Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 100 of 100
  1. #76
    Reputation: Bikemaya's Avatar
    Sep 2012
    Are you going to keep the frame that matte black? The rock shox stuff kinda clashes with its flashy bright logos and shiny finish.
    IMHO, name brand means squat on this build. Paint the fork the same matte black! Stealthy coolness
  2. #77
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Frame too small?
    That's one heck of a seatpost. Hope that thing is solid.
    All kidding aside, looking good, but I agree on the stealth look. Make the fork match the frame.
    frog
  3. #78
    Master of the Face Plant
    Yeah, I was using that long rod to make seatposts for all my old pre-war bikes. I used it to hold the frame for painting and now it is a little stuck. I will need to put it in a vice to get it back out. I was debating taking the logos off the fork. I think I will and I may remove the labels from the wheels as well.
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
  4. #79
    Sooo nasty! I love it!
    I vote fullly label-less.
  5. #80
    Jan 2009
    Looking great!
    What are your impressions of those "Mr. Tick" bars?
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  6. #81
    Quote Originally Posted by J_Westy View Post
    Looking great!
    I have not actually ridden them yet. The sweep is a little more than I am used to but it feels comfortable. The quality is excellent and he will do them in custom widths for the same price. I am lucky my brake cables were about 5 inches too long for my single speed because they came off an extra large bike so they work with this bar without having to change cables.
  7. #82
    Reputation: Fillet-brazed's Avatar
    Great project! I think you'll find that fork will set the bike back too much (too slack). Might be worth getting an older 2.5" travel SID (or any other short fork) vs the 3" one you have just to drop it a little more.
    I agree with the others, fork needs to be decal free and flat black would be even cooler.
  8. #83
    All that remains is the headset. It should be here early next week. I plan to swap the skewers for some black XT ones, trim the cables etc. The rear brake cable is a little shorter than I would like so I had to route it differently than I planned. I could just get a new cable but I just bled these things and they are working perfect so I will wait until the next time they need a bleed to make a new cable. All the decals are gone. I would have painted the fork but to do it right would mean dissasembling it so I will wait until it needs service to do that. I made a shim for the handlebars out of an old scott handlebar. I trimmed off 2 pieces of it and made a shim for the front derailler as well. The rear wheel mounts up perfect with no brake rub. Shifting seems great in the stand but we will have to see how it is on the trail.
  9. #84
    It's like a modern klunker.
  10. #85
    Reputation: Boy named SSue's Avatar
    Quote Originally Posted by sandmangts View Post
    Nice!!! Well done indeed.
  11. #86
    Absolutely love the way it turned out. Looks great. I would throw a Brooks on there myself for a little offset of color. One with the brass rails would look super sick on there but that is just personal preference from my side. Great work!!
  12. #87
    Hi.
    Reputation: jtmartino's Avatar
    Damn man, that is fantastic work. Let us know how it rides!
  13. #88
    Still waiting on the headset so I experimented with the headbadge a bit. I used the toner transfer method to make one out of aluminum. It was much easier than brass or copper. With brass and copper you have to use ferric chloride which is just horrible stuff. With aluminum you just use Lye (Sodium Hydroxide) and water, same stuff I used to strip ano off of old rims. I spend 2 dollars on some surplus aluminum and it worked great. Got a nice deep clean etch in about 45 minutes. I think if I had a better laser printer I could get a more detailed image but this one looks ok.
  14. #89
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Very, very nice work.
    A garage full of steel frames means happiness.
  15. #90
    Finally got the headset turned down to fit and installed. After that everything else just fell into place. I took it for the first ride around the neighborhood and I am absolutely thrilled with the way it rides. It shifts flawlessly and stops on a dime. The steering is not lazy feeling at all. This is the first time I pulled a bike off the stand and rode it without having to adjust the shifting or brakes in some way. Just a little tweak to the bars and saddle and I was dialed in. I absolutely love it. I will get some dirt on it this weekend and see how it holds up. And I will try to get some better photos.
  16. #91
    Took it out for a few miles of dirt today. Front derailler needed some tweaking to get it to drop to the small ring but other than that everything is solid. The 2.35 tire in the rear is cutting in pretty close but it sure takes the edge off the small bumps. 34.6 pounds as it sits.
  17. #92
    Dec 2011
    Beautiful bike! Only 34lbs that's lighter than I expected, I applaud you sir it turned out very nice
  18. #93
    Mar 2013
    Love It!!
  19. #94
    ong
    ong is offline
    That's really excellent! Very distinctive. How's it ride?
  20. #95
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    That is crazy awesome. I'm really impressed with all the custom fab work! Much respect...
  21. #96
    It is still in one piece. I commute on it 12 miles daily and I get a few miles of dirt on the way home. I have ridden a bike everyday since January 1st this year as a part of my weight loss/get in shape for Keyesville program. Although I ended up not going to keyesville I stuck with the plan which included eliminating beer. So far I am down 17 pounds. So yes this bike has taken a good pounding. My biggest concern was whether or not the rear wheel would move in the dropout. After several drops and small jumps and some off camber impacts it has not budged.
    My biggest mistake was using grey primer, I could have used black and all the chips in the paint I am getting would not be so obvious. I will probably strip it and get it powder coated in the future if it holds up. I just didn't want to spend the money only to have to repair it.
  22. #97
    Mar 2013
    Same here on the grey primer on my Colson!
    Not sure on the powder coat, would have to rough up the front after to add the very dark green darts I have. Currently it's a pearl black with the pearl green up front, don't really see the green until the sun hits it, then it pops. It was my first paint job, so what did I expect anyway.
  23. #98
    Still riding and racing.
    How far can you take a pre-war frame?-10427676_738061002968595_719452077839781520_n.jpgHow far can you take a pre-war frame?-10888381_10203095447657440_3199221912167234672_n.jpgHow far can you take a pre-war frame?-10934061_10203095415776643_3277064574428290262_n.jpg
  24. #99
    Reputation: onlycrimson's Avatar
    Nov 2008
    That is really cool, does it handle ok with that slack head tube angle?
  25. #100
    He be a moose too.
    Reputation: pinguwin's Avatar
    Just a FYI if anyone wants to make a head tube badge but you can use a laser cutter to do this work also. Most laser cutters don't have the power to cut aluminum (and if they do, turn the power down) but you can etch the anodization and leave a nice Al finish underneath.
    The laser cutter also allows extremely fine details and basically, if you can see it on a computer screen, the laser cutter will etch it for you.
