Page 1 of 2 1 2 LastLast
Results 1 to 25 of 39
    It's a sad sad day, maybe a though axle will help
    Reputation: RSAmerica's Avatar
    Righty
    Old School
    Reputation: Joe Steel's Avatar
    Is there a story that goes with that pic?
    "JRA" ?
    Quote Originally Posted by Joe Steel View Post
    "JRA" ?
    Well, I was riding and I was moving along pretty well. I will say that I don't baby the bike and I know that everything breaks, I am just bummed I won't be able to ride it for a little while. Rode a pretty technical downhill in Durango when I heard a little ping and the front end got a little squirmy. No crash luckily. I'll get in touch with steve and see what he says. I am just worried the replacement will be beefier and it won't ride as well. It really was a great riding fork, may she rest in pieces.
    Reputation: mainlyfats's Avatar
    That's heartbreaking... (disc brake sh!t talk goes here).
    Hope you get up and running again ASAP.
    I know, it's only 3 years old but no other forum knows what it is.
    The Crazy Cat Lady of VRC
    Reputation: eastcoaststeve's Avatar
    That is sad...at least it died with its boots on.
    Better broken riding, than hanging on a wall.
    Glad you didn't get hurt...could have been bad.
    Steve
    Reputation: chefmiguel's Avatar
    Good thing you're ok, hopefully you get bumped to the front of the line for a fork.
    Technology dragass
    Reputation: tductape's Avatar
    Weird break.
    Seek: Koski Trailmaster. Breezer Series 2 or 3. Cunningham Racer.
    Reputation: DoubleCentury's Avatar
    Quote Originally Posted by tductape View Post
    Weird break.
    It looks like it originates right where the long disc tab terminates. As shown here,
    http://1.bp.blogspot.com/-mUif7LRzmR...0/DSC04290.JPG
    Sorry to hear about the fork failure. Never a good thing!
    I don't know where it actually originated but the inside corner of the upper mount on the disk tab was the only place that was still together when I noticed it. That quickly separated when I grabbed the front brake and rocked just a little
    This was when I first noticed it, cracked about 7/8ths the way around. Pretty clean break, very little deformation on the metal. Also break is about 1/4 inch above the upper mount.
    Well, it took steve about two hours to respond to my email. If sarcasm translated well to the forum I would have something sarcastic to say. Let's just say I am super impressed, once again.
    I guess frontal impacts would cause elongation of the front of the fork leg and compression on the back. So the crack should appear on the front first. But I think the bending of the fork leg is being concentrated at the end of the disc tab.
    Steve worked with John Castellano to come up with a design that distributed the disc load over a long distance, but it may have had unintended consequences.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Sorry man.
    Suspension adjusted? Are the legs butted? Did you ever use the low rider mounts?
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Non-suspension adjusted. I don't know if the legs are butted or not, but it does ride incredibly well. I have mounted a rack up but haven't actually put them to use yet. Steve put rack mounts on the frame as well, plan on using them eventually.
    Reputation: iamkeith's Avatar
    Feb 2010
    Quote Originally Posted by AKamp View Post
    ... plan on using them eventually.
    That's the spirit.
    We still hang bike thieves in Wyoming [Pedal House]
    Sergeant Spandex
    Reputation: lewisfoto's Avatar
    Nov 2013
    Weird break.
    Indeed looks like a carbon failure. Better lock, and delete, this thread ASAP before word gets out. (joking)
    Not as bad as a carbon failure, I didn't face plant and stick a carbon tube through my spleen!! When I noticed it it still wasn't separated. I think a lot of people would get turned off by seeing a fork like this but the people who are looking to get a Type II probably have been riding long enough to know that everything breaks, no matter the quality of the product. Steve says it can be repaired, I trust him.
    Even if I have to pay full price for another fork, still well worth it.
    Reputation: Bigwheel's Avatar
    Easily repairable as he can just sweat out that leg and replace it with another.
    Very curious break however.
    A bike by any other name is still a bike.
    gobsmacked Moderator
    That's awful. Glad you're okay. You going with some beefier legs this time?
    Wanted: WTB rollercams and brake bridges
    Reputation: ameybrook's Avatar
    What Durango trail?
    Why would you own 100 Yugos when you could own 1 Porsche? - Rumpfy
    Quote Originally Posted by ameybrook View Post
    What Durango trail?
    Heard the first little twang on Stacie's. Then climbed back up to raiders and down snake charmer. Noticed the crack riding back up the power line towards FLC
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Poor mans lefty, I mean righty.
    A garage full of steel frames means happiness.
    Quote Originally Posted by CS2 View Post
    Get mendon to modify that for ya! braking is overrated, anyway.
  1. Replies: 2
    Last Post: 01-23-2013, 09:20 AM
  2. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum XC Racing and Training
    Last Post: 01-22-2013, 09:04 PM
  3. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  4. Hope Pro 2 rear axle upgrade? install Evo bearings and axle?
    By KrisRayner in forum Wheels and Tires
    Last Post: 02-24-2012, 02:05 PM
  5. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 09:09 AM
