    Mar 2005
    mid-90's Rock Shox Judy fork with quil steerer tube - help identify and service
    A friend has a nice StumpJumper M2 with an RS Judy XC fork on it, however it's older than any I've seen/worked on. It's got a quill stem (I've not measured steerer diameter yet, but assume 1 inch) and has a canti cable guide.
    I've attached an image of what the frame looks like, although the one in the 1996 specialized catalog has an a-head stem.
    I've also put in an image of the fork.
    I've found a manual from about the time, and was going to google each part by name to see what I can find, but thought I'd post here first and see if there is a good guide online or something?
    Thanks,
    Name:  rock shox judy with quil.jpg
Size:  10.2 KBmid-90's Rock Shox Judy fork with quil steerer tube - help identify and service-screen-shot-2013-11-04-12.06.05-pm.png
    マスターの自転車整備士
    What color is your friend's M2? Judging by the fork's vintage, I'd venture to guess it's a 1" quill. You need to find a reprint of the 1G Judy Service Manual for the 411 on rebuilding the fork. Parts will be scarce, though.
    If the innards look OK, I would try and refurbish the fork, or else try and find a used fork in good condition.
    Mar 2005
    Thanks. The fork is the same color as the one in the pictured above with the fork on its own. I've just found a manual, and will investigate further. A real shame that parts are not available, as I'd really like to help get these forks going for a lot longer.
    thanks
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    well, it depends on how original you want to make them. With some slight modification, you can use parts from the 28mm stantion sids.
  1. Can I rebuild old Rock Shox Judy XC?
    By GoBraves012 in forum Shocks and Suspension
    Last Post: 11-17-2012, 02:42 PM
  2. Paid Spam: NOS Rock Shox Judy BLACK Crown for Bontrager w/Ti steerer
    By bryanus in forum Vintage, Retro, Classic
    Last Post: 12-07-2011, 04:47 PM
  3. How to determine fork travel (Rock Shox Judy)
    Last Post: 10-10-2011, 10:04 PM
  4. Replies: 3
    Last Post: 04-24-2011, 05:11 PM
  5. Old Rock Shox Judy Help
    By sxmatt in forum Shocks and Suspension
    Last Post: 03-08-2011, 11:30 AM
