Results 1 to 8 of 8
    Reputation: dRjOn's Avatar
    grove hot rod cranks reissued?
    am i right these cranks are being 're-made'? any info would be appreciated.
    Thumbs Up!
    Reputation: J Ro's Avatar
    Check out Rody's blog.
    http://groovycycleworks.blogspot.com...s-in-haus.html
    He shows a pic of Aaron Grove's jump bike with a set that where made to work with a Shimano set up. I'm sure Rody could make you a set if you need one.
    "Everyone has a plan 'till they get punched in the mouth"
    Mike Tyson
    bonked
    Reputation: IF52's Avatar
    Quote Originally Posted by dRjOn
    That's the rumor at least. Ready Rody's blog. Actually, if you look at the olive polka dot bike in his most recent entry (9 May 2008) you will see a set on that bike too.
    Quote Originally Posted by banks
    That is one big f'n dude!
    Yes I am!
    Reputation: Hand/of/Midas's Avatar
    Quote Originally Posted by J Ro
    what do you mean a shimano setup,
    thats a Fit chainring(BMX), looks like its another 2-piece bmx crank. i saw these before and wanted more info on them.
    Dumpster Diver
    Reputation: YETIFIED's Avatar
    May 2005
    Quote Originally Posted by Hand/of/Midas
    Shimano outboard bottom bracket.
    Stuart
    wanted: TA Chainrings, FUNK Big Fork, Bullseye Cranks 176mm,
    bonked
    Well, the story goes that Grove came up with the design in the 70s when he was designing for Titron, which indeed made BMX parts. The concept was copied and modified by Roger Durham for his Bullseye cranks. Grove sold his version for mtn bike in the early 90s and now is maybe going to start making them again.
    Yes I am!
    Hey guys,
    so sorry to keep everyone in the dark, but had to work out some final details first
    All the info you desire is here...
    http://groovycycleworks.blogspot.com...-has-come.html
    I'm pretty excited, looking forward to seeing these on the market again
    cheers,
    rody
    As requested by the MTBR gods, I am the voice of Groovy Cycleworks, check it out... http://www.groovycycleworks.com
    horseman
    hot rods
    I still have original matching hot rods on my Grove Assault. It still sees occasional duty. I have replaced bearings over the years, but the cups are relatively soft and locating bearings again seems like a project. But... If you can just use an XT external bearing setup...? Is that what Grove intends? Replacement "collars" for spacing?
