Results 1 to 3 of 3
    Kick Start My Heart
    Reputation: davez26's Avatar
    Dec 2004
    Mag 21 Single Filler Tube mod?
    I was in a different thread and ran across the photo and quote with.
    It solves some problems on my Mag 21.
    I am intrigued as it is suggested that this was a published mod at one point.
    I could probably source the cap conversion, but what about that presta tee?
    Quote Originally Posted by DFA View Post
    It's an old moto trick from when air forks were de rigeur. The valves on the forks were connected with a single filler valve. It balanced the pressure out between the forks so you would have even pressure in both legs. Seen it done on Mags before. MBA featured it as a Mag hop-up at one point.
    Reputation: mainlyfats's Avatar
    The old mechanic in me doesn't get it... The legs are braced together to provide a balance.
    The cynic in me says that Mag21's are decorative/collector today. Why push the performance envelop?
    Kick Start My Heart
    Dec 2004
    Not so much about performance as about the lack of air valve replacements.
    Both of mine died. I did a presta valve conversion, and it worked greet, until I busted a stem off.
    This worked good, but sticks up to high, and hits the frame when the bike, uhh...crashes.
    I am all ears for any viable replacement air valves or alternative replacements.
  1. Brazing: filler, tip size, resource recomendations
    By MannaDesigns in forum Frame Building
    Last Post: 03-18-2013, 09:55 AM
  2. Retrofit frame for belt drive, TIG / Silver filler?
    By zipzit in forum Frame Building
    Last Post: 12-04-2012, 10:02 AM
  3. 1 1/8 vs taper single crown steer tube
    By bhigdon101 in forum Downhill - Freeride
    Last Post: 04-09-2012, 02:58 PM
  4. Wood or dirt for your filler.
    By Fletcher-Love in forum Trail Building and Advocacy
    Last Post: 02-05-2011, 12:05 PM
