Results 1 to 18 of 18
    PVGNA PRO PATRIA
    Reputation: NslrPrtn's Avatar
    Fork for a '96 Ti Nukeproof?
    I am in the process of building up a large Nukeproof and the fork is the last part of the build needed. I really want something reliable and easy to work on. So much so, I am considering a Noleen/Girvin linkage fork with a Risse shock. Any other suggestions?
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    What size headtube? 1 1/8", lots of options. 1", slightly more difficult, but still options.
    -eric-
    http://www.rumpfy.com
    Love the linkage forks but I also have a soft spot for Marzocchi's. They just last & are amazing forks & super easy to tune and work on. A nice set of early 96-97 Z1's or Z2's would be great depending on what travel the bike was made for or you're looking for.
    Reputation: ameybrook's Avatar
    Judy FSX
    Why would you own 100 Yugos when you could own 1 Porsche? - Rumpfy
    PVGNA PRO PATRIA
    Quote Originally Posted by Rumpfy View Post
    Sorry...its a 1 1/8" tube and a 80mm frame.
    PVGNA PRO PATRIA
    Quote Originally Posted by ameybrook View Post
    Judy FSX
    Sweet but a little too $$. Is that yours for sale in fleabay?
    Nope. How much are you looking to spend?
    PVGNA PRO PATRIA
    <$250
    You ought to be able to get into an FSX off ebay for less than that.
    PVGNA PRO PATRIA
    I'll keep an eye out...the current listing must be a bit high. Thanks
    PVGNA PRO PATRIA
    OK, that seems like a more realistic price. Parts and service procedures available for these?
    It's just a fancy Rock Shox Judy which is the easiest fork to work on. Replacement elastomers and springs are available as well as dampers. Upgrade to the Englund air kit to essentially make it an early SID.
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    I thought one of the problem with the FSXs was the bonded in bushings? Are those harder to service?
    I can't imagine that would be a problem, though - not like i've ever seen a worn out pair of Judys...
    VRC Illuminati
    Quote Originally Posted by NslrPrtn View Post
    Sky is the limit then. No shortage of great 1 1/8" forks with 80mm of travel. Find a Fox Float 80 for best results (IMHO).
    -eric-
    PVGNA PRO PATRIA
    I am hoping to narrow it down a little more. What fork from '95 to '02 that has a 1.125 steerer, posts, around 80mm of travel, works well, has available parts and can be serviced easily?
    Feb 2010
    Don't limit yourself to '95 to '02 unless you are doing some sort of period correct resto. There are many great v-brake forks that can be spaced down easily to 80mm including the newer dual-air 32mm SIDs, Manitou R7, Magura Durin and as mentioned by Rumpfy the Fox float forks. You can often get the 2011 or 2012 Manitou R7s with v-brake bosses for less than $250 new. Any fork in the '95 to '02 period will be quite inferior to something newer and parts availability will always be an issue. If you're after a new fork because you ride, the go newer.
    Sneaker man
    Reputation: mik_git's Avatar
    yep, I got some 2012 r7's this year for my xizang, work really well, and didn't cost too much.
    All the gear and no idea.
  1. Nukeproof goes 27.5
    By gvs_nz in forum 27.5
    Last Post: 08-14-2013, 06:43 AM
  2. Nukeproof Scalp
    By iRace559 in forum Downhill - Freeride
    Last Post: 09-04-2012, 08:48 PM
  3. nukeproof hubs
    By nvphatty in forum Fat bikes
    Last Post: 03-19-2012, 06:59 PM
  4. Nukeproof pads
    By PissedOffCil in forum Brake Time
    Last Post: 12-20-2011, 12:08 PM
  5. CRC Nukeproof
    By banano in forum Intense
    Last Post: 01-11-2011, 04:21 PM
