got a frame the other day that uses full length housing for the front derailleur, the cable gets pinched down at the bottom bracket shell, what in the heck am i lookin for?
trek also used that style which is the bike pictured above
you should be able to make any top pull front derailleur will work that is the appropiate clamp diameter.
other than that a down pull front derailleur with the barrel adjuster and mounting hardware that is used on a side pull brake will work if installed where the cable anchor bolt normally goes. I have done this before but no longer have the bike to show. if you want pictures of the pieces let me know
Yeah, that's a shimano adapater to turn a bottom pull derailleur into a top pull. I looked for a while to find one, only to source it at my LBS. It's just a small plate. Would be pretty easy to make at home if you can't find the shimano part.
Like someone else said above, just find some old sidepull road bike brakes. The cable stop they use will thread right into the FD cable attachment point.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
