    Reputation: geckocycles's Avatar
    Found a few spindles, CK, McMahann, Actiontec
    The ones on the left are CK SS ones. The one with the raised center is solid. I'm pretty sure only a couple of these were made.
    McMahann Ty's on right.
    Spacer I made for press on sleeve for my bikes.
    Broken Actiontec from 87? I broke 2 of those. I also have an early broken MRC too. After consulting with CK and new design change shown here. Never had an issue with the MRC spindles after that.
    [SIGPIC]http://www.geckocycles.com[/SIGPIC]
    There is but one rule in life. "First one to the finish line wins!"
    VVA
    Team Brooklyn
    Reputation: CCMDoc's Avatar
    Cool!
    Never broke a B.B. spindle - but I weighed only 126lbs back then.
    Glad you helped improve the design considering the increase in Earth’s gravitational pull and thus my apparent weight.
    Wanted: more of the same ... but different
    Ken-
    Which of those spindles would have been used on your Y file bikes?
    I'll take one if you got it.
    Quote Originally Posted by zygote2k View Post
    Ken-
    For the most part Y bikes used threaded BB of your choice.
    If you got a press in BB on a any bike other than a Genesis, it used 125mm spindles. Special order ones used the MRC 125mm ones pictured on right. Genesis used 119mm ones. These worked well for cranks of the period for the most part.
    Email me
    VVA
  1. 39t - Actiontec
    By aprinslo1 in forum 29er Bikes
    Last Post: 10-04-2014, 12:34 PM
  2. How to shift to big ActionTec ring?
    By russmcb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2011, 01:27 PM
  3. ActionTec Ti 36T COG correct install direction ?
    By magpies14 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2011, 02:13 AM
  4. Replies: 9
    Last Post: 04-03-2011, 05:45 PM
  5. best gear ratios ever - ActionTec
    By CaveGiant in forum 29er Bikes
    Last Post: 02-07-2011, 11:22 PM
