Results 1 to 9 of 9
    Fisher CR7 Bottom Bracket Info
    Just managed to get myself one of these after wanting one back in the day
    Seem to remember issues with the Bottom bracket bearings, from memory they were a press fit bearing with a cir-clip to retain them?
    I have as yet to recieve the frame but I am keen to replace the BB bearings when it arrives, does anybody have any infomation on doing this or the spec for the bearings?
    Any help greatfully recieved
    Attached Thumbnails Attached Thumbnails Fisher CR7 Bottom Bracket Info-side.jpg
    Bird watcher
    Reputation: ckevlar's Avatar
    Feb 2005
    pull the circlips out. and tap the spindle with a block of wood between the spindle and your hammer. When you get one side out use the spindle the same way for the other bearing. This is if the locktite holding the bearings is still doing its job. The bearings are 6003 sized. This guy below has great deals on Nachi brand bearings. These are not cheap bearings, These are high grade Japanese bearings. Same size as the Klein Attitude BTW.
    http://cgi.ebay.com/6003-2RS-17x35x1...item53d5b25d7a
    Clean the bb shell. coat the seating surface with a lil red locktite and pop it all back together. Be careful not to poke the bearings seals with the pin tool when putting the clips back in.
    Nice bike now send me that suntour seatpost as payment.
    illuminaughty
    Reputation: da'HOOV's Avatar
    Jan 2009
    not many of these around
    Just saw this today, I didn't pick it up, too big at 19" but it could clean up pretty nicely.
    Attached Thumbnails Attached Thumbnails Fisher CR7 Bottom Bracket Info-cr7.jpg
    Neo-Retro Forever
    idoru - you got the second best year (1989), and second best color in CR-7 history, in my opinion.
    Attached Thumbnails Attached Thumbnails Fisher CR7 Bottom Bracket Info-7557331040_d61014e2e4_c.jpg
    Nov 2012
    I'm posting here because I don't know anybody in real life that knows or cares about the CR-7. I just bought a red and black one off of Craigslist for $75 bucks, should be a cool project bike.
    Should be finished in about a week. Ill post pics then. Havent ridden much but I like it.
    " width="549">
    Seeking MB-2 Fork (19.3), Ritchey FD post silver 26.8
    Quote Originally Posted by ckevlar View Post
    6003 2RS 17x35x10mm SEALED Deep Groove Ball Bearings | eBay
    just checkin to see if that red loctite is correct...green is the bearing stuff that I alwaysed used on my fishers BITD...it was specifically formulated for press-fit bearings...make sure you use the correct stuff or it can make it real difficult to remove...just an FYI.
    And remember to press the bearing in from the outter diameter (not the spindle) as it presses into the shell(looser on the spindle)...if you push anywhere else, you can ruin the bearing.
    Nov 2012
    Cr-7 BB
    Quote Originally Posted by syklystt View Post
    Is this what we're looking at?
    ooowww broken spindles suck....my setup didnt have the stepped shaft (and no weak point like these shafts)..it was smooth and had locking colllars but essentially was the same. The bottom bracket shell should be machined with stops for the bearings or they just sit flat to the outside of the bb shell. This keeps the spindle ends in the correct position in relatin to the bike frame so your chainline is correct. With the smooth spindle, you can adjust that chainline (which can be good and bad)..you can find smooth shfts and collars if you want (i had a Ti action tec spindle in my bike). I see them for cook bros and Kliens all the time..just gotta keep an eye out for them but it looks like you already got a replacement.
