agree with Danhar, also because of the dropouts and 1/18" pepperoni fork. The 1996 models had the P-bone fork (straight blade). Another clue is the cable stop on the fork, that replaced the crappy force 40 cams (1993-95). 1996 and forward did not use the force 40 cams.
    Only the once black faded to bronze seat collar looks original, so can't use parts to ID model. Look for the original paint color, (1995) M500 came in blue or green, M800 "Beast of the East" had cantilever dropouts, M900 came in red (the one I had) or black fade to purple, M2000 came in black fade to blue and purple. Are those Sun rims on XT hubs?
    A nice bike, but if I may suggest,
    1) Keep the rear 7sp 600 derailleur (I run road d-rail/cassette on all my non-single speed bikes), unless you find the matching M900 XTR
    2) Ditch the 52t ring and just run the 28?/46 combo as a double (turn high limit screw in on XTR front d-rail), better ground clearance
    3) New brake pads, those XTR pads are at least 18 years old, space the cantilevers wider than they are now for better leverage. Sweet brakes!
    4) Change the "almost as long as your top tube" stem for something shorter with more rise, your back will thank you
    5) 27.2mm Thompson post good choice, 1 1/8" King'er always a good choice, and both keep you parts picks in the 90's if you want to stay retro
    My 1995 M900 was maybe mid to late year because it had the Coda 501M CNC crank that was soft as butter but very cool looking. 1996 M900 had the 501M. Check the chainstay bridge on the frame for cracks, that is where mine broke.
    M900 in action
    youtube.com/watch?v=jolQIHeF7zU
    Post-M900 pepperoni fork in action
    youtube.com/watch?v=7Wu6ZDXFI2M
    Broke both frames a very long time ago but still have the fork.
    check the site. SN will say it all. 95's had a canti stop on the rear. my vote its a 96/97 M series. more like a 96.
    You might be correct since the 1995 has the post for the force 40 cam, 1996 does not. The fork would indicate 1995, but appears not to be a pepperoni and the bike has been completely rebuilt and painted (frame and fork).
    1995 catalog here
    66.147.244.179/~vintagm8/year/1995/1995.pdf
    1996 catalog here
    66.147.244.179/~vintagm8/year/1996/1996.pdf
    haha.
    SN will say all.
    thats epic nice bike that proper retro
    Nov 2012
    Quote Originally Posted by letusride View Post
    You might be correct since the 1995 has the post for the force 40 cam, 1996 does not. The fork would indicate 1995, but the bike has been completely rebuilt and painted (frame and fork).
    1995 catalog here
    1996 catalog here
    Are you sure its a repaint? There is no evidance of another color ever being there and the paint appears to be pro/factory quality. In any case, I love it in black
    Nov 2012
    M900 in action
    Thanks for the insight!
    The hubs are Deore LX, not sure on the rims, they only have a tiny little sticker with a few numbers on it (dont remember what they are) Maybe Mavic?
    New brake pads are on the list for sure, probably going for Kool Stop
    There are a few downhills I use the 52 on so im gonna keep that on
    The bike is pretty comfy for me right now.I dont like the feel of the more upright riding position actually. I may go for a set back Thomson though, then I could shorten the stem and get more weight over the rear.
    Nov 2012
    Quote Originally Posted by savie62 View Post
    Nov 2012
    Good pick up, I'd forgotten about the cam. It's been 16 years since mine was stolen so my mind is rusty on the details.
    That looks sweet! Sort of a Back in Black look to it.
    I've always stayed away from 'Dales because many of their parts were Cannondale specific (Headshock, Lefty, CODA parts) but it's hard to deny the simple elegance of fat tubes and a rigid fork in basic black.
    Did you find that serial number yet?
    Nov 2012
    The serial number is vary hard to make out, Ill check back again tonight and post up what i find. In the meantime, I was able to find the "Before" pictures if anyone is interested.
    Attached Thumbnails Attached Thumbnails My first thread...1990's Cannondale!-010.jpg
    Nov 2012
    The SN looks like 5716 and then 0355 below that, but once again they are very very hard to read
    Nov 2012
    Just picked up a bike with sram x9 drive train and shimano deore xt hubs laced to Mavic 221 UB rims. I am swapping those wheels onto the Cannondale and am thinking about doing the same for the x9 group. Any thoughts?
    its your call for the parts. those XTR brakes are 95, and i belive every part on there was never on that frame originally. if your gonan ride it and just use it, go for x9.
    and the frame should have a 2 letter code for the date.
Hot Deals
Contests
Latest Mountain Bike Articles
