Lets find out. I have been practicing brazing so this should be fun.
Here are my plans:
1. Sandblast off all that rust.
2. drop some hot brass in around the joints to smooth them out.
3. Flatten and trim the drop stand tab, drill and tap a derailler hanger.
4. Cold set the rear to 135mm spacing, re-align the dropouts.
5. Braze on cable guides/stops for brakes and deraillers.
6. Braze on a disk brake adaptor on the rear.
7. Ream and face the headtube.
8. Powder coat.
9. Custom Brass headtube badge.
The build will consist of mostly parts I already have. Mavic wheels with King ISO hubs, Fox F-80 Talas fork or a Fox f-100 RLC (Depends on how slack it ends up). XT cranks, Sram X.0 rear derailler. Thomson stem. Easton Monkey bar. Hope Mono Mini brakes.
Wow. Frames really haven't changed all that much in 100 years, have they?
For cruisers, no they really have not changed much. What worked then still works now but I would say the quality has fallen off quite a bit. There are headsets available that allow you to use a 1 1/8 inch steerer in a bmx standard size headtube without boring out the headtube.
It was pretty funny sweating those tiny steel letters with my huge aircraft torch.
Interesting about the headsets -- I had no idea! So this is a 32.5 I.D. head tube, not ISO? It will be interesting to watch your project. I hope you'll post updates. I worry a bit about the (presumably) mild steel frame with the extra leverage of a suspension fork, not to mention disk brakes, but I bet it's pretty overbuilt anyway!
I have had reservations about that as well but I have a 36 Mercury that I have been running a short travel Bomber on for about 2 years without issue. I have jumped it and ridden pretty hard off road. The head tube is so thick I think it will hold up. I am a little more concerned about the rear end given that the chain and seat stays are oval. I may cut out the current brace between the stays and braze in a slightly wider one after cold setting. I may also braze a brace in close to the dropouts.
I vote for 80mm fork, mine was plenty slack with the Marz - climbing was twitchy (slack seatpost angles on these newsboy frames doesn't help either) but great fun pointed down.
Disk in front was all I ever needed, I ran a Nexus hub with roller brake in back.
I would not worry about the head tube, I've seen more brakes where the seat stay joins with the seat tube once you widen out the rear end. Adding some weld will help though. I've done 1000's of miles on my Schwinn (not pre-war) wearing out 3 sets of tires, yes you can go far as you want as long as you ignore those creaking sounds, well most of them anyway.
I got it back from the sandblast. It lost about 120 grams of rust but I suspect most of that was muck built up in the BB shell. It has some pitting that I have filled in with hot brass. I cut out the old fender mount/brace between the chainstays and cold set the frame which was much easier without the brace. I re-aligned the dropouts and then cut a piece of steel tube to fashion a new brace. I am going to use the same steel tube to fashion braces for the dropouts to stiffen up the rear for disk brakes.
This is my first time brazing. I did some practice runs on some steel scrap. I brazed 2 pieces together and it seems the key to a good weld is getting the metal hot enough to keep the molten brass flowing. Otherwise you end up with globs and a weak bond. It is also key to prep the surface by roughing it up so the brass can flow in and bond. I brazed the 2 pieces together and after cooling I put it in a vise and beat the sh!t out of it with a hammer to see how strong it was. To my suprise it was very strong and took alot of pounding to break so i am confident the disk brake mount will hold up assuming I can get it mounted properly.
My first time brazing. Still alot of file work left but I managed to do it without overheating and warping the frame. Its not pretty but I think it will smooth out ok. Once it is powder coated or painted it should look fine.
The paint actually usually highlights the dips and uneven spots (especially undercuts), so try to get it as good as you can before you paint it. I filed some joints before which I tought were perfect, but they didn't look so perfect after the paint. Looks great for your first time brazing, Cheers.
paint is 90% prep. Looking forward to seeing your completed project, with some dirt on it.
You said it there. This bike is going to require lots of prep before painting. I was going to do a powder coat but there are some areas with pitting that need to be filled. I don't think you can do power over body fill. Either way, my paint guy is really good and cheap.
I got the derailler hanger tapped and I have fashioned some gussets to reinforce the rear end. After I get the disk tab mitered I will see if everything will fit and if so I will start brazing.
I brazed in some braces for the rear end. I used the same tube that I used for the chainstay brace, heated it, hammered it flat and mitered it to fit the shape of the rear triangle by hand. Lots of file work. I brazed it in and then hit it with the angle grinder to get it shaped right. I had to coat it with primer because my garage is so damp that everything flash rusts practically overnight. Next step is the disk brake mount. Not bad for a guy that learned to weld watching YouTube. I also tapped and shaped the drop stand tabs into a derailler hanger and trimmed the non drive side dropout.
