    HELP > Ringle Slamma Jamma
    H E L P
    I need a bearing for a Ringle Slamma Jamma Headset (1 1/8").
    It is for the bottom cup but I think they are the same (top & bottom).
    Your help is much appreciated!
    T H A N K S
    looking for Adroit Strata fork in 21", preferred color = burgundy blue - THANKS
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Should be a pretty standard size bearing right?
    I sold my Slamma Jamma a while ago so I don't recall for sure.
    -eric-
    http://www.rumpfy.com
    slamma jamma ringle
    Thanks Eric,
    What I can do is measure the size of the one bearing in the top cup but I can't measure the height (since it is pretty stuck in the cup...)....
    Is this standard too (so is there a standard ratio in diameter and height)?
    and then: where to get it? ebay? or just any hardware store...? Or do I sound dumb now ?
    does any one have a crappy slamma jamma lying around somewehre from which the bearing is ofcourse not that crappy ?
    help is much appreciated !
    Neo-Retro Forever
    take the bearings to a local bearing supplier. There will be a code on the seal, and they should be able to get you a match.
    Look up "bearings" in your local yellow pages or online in your area.
