Results 1 to 40 of 40
    Ariolimax columbianus
    Reputation: nativeson's Avatar
    Apr 2005
    handsome retro vintage xoxo
    http://www.bikerumor.com/2010/09/14/...ndsome-cycles/
    found this cruising on some of my daily internets, thought you folks might either love it or hate it....hipsters are starting and have been buying up all those old retro/vintage 80's mountain bikes, we've seen it in sf....
    Reputation: jmmUT's Avatar
    Either more competition for scores or easier to dump off my junk...
    Either way cool bike.
    That fork don't look like any Bstone fork I remember. Fugly rake.
    -Schmitty-
    Reputation: laffeaux's Avatar
    Very nice. Handsome makes some interesting frames. An XO-1 remake is a neat idea. Hopefully, unlike Bridgestone, they offer a 57cm frame.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Glorified Hybrid Owner
    Dec 2005
    Quote Originally Posted by Schmitty
    -Schmitty-
    700c or 26" Ashtabula wannabe copy?
    Do they actually make anything?
    If that fork is any indication as to how exact a 'copy' it is, you can take any bike, paint it orange.. er select an orange coulour way...., put on some weird bars, and call it an XO copy.
    Bstone's were pretty refined....
    -Schmitty-
    -Schmitty-
    Proud Snob
    I love that bike, and I don't care if the fork is different. The XO-1 is one of my favorite bikes ever, and when I do come across one it's either far too expensive for me or far too worn out and not original enough to bother.
    So I'll buy this most likely and enjoy it for what it is.
    The fork bend actually doesn't look that far off. However, the HTA looks to be a lot more slack than the original.
    <img src="http://www.eandsweb.com/bikes/pics/bridgestone_xo1/117_1793.JPG" height="768" width="1024">
    Check it.. Bstone, nice gradual radius almost to the tips.... Handsome looks like a straight tube that was whacked over someone's head..almost as much straight blade after the bend as before. It hard to get a nice radius close to the tips, so cheap forks often have quick and dirty rake...aka hack rake.
    I'll never know, but I bet a side by side comparison would reveal plenty of differences.. from geo to looks. I think freekin Sachs designed the lugs.
    -Schmitty-
    Humanoid Lobster
    Reputation: Jak0zilla's Avatar
    May 2010
    If it's not going to be a molecule-by-molecule repro, it might be nice to make the fork threadless. Threads are good on vintage rigs, threadless are SO much easier to deal with.
    Heck, if they want to really do the world a favor they could (have Taiwan) knock off some Salsa P7's and P10's in threadless. That Nitto (copy?) Dirt Drop stem isn't so rad that it's worth pulling out the BIG wrench to adjust the HS - especially on a new bike. Just my $.02 worth ...
    Don't call it a gooseneck.
    Humanoid Lobster
    May 2010
    And, in my humble opinion, that White Ind. crankset is fugly.
    Quote Originally Posted by Jak0zilla
    I half agree with you. Threadless headsets are easier to deal with as an allen wrench (or maybe two) is all that is needed to adjust them. There's nothing worse than having a loose threaded headset in the middle of a ride, and not having a wrench to adjust it. I've tightened several by hand and rode them home.
    However, IMO for bikes with higher rise bars/stems quill stems look about 300% nicer and offer easier height adjustment (one bolt versus 2 or 3 for a threadless setup). To me a high rise quill stem, like a Dirt Drop, looks fine. Lots of spacers below a threadless stem often looks pretty cheesy.
    Humanoid Lobster
    May 2010
    Quote Originally Posted by laffeaux
    Point conceded. I'm probably going to end up getting a custom stem with more rise because I hate all the spacers on my Bonty. I replaced fork/stem/headset, and the subtraction of the wrench flats on the top stack, single spacer, and locknut add about 1.5cm of spacers, and I had my stem up about 1cm over the locknut, plus I want the bar a little bit higher than it was when I set up the bike originally. This makes for about 4cm of spacers. In my book, running your stem up a flagpole like that is well on the way to buying one of those Spenco "full diaper" gel pads for the seat. Not at all moto.
    Still, I don't think I'd buy a new (newly made) bike with a threaded fork. And I only recently decided that I would run threadless at all. I crabbed about them when they came out. Thought they were somehow part of The Great Shimano Conspiracy. (You know; the unspoken goal of the one piece component group that bolts onto the side of the bike as a unit and must be replaced entirely when the middle chainring wears out. Complete incompatibility with all other makers componentry. Plastic ratchey spirograph gears in the shifters that break into pieces when shifted for the 317th time .... ) Not fair minded on my part, but I was a hater.
    Reputation: chefmiguel's Avatar
    Ladies and gentlemen I present to you the Lewis Black of VRC.
    Just kidding Jack.
    -Schmitty-
    First thing that came into my head when I saw this thread. Even the low end Bridgestones had a more refined fork.
    Too many bikes, not enough time.
    I thought I would bump this thread... I prefer threaded headsets. Its a pain in the ass when a threadless tube is cut too short.
    25-yr old Retrogrouch
    Oct 2007
    Those pics from Frostbike?
    Keep the Rubber Side Down!
    Wanted: Judy FSX decals
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I will never understand why people clamp nicely painted and thin frame tubes in a repair stand
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    John Galt
    Reputation: cegrover's Avatar
    Quote Originally Posted by wv_bob
    It's usually because they wish to repair or display the bike.
    Quote Originally Posted by Slimpee
    Seattle bike expo
    Quote Originally Posted by cegrover
    That's what the seat post is for. That's right, using it to hold up the saddle was just an unexpected side effect.
    gobsmacked Moderator
    I gave Aemmer some grief about that and forgot that early clamps couldn't fit certain sized seatposts.
    Dec 2009
    Has anyone tried to run this bike (or an XO-1) with Drop Bars or is that sacrilegious?
    Quote Originally Posted by wirelessness View Post
    Excellente thread revival. I like it. sacrilegious? Hell no! Run whatever you want! Even the XO-2 came specced with drops.
    Here you go:
    <a href="http://www.flickr.com/photos/26117248@N03/5930336421/" title="Gene on the XOXO by handsomecycles, on Flickr"><img src="http://farm7.static.flickr.com/6001/5930336421_6d2e22e43d.jpg" width="500" height="500" alt="Gene on the XOXO"></a>
    That's Gene-O, owner of One On One Bikes and former pro Bridgestone racer. He recently raced the XOXO and had great things to say about the bike...
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Quote Originally Posted by McFlyMpls View Post
    Got an article or review you would like to share? I really want to find a 26" from the XO series for commuting, if I ever get room for one in the collection. Not so sure about the XOXO....
    Quote Originally Posted by umarth View Post
    I haven't seen an article yet, that's just what the Handsome guys said. If anyone is really curious about it, I would just call up Gene O at One On One and ask him about it.
    Reputation: mainlyfats's Avatar
    http://www.allhailtheblackmarket.com...k_23.html#more
    Dec 2009
    It just seems like a no-brainer to get this bike. Set up the way I want it with Noodle drop bars, Sugino XD2 Cranks, and Selle Anatomica Saddle for $1675. That's about $1100 less than the Rivendell Sam Hillborne I have been eyeing.
    Reputation: chris chicago's Avatar
    is the geometry comparable to a sam hillborn?
    Thanks homey. I just picked up a Bontrager (probably Trek made, I haven't done the research yet) so I'll pretend it covers the bases.
    Reputation: iamkeith's Avatar
    Feb 2010
    I ran mine with drops for a long time, when it was the only "road" bike I owned. I recentlly put the moustaches back on for the sake of variety and historical accuracy... and to help justify owning another bike. But I much prefered the drop bars. There are two other XO-1s used as daily riders in my little town, and they both run drops as well.
    Here's mine with drops:
    Attached Thumbnails Attached Thumbnails handsome retro vintage xoxo-xo-drops.jpg
    We still hang bike thieves in Wyoming [Pedal House]
    I set up my new XOXO similarly to those in the photos above (2X9 drivertrain, bar-end shifters, canti brakes, etc.), excepting that I went with a drop bar (Salsa Bell Lap), rather than a moustache bar.
    It's a great gravel/dirt road and rail-trail bike. Lots of fun to ride. Looks nice. I can't see how you could go wrong getting one. I think you will like it.
    Dale in Missouri
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by Dale Brigham View Post
    Dale in Missouri
    How about a pic?
    A garage full of steel frames means happiness.
    Dale in Missouri
    +1 on a picture of this setup. This sounds exactly like how I've setup the imaginary one I'm building up in my head, which I may have to make real sometime soon....
    Quote Originally Posted by jtill View Post
    I will see if my wife will help me take a pic of the aforementioned XOXO and post it. I am a 55 yr. old doofus who barely can make the internet tubes work on my computer. My wife says if I am good, she will help me out. She's the smart one, and, I guess, the good looking one, in the outfit. Will do my best, fellows!
    Regardless, the XOXO is a darn nice bike, and the Handsome folks seem likewise tres amiable.
    Dale in Moozoorah
    I can't seem to stop myself from ordering a XOXO. I have a complete XT groupo from a 94 Blizzard that is looking for a home.
    Oct 2011
    I have the 700c version of the XOXO....the Devil. Same basic geometry with some tweaks to make it 700c. The Devil also has 4130 cro-mo instead of the fancy Reynolds tubing the XOXO is built from so it's a little heavier. I've got it set up with 3 x 9 drivetrain and V-brakes. It's a very nice riding bike, very smooth. Sheldon Brown described the XO series as "fast, sporty, urban street machines" and that's a pretty good descriptor.
    It's pictured with 40mm Schwalbe Duremes and those make for a very comfortable ride but I actually prefer 32mm Vittoria Randonneur (now Voyager) Hypers.
    Very nice. I prefer the XOXO because of the paint (I'm a fan of B'stone), but I think that the 700c wheels would be nicer.
    Question for you all on XO sizing, in my MB1s I always ride the 46cm as I feel the 49 a bit too big for my liking. What size XO should I be looking for?
    Oct 2011
    Quote Originally Posted by laffeaux View Post
    I agree! For a bike, orange is MUCH better than blue. However, I'm going to powdercoat this sucker black this Winter or next Spring.
