• 02-22-2013
    patineto
    I have seven Klein's in need of "housing guides" where to you guys get this tubes...?
    I promise if I find the answer elsewhere I will share it too
  • 02-22-2013
    LARRYJO
    I have bought 4 sets from this guy and they have worked great.
    Klein Bike New Cable Liner Frame Guide Housing Sleeve | eBay
  • 02-22-2013
    patineto
    Thanks Larry that is a good start, i just wish i can find the "source material" in bulk and make them my self..
  • 02-22-2013
    holden
    I believe it's PTFE tubing, 3.2mm OD. I forgot where I bought mine from (years ago).
  • 02-22-2013
    patineto
    Thanks senor, I take a look on McMaster-Carr and go from there..
  • 02-22-2013
    patineto
    Update: sadly MaMaster does not have such a small size, HERE is what they have
  • 02-23-2013
    da'HOOV
  • 02-23-2013
    patineto
    Here is what I have found so far..
    -White, 50feet for $55
    -Many colors, so far no price but not translucent.
    -I think is translucent but I'm waiting for a response also on the price.
    -McMaster's in traslucent for about a dollar a feet
    Still not cheap, but cheaper than the already made stuff on Ebay
  • 02-23-2013
    jaxes88
    I would imagine that it doesn't need to the high temp teflon stuff. Could you use some of that small black plastic tubing that they use for garden irrigation? Just a thought.
  • 02-23-2013
    holden
    OD and wall thickness are too thick.
  • 02-23-2013
    jeff
    And the question no one has asked. Why 6 Kleins? :)
  • 02-23-2013
    patineto
    Actually I have Nine of them but only seven of them need new liners..
  • 02-24-2013
    jeff
    The question went unanswered.
  • 02-24-2013
    patineto
    Very basic answer, because I like them and I have great memories of them from years gone by/
  • 02-24-2013
    LARRYJO
    Another VRC dick?
    Or are you trying to be funny? Witty?
    How many bikes do you have Jeff?
    Why say anything at all?
    1,2,3 go!
  • 02-24-2013
    jeff
    Not a dick at all Larry. Witty? Not today. *****ey today? Yes. Bikes I own? Maybe 12-15. Nothing over the top as far as quality/heritage goes. I find 9 of the same make over the top but that's just me, today. 3-2-1 go.
    Another VRC dick?
    1,2,3 go!
  • 02-24-2013
    LARRYJO
    It seems that if owning 6-9 of the same builder/company is over the top then half the members of this forum are over the top.:)
    People come to the VRC for help and sometimes in return they get no such thing. As my dad used to say "it only takes one ******* to spoil everyone else's fun".
    Maybe you where not trying to be one and all you really wanted was a serious answer to your question. If so, I apologize. Please tell me I was worng. Please.:)
  • 02-24-2013
    jeff
    Sorry Larry...you're wrong. I was being a judgmental, Klein hating jerk. Now I'll just go hide in the corner and keep my peep shut until I have something nice to say. :)
    Jeff
  • 02-26-2013
    pinguwin
    I bought some stuff from Graingers. The tubes from Klein had the sizes stamped on it and I used that to get it from Graingers.
    Nylon Tubing - 1/8" - Pipe and Tubing - Grainger Industrial Supply
    If someone needs an exact ID size, I can measure it at the machine shop but going from memory, it's 1/8 OD, 3/32 ID. The official Klein tubing isn't teflon or PTFE, it's simple nylon tubing. Don't pay the guy on ebay. To flare the end, take a larger nail or punch, heat it up and form the flared end. I bought 50 ft. and don't ever need any more.
    Now, if I could only get an old piece of nylon housing that has broken off inside a down tube.
  • 02-26-2013
    patineto
    Wow you just save me a ton of money, thanks..
    So do you want to sell me the rest of your roll, I pay you the Grainger's price even if the roll is not complete..
  • 02-26-2013
    girlonbike
    Sweet! Thanks, Pinguin!
    LarryJo, no need to call anybody a dick. OP was kind enough to answer. I also think his answer was a very good one.
  • 02-26-2013
    eastcoaststeve
    ping, FTW had a neat trick for getting stuff out of Klein tubes recently...he said he rolled a small piece of paper into a tight cone, put it in a hole in the tube, and turned the frame until the piece (broken drill bit) hit the paper, then he just tipped it out. Might be worth a shot with your stuck tubing.
    Steve
  • 02-26-2013
    girlonbike
    I think I can picture that....I'd probably lose the cone in the tube as well. heehee. Thanks for the tip, Steve. FTW should make videos!
  • 02-26-2013
    G-reg
    Jagwire sells replacement lining for Nokon housing. It's a couple bucks for a few meters of the stuff.
  • 02-27-2013
    datmony
    I would contact a local plastic supply place, virtually every decent sized city has one and you would be very surprised the sorts of stuff they have around. Might save you from buying a huge roll.
  • 03-05-2013
    Tim Kriksciun
    My LBS was able to source them. If I remember to ask next time I'm in there I will post the info here.
  • 03-05-2013
    Tim Kriksciun
    My LBS was able to source them. I will ask next time I am in and post the info here.
  • 03-07-2013
    sq_root_of_2
    3 Attachment(s)
    Is this the size that works?
    Approximate measurements:
    OD
    Attachment 778615
    ID
    Attachment 778613
    Tubing
    Attachment 778614
  • 03-08-2013
    pinguwin
    I just took the tubing into a machine shop this morning and the OD is .125". They've got boxes full of hundreds of precision cylindrical pieces of metal, in increments of .001", that are used to measure inner diameter. The tubing has an ID of .088.
  • 03-08-2013
    girlonbike
    Thanks Pinguwin. I'm going to pick up a little bit for a project.
  • 03-08-2013
    sq_root_of_2
    I use this for my bikes at friction points, but they are not Klein bikes. It works with the old thick brake cables as well as the thinner shifter cables.
    Conversion to inches OD = 0.1185 inches ID = 0.102 inches. Again my measurements are approximate because the tubing is not completely round. I tried to get the best average reading.
    I will try to go to my source and look at the reel later today, maybe it has the actual dimensions on the reel.. It is fairly inexpensive I seem to remember somewhere around 10 cents to 50 cents a foot no quanitity minimum. Available in black as well.
  • 03-27-2013
    patineto
    From Gary Klein him self (I ask on the Klein facebook page)
    " it is just polyethelene. Teflon shreds and binds up the cables. 1/8 is correct. We eventually just used it to thread the cables and removed it in most cases."
  • 03-27-2013
    girlonbike
    Good job, guys! SQrt2, I owe you an email. :)
  • 03-27-2013
    G-reg
    If your not going for a "parts matching" restoration.....here's a link to the Jagwire/Nokon replacement stuff.
