Results 1 to 7 of 7
    Reputation: mrjustin007's Avatar
    Critical Racing Gatling Gun Brakes
    I found a set of Critical Racing Gatling Gun brakes but they do not have the spring and cap. Is there anything I can use as a subsititute?
    Jan 2005
    Pics?
    Digging around some of the local LBS' I found these caps, but they don't fit over the bushing. Are they supposed to have a gap?
    Reputation: Inigo Montoya's Avatar
    aren't these caramba canti breaks?
    I've finally had time to get back to these brakes. Could I use Pauls springs and caps? As long as the cap holds the spring in place and the spring moves the arm in the right direction, it should work, right?
    WTB: Bontrager Comp Fork & Syncros metal top cap
    Hit The Road Cyclery
    Reputation: -Anomie-'s Avatar
    Jan 2005
    If it doesn't bind up the brake arm when you tighten the mounting bolt and everything else lines up, then the Paul's caps should work. Just make sure the caps/springs hold the arms against the back of the canti stud and that the arm doesn't slide back and forth on the stud.
    Cool, thanks for the advice.
