Results 1 to 10 of 10
    Mountain Goat Pin Hole Rust Question
    A friend down the street has had this for a while collecting dust.
    He traded it with me for a XS Klein Pulse frame that he is going to build for his daughter.
    It is a 1992 Whiskey Town frame(I think) that is straight but it has some pin holes in the seat tube.(see photo) I tried to get a photo of the inside of the seat tube but could not get one good enough to illustrate that the seat tube does not have what I thought would be a lot of surface rust.
    There is some surface rust but not the kind you would expect to see.
    Anyone ever fixed pinholes? If so, how?
    I was told to mix up some JB weld and force it into the holes and then sand it down. I do have a friend that would fill them with weld.
    I plan on getting it powder coated and having it be a townie so i don't want to spend a lot.
    Any advice would be gladly taken.
    Cheers,
    LJ
    photo 1 by lawrencejobe, on Flickr
    photo 2 by lawrencejobe, on Flickr
    photo 3 by lawrencejobe, on Flickr
    Stokeless Asshat
    Reputation: jeff's Avatar
    JB Weld. Powder. Frame saver. Build. Ride.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Quote Originally Posted by jeff View Post
    Thats what I wanted to hear.
    Reputation: sansarret's Avatar
    Mar 2006
    Proper way would be to fill them with silver with a torch and file it smooth. Not hard to do if you know someone who can braze. Good time to do it now since it's stripped of paint.
    Quote Originally Posted by sansarret View Post
    I have a couple of friends that are frame builders and they said they could do it but also said for what I was wanting to do with the frame that JB would work fine. I may just take it to them and see.
    Mar 2006
    True, JB would probably work just as well and is easier to do, I just braze since I have access to the equipment. Interesting how the bb is tig welded but also has unfinished fillet brazed on top. Nice frame, worth fixing up for sure.
    Reputation: DoubleCentury's Avatar
    Can JB Weld survive the powder baking process?
    Quote Originally Posted by DoubleCentury View Post
    I think it can as I have friends that have used it on ceramics that get to a pretty high temperature. I will have to research though as I had the same question.
    Spectrum Powderworks uses some sort of non-metallic filler.
    Stokeless Asshat
    Not saying that JB is the perfect solution but it does in fact work with powder.
    FAQs » JB Weld
    Want:
  1. Mountain Goat Trench Goat
    By Elevation12,000 in forum Vintage, Retro, Classic
    Last Post: 04-29-2012, 06:10 AM
  2. 1982 Mountain Goat Escape Goat, cool frame details
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 11-19-2011, 12:21 PM
  3. 1989 Mountain Goat Escape Goat CA Yuppie paint
    Last Post: 09-05-2011, 01:42 PM
  4. 1992 Mountain Goat Lombada Goat tandem w/ Campy
    Last Post: 04-18-2011, 10:37 AM
  5. Mountain Goat Whiskeytown question
    By bestmtb in forum Vintage, Retro, Classic
    Last Post: 03-01-2011, 09:50 PM
