Results 1 to 25 of 25
    May 2010
    Is a Hanebrink ET vintage?
    Always wanted one of these, found one for a decent price, so I went for it. Not a whole lot out there about these, so dont really know what year it is. I know the jack drive variants are the earlier ones, which this one is, but not sure when they stopped making them that way. It has Sachs power grip wavey twist shift and a Sachs 5 FD, but a Alivio RD MC18, not sure if that is OEM or a replacement. Non standard disc rotor and caliper mounting, and the calipers are pretty crude looking, especially considering Hanebrink is a "NASA engineer"..... Tektro levers that can switch between V or Canti pull. A low end spec'd bike.
    The welds on the frame are pretty sweet though.
    Anyone know of a way of dating these?
    Stokeless Asshat
    Reputation: jeff's Avatar
    Let me be the first to say....DUDE!!!! That thing rocks!..Otherwise, I'm of no help.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    May 2010
    Quote Originally Posted by jeff
    Thanks anyway!!! They are beasts.
    Stokeless Asshat
    Have you had it out for a spin? I've often wondered how they ride.
    Want:
    May 2010
    Just a couple short neighborhood cruises. It rolls through sand and soft leaf/brush covered woods pretty damn well, its like a tank. Really doesnt feel like soft earth/sand bogs you down the way it does on a standard bike. On pavement it felt a bit bizarre though. Its geared low, plus the small diameter tires add to that, so its actually quite ridable up hills and through soft stuff. I'm trying to get the brakes setup better. They are crude as it is, but the rotors need some bolts and washers to be mounted more securely. Should have that worked out this week, plus I have some snow/mud tires coming in, (along with some other components) then I'll be hitting the trails for some real testing....
    defender of bad taste
    Nov 2007
    Very cool.
    Feb 2005
    First off, I have lust right now. Those things are so cool. I know little about them technically though, what width is the tire?
    I've played around with getting my Pug as fat as I can, 4"s is about it.
    I think the bigger wheels take care of some of the low gearing feeling as well.
    Fat tires rule.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Nov 2007
    Do surly make a kit to make Lefty work with Pugsley? or do you have to have crazy mount side dish?
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    As I recall they were sold as frame/fork/wheels and the jackshaft assembly, and the rest you had to figure out yourself. The disc brakes likely came from motorcycles. They're ATV wheels and tires and the rubber blocks were shaved down as I recall at the factory cutting several pounds from the tires. MBA reviewed one once. If I remember the basics right, the crank has a single 24T ring, and the jackshaft has a 24T ring on one side, and the other side where the front derailleur goes there are three cogs... 12-18-24, which gives the equivalent of a 24/36/48 triple ring setup. The correct tire pressure for pavement and hardpack is 4psi and for snow/sand its 2psi, and anymore than that and it won't ride right (expect lots of uncontrolled bouncing).
    Feb 2005
    Quote Originally Posted by mechagouki
    Nope. I used a Project 321 adapter, swung it out to the left more, which compensated for some, dished some more, and had a workable situation.
    It wasn't quite in plane, but felt fine off road. On pavement, mmm, not great, but not bad at all. I had a 100mm rim too, had I used a Marge, or an 80, it likely would be more workable.
    Gotta play though!
    - FrostyStruthers
    Reputation: proto2000's Avatar
    Gotta love a bike that leaves chainring marks on both sides of you....
    Too many bikes, and just enough time to ride them.
    May 2010
    Quote Originally Posted by MendonCycleSmith
    Fat tires rule.
    Lefty looks bad ass on the Pugs. What do you mean by sying you swung it out furher left? I had been wondering how fat I could go on my Prophet, was thinking of putting a 24" on the rear but didnt think I could get much fatter up front on the Lefty anyway....
    May 2010
    Quote Originally Posted by DeeEight
    I think the brakes are just motorcycle or ATV or Go cart type pads jerry rigged to some aluminum plates, the pads basically make up th body of the caliper, theyre funky, I'll get some pics up after work today. This one came with Duro turf tires, look like whhat would be on a golf cart or something.... I think youre basically right on the drivetrain, havent counted teeth, but I am thinking the crank chainring to the jackdrive is a 1:1 ratio, maybe. More info tonight....
    needs drop bars
    I'll get my coat...
    If steel is real then aluminium is supercallafragiliniun!
    May 2010
    Quote Originally Posted by byknuts
    needs drop bars
    I'll get my coat...
    Yes it just screams drop bars!!!!!
    Old School Legs
    Reputation: JokerW's Avatar
    I remember Dan riding that thing at more than a couple of races in Big Bear, back in '93 or '94.
    I asked him WTF for?
    He said Why TF not? (not really, but it went something like that)
    I think he finished every long course race he entered on it.
    May 2010
    OK so in stripping the shifters/levers off of the handlebars, I saw that the Meng Jing (Taiwanese for quality) handlebars are stamped with 1995, also the Sachs Power Grip Wavey shifters are listed on MOMBAT as a 1998 introduction. The Sachs 5 FD I cant find anything on. The Sugino Impel cranks fit the late 90's time frame too. So my best guess is this is a 97-98 model... I'd really like to know when Hanebrink started using the 100mm BB shell and did away the jack drive, that would give me an even better idea.
    Here's some more pics
    The drive train/Jack drive setup
    Here is a shot of the front caliper mount and front wheel/hub with the 5 bolt rotor mount (Rotor not mounted)
    And the rotor:
    Rear Brake
    Front caliper
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    I dont know man......that derailleur is to close to the ground to ride offroad
    "If women don't find handsome , they should at least find you handy."-Red Green
    May 2010
    Quote Originally Posted by nuck_chorris
    A little bit close, but still rideable I'd say.
    Bottom of the cage is about 4" off the ground, my Killer V with a long cage is about 5", the Hooligan with short cage is actually 3", and I ride that offroad frequently, it is scuffed up pretty good though. Really I'm lookin to ride snow with this,so its not as much of an issue. I'll probably end up doing some powerline trails too. This is definitely not my "bike to replace all bikes", but I want to take it out on gnarly stuff at least once.
    Reputation: KDXdog's Avatar
    From Bike: nov/dec 95
    Attached Thumbnails Attached Thumbnails Is a Hanebrink ET vintage?-hanbrink049-copy.jpg
    May 2010
    Thanks KDX!!! A few more MB's in my archives...
    ...Hanebrink...
    Howdy ride free or die, judging from the disc brakes on your Big Bike I'd have to say you have an early version (probably "94 or "95) Dan started using Hope disc brakes late in "95 when I got my first Extreme Terrain. Last fall (as I understand it) Dan started making ET"s again, the bikes are now available with an electric motor. These bikes are upgraded with the new wider bottom brackets and a single (albeit longer ) chain (on the pedal version). These new bikes are highly refined designs...extremly capable offroad, lighter,and with the electric assist able to traverse trails at close to 40 mph pulling a trailer! I am the East Coast rep for Hanebrink bikes (NY,NJ,MA, and PA) if you need any parts or service for your "Classic". Your bike is really collectible...big and tall...vinsonbikeman7@aol.com (518) 528 1668
    May 2010
    Thanks Big and Tall, email has been sent. I was thinking it was an earlier one, but the parts were 97-98 so I'm just not sure. I'd like to get the date nailed down for certain. Thanks for the info though...
    I'd really like to get the brakes updated, the ones on it feel awful, and really dont have much power. I'm messing around with some things now to try and adapt some new rotors/calipers, but I'd like to see about how the current hubs mount the rotors, and if I might just be able to get that part and replace my current setup......
    Sep 2012
    Vintage ET
    Hi! That bike looks to be mid 90's. I can show it to my dad and ask him if you'd like?
    -Rani Hanebrink-Figueroa
    May 2010
    Quote Originally Posted by rhanebrink-figs View Post
    That would be awesome.
    I'm also in dire need of some new brake rotors, or rotor adapters to use standard rotors. I had sent a couple emails through the fortunehanebrink site a while back, but never got a reply.
    Its a cool rig, but I havent ridden it much because of the brake situation.
