Results 1 to 51 of 51
Thread: Modern LD Stems
    gobsmacked Moderator
    Modern LD Stems
    I know that some of you guys are getting desperate for LD stems. I thought I would gather some information on modern resources and see if anybody will post pictures of theirs and what they think of them. I believe Joel will make it custom to suit your needs. Maybe somebody can confirm this?
    1) First up is Joel from Clockwork Bikes. You can ask for it as a quill stem which is a huge plus to me and also the fact that he's doing it himself here in the US.
    Clockwork Bikes : Options
    Here's his flickr feed: https://www.flickr.com/photos/28879558@N04/ Nice planes!
    2) Velo Orange was also doing some LD prototypes. Not sure if it ever made it into production but I like the idea that the stem passed the ISO MTB tests, 100,000 cycles of substantial load in two directions. Not sure who's making these for them.
    The Velo ORANGE Blog: More Stem Stuff
    Some highlights:
    We plan to offer it in black and chrome, and maybe a limited run in clear-coated raw finish.
    The steerer insertion length is about 65mm.
    We're designing a dedicated 1" quill adapter that we'll make if the stem sells well.
    The price should be about $80.
    The clamp is 31.8mm. Modern MTB and dirt drop bars use that size. It's simple enough to use a readily-available shim if you want to run 25.4mm or 26.0mm bars. We thought about making it smaller, but still can't get our negative shims to work.
    The Velo ORANGE Blog: Long Tall Stem Prototypes
    3) Crust Bikes (which sadly, practically, uses comic sans) has sold out of their pre orders for a LD stem. Anybody on the list? I wanna hear how it comes out. Profits from the stems go to Charlie's fund so thanks for that, Crust Bikes! 1 1/8" only for your modern bikes.
    https://www.crustbikes.com/products/...stem-pre-order
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Good stuff GOB, thanks for posting that.
    I'm getting close to placing an order for one actually...
    -eric-
    http://www.rumpfy.com
    TrinityRiverKerplunk
    I still want one for my 91 Ibis SS, if I could only get my hands on just the pre bent main tube I could make my own no problem at work, grrr.
    Saw the Velo Orange one a little while back and damn, it is half ass OK. That chrome looking one isn't my style. I wondered where all this was going and many thanks for the update too.
    Good friction shifting is getting hard to find nowadays....
    Sweet-thanks for the info GOB!
    Looking for/WTB : Grove Innovations Assault Fork, Grove Innovation Hammerhead Stem or Hothead Bar Stem
    Reputation: iamkeith's Avatar
    Feb 2010
    Looks like the VO ones are available for purchase. Two rises/extensions and three finish options:
    Grand Cru Cigne Stem, Nickel - Threadless Stems - Stems - Components
    I'd love the hear and see some photos from someone who's bought and tried one - especially if it is for use on a bike with a 1" threaded steerer. It sounds like VO have designed an expansion wedge adapter for that application, but haven't committed to releasing them yet.
    So, for now, you'd have to get a typical quill-to-ahead adapter, and the pre-tension bolt would be discarded as superfluous. And then you'd (I'd) probably need a 31.8 to 25.4 bar clamp adapter, too. Maybe all those extra pieces aren't a big deal, but I'd love to see it in practice. I can't help but think that, at some point, it would be easier and almost as cheap just to get a custom from Joel. Still, it's great that someone is doing these affordably.
    We still hang bike thieves in Wyoming [Pedal House]
    I have one of Joels, it is fantastic. Very nice, very reasonable price wise for something very custom. I would highly recommend
    Quote Originally Posted by iamkeith View Post
    Thanks for the heads up! I just ordered a couple. Can't beat the price.
    Quote Originally Posted by AKamp View Post
    Nice. how wide a tire can you fit in there?
    Quote Originally Posted by girlonbike View Post
    Not sure. I generally run tires in the 2.25 range. I generally don't like big heavy tires. Could probably do a 2.7 ish I would imagine on the rear???
    Velo-Orange LD
    I picked up one of the Velo-Orange stems for my commuter/around town bike. Running original WTB Dirt Drops w/ Campy levers and so far everything seems like it is in the right place. Looks pretty good too! (Way better than the ridiculous spacer stack and +35 deg stem I was running before) For the price I think it is an unconditional winner.
    PS: I need to throw longer cables/housing on as it brought the bars up another inch from my previous setup.
    VRC Illuminati
    Quote Originally Posted by apat13 View Post
    Looks right at home on that bike. Looks like you could loose one of the spacers you have in there too ya? Top of bars to saddle height is almost even...lowering the stem the 1/2"-3/4" could do the trick.
    -eric-
    Quote Originally Posted by Rumpfy View Post
    That spacer is also a bell mount (also from Velo-Orange)--it was fine when I had like 3" of spacers with the previous stem, but it is a little high with the LD. Flip side is I have discovered I actually use the bell more than I though I would and like where it is. Aesthetically it would prob look cleaner without it.
    half-fast rider
    Reputation: kpomtb's Avatar
    Feb 2006
    This one is from Clockwork. Reasonable price and turnaround for custom.
    A wise man once said: "Always Ride"
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Velo Orange Cigne Stem w/70mm extension w/ 25.4-31.8 stem shims and a 25.4 Salsa Woodchipper on my DB Overdrive. I swapped the stock threaded fork/headset for a Surly Cross Check fork and FSA headset. I know, I'm straying from the VRC, but it's the most comfortable the bike has ever been with drops. It does limit the front tire clearance to about 45c, but now it just matches the rear!Modern LD Stems-file_000.jpg
    Quote Originally Posted by kpomtb View Post
    Nice Coconino! Let's see more of that. Is there a max height that Joel will do? I'm just wondering why have spacers when it's custom?
    half-fast rider
    Feb 2006
    he would have made it taller, i may replace it at some point. I don't love the spacers, but didn't want to cut the steerer again, and it is inserted about as far as I feel comfortable. Geo on the bike was loosely based off old MB1s. Does duty on gravel, cross, some xc, and road.
    Stokeless Asshat
    Reputation: jeff's Avatar
    That's a sweet bike. Garro was stoked with the way it came out and really enjoyed building it.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    taste death, live life.
    Reputation: super_stein's Avatar
    Your Ted is awesome! Interesting bronze color.
    Quote Originally Posted by super_stein View Post
    Thanks! Not sure if you remember, but I am the guy who bought the two ted's from you a few years back--the blue one with the color matched judy and the orange one with the headshock.
    I remember. I was up to 5 Ted's at that point, now just one.
    Feb 2015
    VO Cigne Stem
    Im really grateful for having a company like Velo Orange to create these Cigne Stems for people like me who would probably would never find a vintage LD stem, let alone afford one!
    Feb 2015
    Took the Bontrager out with the VO LD stem and noticed I'm getting a little too much slippage where the stem meets my adaptor. What adapters are you using? I am going from 1" to 1 1/8" threadless. When I stand in front of the bike with two legs holding the wheel, I can move the stem/handlebars in the opposite direction. Everything is clamped as tight as I can get it.
    Feb 2010
    Quote Originally Posted by Wissahickon View Post
    Thanks for posting your experience and pictures. Unfortunately that's what I was afraid of. You might try the nitto adapters which have a good knurled surface. If it doesn't work, I can't imagine what would. You should mention it to VO and ask what their adapter plans are. BTW, did you just remove the pre-tension bolt that came with the stem?
    Feb 2015
    Hey Keith,
    I wrote VO and I'm waiting for a response. I saw that Nitto adapter but it was much more expensive than I wanted to pay. It does indeed look like it could work.
    I just removed the pre-tension bolt and I'm only using the single bolt clamp at the bottom. It seems like it clamps pretty well but the two slippery surfaces of the adapter and stem allow the stem to rotate. I just placed an order for Park Tool SAC-2 assembly lube which is supposed to add grit when assembling slippery alloy or carbon parts. I never used this before but it's supposed to help spinning seatposts, etc. Will report back when it arrives. If that doesn't work, I'll try hairspray or engineer something...I really love the stem and want it to work!
    May 2014
    I've used carbon assembly compound on many a slippery seatpost with great success. Hopefully it works as well on the stem.
    Feb 2015
    Quote Originally Posted by LeeDumler View Post
    Good news, it worked. No more slipping stem!
    I have wanted to monstercross an old hybrid for a while. The new VO stem really helped kick that project along. I'm still sorting it but it's fun so far.
    "Iím basically the equivalent of a tunnel dwelling hobo who insists on drinking only top shelf hairspray."-Stevil
    Oct 2015
    AKamp, what shifter mounts are you using on that nice steed? Can't tell but they're not WTBs, are they readily available and if so, what's your opinion of them? Cheers
    Modern LD Stems
    I made the mounts. Took about a day of thinking about it and about a hour of hacking them together. They work pretty well but the rear one the shifter rotates on the mount a little. I think a dab of jb weld would fix that.
    Oct 2015
    AKamp, thanks for the reply, if I'm less than thrilled with barcons I'll try that route, I like tinkering, but don't have the space for a proper shop/shed so it'll be time to visit a friends garage.
    Oct 2014
    An LD example from Crust. Love the position it puts me in, I just wish that it had a 2 bolt removable face plate for easier installation. Once it's on there though, its good to go. I have about 350 miles with it on everything from road to single track and rocks and it's been awesome. Modern LD Stems-rove-ld-stem.jpg
    Oct 2015
    [QUOTE=girlonbike;12729781]I know that some of you guys are getting desperate for LD stems. I thought I would gather some information on modern resources and see if anybody will post pictures of theirs and what they think of them. I believe Joel will make it custom to suit your needs. Maybe somebody can confirm this?
    [url=http://velo
    GOB, I just ordered one of the Crust LD stems in clear coat (they're sold out of the black), we'll see how it performs on the Phoenix. Is the schematic of the stem directly from Crust? Are you sure it's accurate. I was trying to find the dimensions, but no luck on their website.
    I'll report on the ride and product after I get a few rides on it.
    Cheers,
    Oct 2014
    The schematic on the crust site is accurate, it's one of the thumbnails on the product page and yes, what is above looks to be taken right from the site. I just received, what I believe was the last black one from Crust the other night. I am swapping it out for the chrome one that you see on my Kona in the above post. I really wanted black, but they were only offering chrome when i built the bike several months ago. I have a chrome one if anyone is interested. If you are looking to get your bars up there, you should enjoy it.
    Oct 2015
    Ahh thanks, good to know I think it should work out on the Phoenix, I too was looking for black, but as they say about the early bird. If I am too put off by the clear coat, it'd be relatively easy to get it powder coated black. Cheers
    Oct 2014
    I actually really like the clear coat. I love seeing the welds contrast with the steel. Post a pic when you get it mounted.
    Oct 2015
    Crust clea coat
    The Crust came in quite quickly. The brazing is very smooth and pretty. The build is far from complete, but from an initial comparison to my other dirt drop bike it looks like it will put me in the correct position. The build will be mostly black (fork, wheelset, hoods, tape) and I hope the clear coat meshes well with the overall bike, but if it's horrid I'll have it powder coated black, we shall see. A very reasonable price and the profits are still going to the Charlie Cunningham fund!
    Reputation: Linoleum's Avatar
    Those VO stems wishlist only now. Bummer!
    'Calm Down'
    Reputation: GrumpyOne's Avatar
    Quote Originally Posted by Linoleum View Post
    From their blog it looks like more Cigne Stems are coming in April.
    -jw
    "And single-speeding 29ers are mountain biking's equivalent of Scientologists..." - Captain Dondo
    Reputation: dfltroll's Avatar
    Anyone know how much steerer tube a VO Cigne Stem can accommodate? I know it needs at least 5.5cm of steerer, but what's the max? I'd like to try one of these stems with Cowchippers on my Ogre but don't want to cut the steerer tube down further.
    All good expeditions should be simple in concept, difficult in their execution and satisfying to remember--Alastair Humphreys
    Dec 2015
    How much longer is the steerer you have? I mean you could use some spacer beneath the stem and on a certain point a longer screw. Maybe you can get a better fitting fork for test riding the stem or get a cheap high rise stem which you can put on some spacer to get the bars where they would be with the Cigne without using spacer...
    Mtn Biker Machinist
    Dec 2004
    The Cigne stem has a washer welded into it that acts as the stop for the stem bolt. The washer is 2.6 inches measured from the bottom of the stem with the depth gage on my calipers. That is the max steerer you could have unless you use spacers. See pic.
    Quote Originally Posted by 1 cog frog View Post
    Thanks! That's what I was looking for. I'll have to rethink this project as I'm reluctant to trim my steerer tube.
    Mtn Biker Machinist
    Dec 2004
    Spacers solve that problem. How much more steerer are we talking?
    The total steerer length above the headset is about 9.5cm so I'd only need 3cm of spacers. Not that might put the bars too high. The stem would be going on an XL Ogre which is a tad big. If I do end up pursing this set-up, I'll be sure to post a picture here.I'd be using Cowchipper bars. I tend to ride more dirt roads than singletrack but I'd be fine with drops on the trails I ride, especially on a bike with big tires like the Ogre.
    Think differenter!
    I did end up ordering the stem from VO. We'll see if I go through with the swap. With the steerer uncut I think the bars will be too high but I'm reluctant to cut the steerer until I know if the set-up will work for me. This could wind up being a costly little experiment. Good thing I'm getting ready to make a parts purge.
    I came across these creations in my search. The first in an XL Troll with the LD stem as found on the Yellow Bicycle Haus IG stream. The second is an Ogre with a Crust Towel Rack (formerly Leather Bar). The stem is... welll... unique to say the least and opposite of an LD. Also found on IG.
    Dec 2015
    The "unique" stem and as it seems the bike as well where made by Rick Hunter - Hunter Cycles
    This is my setup with the VO LD stem:
    Quote Originally Posted by caemis View Post
    Looks nice.
    The stem was made by Rick but the frame is an Ogre with a Fargo fork if I'm not mistaken. A better view of the entire contraption.
    https://www.instagram.com/p/Be1Q4PHg...=reverend_dick
    Rolling.
    So it works great. Haven't ridden singletrack yet but did some steep climbing and descending on dirt roads and it feels great. Feels natural in the drops which is the idea, right. On top of the hoods feels odd. I just need to remember I'm riding this as more of a dirt drop mountain bike than a monster cross.
    The Cowchipper bars are great but I can see playing around and maybe trying some Woodchippers or Soma June Bug.
    Dec 2015
    Looking good! I was out on the weekend as well:
    Finally got out for a great ride on singletrack with this set-up. It worked quite well. In fact, the set-up was way more comfortable and capable than I anticipated. Far more than some temporary novelty set-up. I'd still like to get a stem with just a tad less extension although the same rise. We'll see.
    Attached Thumbnails Attached Thumbnails Modern LD Stems-surveyorsridge18.jpg
  1. Are modern bikes more fun?
    By mountainbiker24 in forum General Discussion
    Last Post: 02-22-2016, 12:24 PM
  2. Modern Hoo Koo E Koo
    By l'oiseau in forum General Discussion
    Last Post: 10-15-2015, 04:17 PM
  3. VRC vs Modern
    By bing! in forum Vintage, Retro, Classic
    Last Post: 01-22-2015, 03:39 PM
  4. Help with A-C heights on modern forks and modern frames
    By Blatant in forum Shocks and Suspension
    Last Post: 05-28-2012, 05:24 PM
  5. Carbon Stems vs Alloy Stems & Carbon Seat Post vs Alloy Seat Posts
    By torque29er in forum General Discussion
    Last Post: 12-05-2011, 10:01 AM
Members who have read this thread: 98
