Results 1 to 9 of 9
    Highly Ir-regular
    Do Ceramic rim take special brake pads ????
    I took the ceramic rims off my GT and replaced them with machined rims. I left the XTR V-brakes on and although they stop on a DIME, they sound awful. Not squealing, more of a grinding sound. The pads are nearly new. Are there special pads for Ceramic rims and if so, will they work with or damage machined rims?
    "I won't sell these for a penny less than $60.00. I'd rather put 'em back on the shelf and keep 'em! "
    He be a moose too.
    Reputation: pinguwin's Avatar
    There are special pads for ceramic rims. You should only use the proper pads on each given rim type. Yes, you can use ceramic pads on a regular rim but it's not recommended.
    I have one set of wheels built up with ceramic rims and recently picked up a set of NOS ceramic Mavic 231s.
    Schipperkes are cool.
    Reputation: banks's Avatar
    You can buy Shimano XTR replacemnt cartridge pads in Ceramic compounds.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Reputation: laffeaux's Avatar
    The "ceramic only" pads are made of a harder compound and probably will wear down your non-ceramic rims quicker. Replacing the pads is a good idea.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Highly Ir-regular
    thanx..
    Quote Originally Posted by laffeaux
    That's what I thought the answer would be. I'm switching to XT brakes that have normal pads. The XTR's are going bye bye. Great brakes but more sellable than functional for my use
    Not a regular
    Quote Originally Posted by stan4bikes
    XT, when XTR just won't do.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Why not just put some Alivio's on there?
    (green Kool Stops are also a ceramic rim brake pad option)
    -eric-
    http://www.rumpfy.com
    Highly Ir-regular
    hmmmmm?
    Quote Originally Posted by Rumpfy
    ...who's instigating now? Or do you think Alivios are comparable to XT's?
    VRC Illuminati
    What, I gave you info too.
    -eric-
