Results 1 to 23 of 23
    Frame Mounted Pumps.
    I did a search and couldn't find a good VRC thread.
    So what brand of pumps were used back in the day? What considerations does one need to keep in mind when looking for a good VRC pump for a MTB. Thanks!!
    Andrew
    Feb 2005
    Mt. Zefal was always what I ran.
    A little later the Blackburn Mammoth Mtn.
    But before the Mt. Zefal, pretty sure it was just a silver, OG Zefal....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Sneaker man
    Reputation: mik_git's Avatar
    I ran a Zefal frame pump to start, then a mini double shot for a good long while.
    All the gear and no idea.
    gobsmacked Moderator
    Are you asking about the frame pump that fit the pump peg? Silca made some of those. Zefal has also been around for awhile. I had a zefal that I used for all my flats to and from school so I have bad memories of those.
    Ooohhhh. Everybody typing at once.
    This is what I had in mind (check link below). Mounted either in front of or behind the down tube. I had one on my school bike too back in the early 90's but I have no idea what kind it was.
    MOMBAT: 1984 Mountain Goat Whiskeytown Racer
    Feb 2005
    That'd be a Silca, work fine, look cool, plastic.
    The Zefals were aluminum, so possibly more durable, but otherwise, the Silca is the more "classic" model I suppose.
    GOB, simultaneous typing is a state oft discussed but seldom reached in real life!
    - FrostyStruthers
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Back in the day (and now): Mt. Zefal
    -eric-
    http://www.rumpfy.com
    Schipperkes are cool.
    Reputation: banks's Avatar
    Zefal HPX1 or HPX2
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Team Brooklyn
    Reputation: CCMDoc's Avatar
    Yellow or pink Mt. Zefal.
    Gunmetal gray Mt. Zefal too - but not as cool.
    Wanted: more of the same ... but different
    Reputation: chefmiguel's Avatar
    Rhode Gear which used rubber straps, Zefal was next, think there was a Planet Bike but found happiness in Blackburn Mammouth Mountain. Still have it.
    Technology dragass
    Reputation: tductape's Avatar
    I think the goal in the early days was to get a Silca painted to match with a Campagnolo head.
    My favorite is a Blackburn that just keeps working.
    Seek: Koski Trailmaster. Breezer Series 2 or 3. Cunningham Racer.
    Team Brooklyn
    Show off!
    slower than you
    Reputation: rockychrysler's Avatar
    Aug 2003
    ode to mt zefal
    mt. zefal. hands down, the very best, most reliable, only truly field serviceable pump ever. i feel about this pump the way charleton heston felt about his guns. i've carried one on every mountain bike ride i've ever been on. still do to this day. have enough of them in my back-stock bins to keep at least one working pump in my pack for probably the next 100 years.
    "May your trails be winding, lonesome, dangerous, leading to the most amazing view." - Ed Abbey
    http://rockychrysler.com/
    Quote Originally Posted by banks View Post
    Zefal HPX1 or HPX2
    Still the best frame pump made. I still have two. Blows the Mt Zefal away, but then again I never liked that garbage. Make sure you use a Jandd Pump Strap so you don't lose it.
    slower than you
    Aug 2003
    Quote Originally Posted by AKamp View Post
    I prolly have every color Jaand strap ever made. your opinion of the mt zefal makes me sad, akamp.
    Quote Originally Posted by rockychrysler View Post
    The Mt Zefal always gets dented when mounted behind the seat tube where pumps belong on mountain bikes. At least mountain bike without super short stays that people think they need. Also I never liked fighting the spring of the Mt Zefal, you don't have to do that with the HPX
    slower than you
    Aug 2003
    but you can't take the HPX to bits in 30 seconds, spit on the rubber gasket, and bring it back to life, now can you? HPXs are all glued together or something. zero field serviceability. tons of planned obsolescence.
    only the mt. zefal can be resurrected on the fly with spit (or nose grease) and rebuilt annually for a thousand years with franken-parts.
    So there's that.
    Reputation: KDXdog's Avatar
    Mt Zefal fan, still have one in black, and white. Both still work.
    Had an old fluorescent green one to match my old Monster fat. Hmm, maybe I painted a white one...
    Also have the mt zefal II, the skinny grey plastic one. Yes, that also still works.
    AND an old black Zefal MP on my road bike, yes, also still works!
    So there's that.
    Sure you can. Completely field servicable except for the end of the handle that locks the spring out. Worst case is you have a Zefal HP (basically the road version of the Mt Zefal) and have to fight the spring just a little. Plus I have never seen one fail but I am sure that it does happen. Everything else screws together. The head takes the same parts as the Mt Zefal. So this planned obsolescense so far continues to work for me on a 25 year old pump.
    Plus I did have one fail when I broke it across the nose of a Rottweiler.
    After remembering I used a frame pump in school, I looked in my parts bin and sure enough there was, my old Zefal hp. A quick trip to my favorite bike shop yielded an umbrella clamp out of THEIR parts bin. Thanks for the input all.
    Andrew
    Found my mt zefal from school. Still works. The solibloc lives inside my seattube.
    My hp has something loose in it. Not sure I want to take it apart and have everything spring out of place.
    slower than you
    Aug 2003
    Oh.
    Nevermind.
  1. Need a frame mounted pouch, which one?
    By MTFATBIKER in forum Fat bikes
    Last Post: 05-14-2015, 06:24 PM
  2. Replies: 4
    Last Post: 12-04-2014, 09:30 PM
  3. frame mounted accessories?
    By Tama68 in forum General Discussion
    Last Post: 03-09-2014, 01:04 PM
  4. Frame mounted bash guard for XX1 Chainring
    By onetothepowerofn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-12-2012, 02:57 AM
  5. Rear mounted sidestand for disc frame..
    By DougGuy in forum Cannondale
    Last Post: 02-20-2011, 09:16 AM
