    help removing Critical Racing cantis
    I'm sure a picture would help but I'm experiencing technical difficulties- so here goes my best try at an explanation-
    When I disassembled these brakes and removed everything from the frame, I end up with the left side canti still attached to the brake boss on the front and the back. There's a brass bushing? that fits tightly over the brake boss that is attached to the canti arm itself. I can pull the assembly up maybe an 1/8" but it will not come off. I can spin it around the boss but it only spins. Do I need a gear puller to remove these brakes? FWIW, it even seems like the wall thickness of the left side brake boss is thicker than the right side.
    Stokeless Asshat
    Reputation: jeff's Avatar
    A bigger hammer. Really. The ends of the brake bosses have flared on you.
    Use a 9 or 10mm open end wrench. 9 fits perfect over the boss but a 10 will do. Slide it behind the brake and over the boss. Tap the wrench with a hammer. Bingo. Emery cloth to diminish the bulge on the boss.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    thanks jeff. that worked for the front boss, but the back is still stuck. I did remove the boss entirely from the frame and looks like a hacksaw will do the trick. I'll just get another brake boss...
    Reputation: chefmiguel's Avatar
    Try warming up the bushing with a lighter
  1. TRP mini-v's vs. Cantis
    By chowdownca in forum Cyclocross
    Last Post: 6 Days Ago, 03:16 PM
  2. V brakes / cantis to fit Fat bike
    By flashes in forum Fat bikes
    Last Post: 04-06-2015, 02:45 PM
  3. Critical Racing Gatling Gun Brakes
    By mrjustin007 in forum Vintage, Retro, Classic
    Last Post: 08-19-2011, 09:21 AM
  4. XC Pro Cantis Question
    By kool maudit in forum Vintage, Retro, Classic
    Last Post: 07-30-2011, 02:16 PM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
