Results 1 to 7 of 7
    Reputation: EatsDirt's Avatar
    Jan 2014
    M950 XTR Chainrings - New/Aftermarket Option?
    Hello all... wondering if anyone knows where to dig up new M950 XTR chainrings (need middle 34t) or if there are any aftermarket brands are compatible/spaced correctly. I've been digging around the interweb and can't find much and don't care to risk purchasing used.
    Perhaps Warhawk Industries?- 4 Bolt 112mm BCD Chainring
    I've read changing the spider is an option but I'd prefer not to purchase a spider + three new c-rings.
    Any help is appreciated.
    Feb 2013
    I got lucky by finding a lightly used m950 spider/ringset at my favorite local shop. The three rings cost me less than a new 34t middle ring from Warhawk Industries and I have extra parts.
    I was willing to pay good money but I couldnt find one in good condition anywhere. And a NOS m95x 4x112 34t chainring is going to be $$$
    So my advice is to keep your eye out for a used spider assembly. Good luck
    Riding rigid
    The spider option would keep you on the 950 cranks on the trails longer. Check the trade thread in the single speed forum. User murf99 had a 104 compatible spider for trade (12/7/13), all he was looking for was some tires. A 104 compatible spider would open up your options. In the long run, you will probably be able to continue finding 104 chain rings cheaper than if you needed to replace proprietary XTR rings. I have a 110 5 arm spider I'm holding on to incase I ever go to 2x or 3x on my 950 cranks.
    Jan 2014
    Thanks for the input guys.
    I probably need to replace this chain/cassette soon for peace of mind at least... if anybody happens upon a NOS 34t or a cheap standard 5 bolt spider, I'd appreciate the heads up.
    Feb 2014
    Just went through this with my M950 crank set, 2 full days checking all the options. Best one I found was getting a middleburn 4 bolt, triple ring spider. $76.00. Allows you to convert it from 68/112 bcd ( hard to find rings) to 64/104 bcd ( easy to find ring).
    found here. Middleburn XTR M952 Replacement spider
    A Raceface Turbine 9 , triple ring set. $95.00. I had the spider anodize red. $10.00
    M950 XTR Chainrings - New/Aftermarket Option?-20140313_120739.jpgClick image for larger version.
    Riding rigid
    Let's see it with the crank arm, then on a bike.
    Feb 2014
    M950 XTR Chainrings - New/Aftermarket Option?-20140319_164410.jpgM950 XTR Chainrings - New/Aftermarket Option?-20140319_151545.jpgM950 XTR Chainrings - New/Aftermarket Option?-20140319_153131.jpgM950 XTR Chainrings - New/Aftermarket Option?-20140319_153119.jpg
    Just back from LBS and works great on bike stand and parking lot ride.
  1. Aftermarket XX1 chainrings?
    By mikesee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2013, 05:22 AM
  2. Aftermarket Chainrings for XTR 960 Cranks??
    By durianrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2012, 01:52 AM
  3. Favorite Aftermarket Chainrings?
    By Ace5high in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2012, 03:34 AM
  4. Best option? XTR M950 series mix ....
    By abailcb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-02-2011, 06:09 AM
  5. Aftermarket Chainrings for M770 Cranks?
    By LarryG in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2011, 03:40 PM
