    one chain loop
    Reputation: fishcreek's Avatar
    New question here. Liner for XT brake cable
    I am repacing my brake cables for an XT one and it has 2mm cable instead of the common 1.5mm. Where can I get a proper liner for it? Searched everywhere, not a fan of running bare cable on top tube. Thanks in advance.
    everything sucks but my vacuum cleaner.
    Reputation: datasurfer's Avatar
    Nov 2006
    small diameter plastic tubing...
    Nov 2006
    I believe this is what you are looking for. I use it to sheath the brake/shifter cables along the top tube as was originally spec'ed on Kona/Voodoo bikes from the 90's. Much prefer it to the little donuts that keep the control cables from rattling against your frame.
