Results 1 to 25 of 25
    Reputation: jack_read's Avatar
    Converting 1" head tube to take a 1 1/8" steerer- question
    Hi,
    I'm hoping somebody can either tell me I'm being foolish or ingenious. It's likely to be the former...
    I have a '95 Independent Fabrication Steel Deluxe with a 1" head tube. I'd like to be able to install a fork with a 1 1/8" steerer. (I know that changing the fork will slacken the geometry and change the handling characteristics and I'm good with that- I've made similar alterations to a '96 Voodoo that I have).
    The OD of the head tube is 33.5mm. Let's say I found a 1 1/8" headset with an ID of the cup (where it presses into the frame) of 33.5mm. I could install the cups *outside* the head tube and run a 1 1/8" fork. It would look funny, but I could paint the cups orange to match the bike, I suppose.
    The question is- has anyone tried this? Am I looking for trouble in the form of an unsafe modification or damaging my frame?
    Thanks for any input you might have.
    Jack
    Jack
    '95 Independent Fabrication Deluxe
    '96 Voodoo Bizango
    '08 Rocky Mountain Solo CXR Team
    '92 Trek 930 SHX
    Sneaker man
    Reputation: mik_git's Avatar
    I would have thought the the cups press into the frame and then are stopped by the cup butting up against the frame, if you put them on the outside then 1) any force applied may push the cups further down (or up) the head tube. 2) don't the cups come in the size so you can just fit the steerer inside them? Usually?
    But thats just me thinking, could be totally wrong.
    Hey mik_git, excellent point about the cups getting pressed further onto the tube. That's a deal killer right there. Thanks for saving me the trouble! :-)
    Jack
    '96 Voodoo Bizango
    '92 Trek 930 SHX
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Someone here had reamed the headtube of an old Schwinn klunker and put an 1-1/8 fork on it. That thinned the head tube so probably not an ideal solution and probably not something you want to do to a nice bike either. Just throwing it out there since I remembered it.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    defender of bad taste
    Nov 2007
    It wouldn't work, or be safe, for a slew of reasons, but why not find yourself a reputable frame builder and have the head tube replaced and the head angle modified to suit whatever fork you wish to run? IF would probably do it themselves?
    5 is the old new black; 6 is the new new black...
    Certified Bike Junkie
    Reputation: muddybuddy's Avatar
    I know some some people have been able to fit 1-1/8" forks to 1" frames by carefully mixing and matching 1" frame cups with 1-1/8 crown race and top parts. If this is possible, it makes me wonder why no one makes a headset for this application.
    Need: McMahon brake for roller cam mounts, Mountain Goat fork.
    Sneaker man
    don't white brothers still do a 1" 80mm fork?
    muddybuddy- that's an interesting thought. I'll dig through my parts bins and see if I can rig up something safe and workable.
    OTOH, I'm not far at all from IF. I'm going to give them a call and see what it would cost.
    Jack
    '96 Voodoo Bizango
    '92 Trek 930 SHX
    Brain fart. Sorry. The one I've seen were on klunker type frames with 1" BMX headset with larger cup skirts than standard 1". Probably won't work with standard 1" head tube.
    Reputation: Williwoods's Avatar
    I would just run a 1" fork. either rigid or a franken sid.
    Stokeless Asshat
    Reputation: jeff's Avatar
    Quote Originally Posted by wv_bob View Post
    That was me. I've also mixed and matched parts to fit 1 1/8" to BMX standard but have never had success otherwise.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Sneaker man
    **hmmm totally OT, wonder why my post is waay up there at #7 rather than at #11... some sort of time zone delorean situation...?
    Have a look a on the BMX Museum, I think its been done before......
    underachiever
    Reputation: misterdangerpants's Avatar
    Oct 2007
    Quote Originally Posted by mik_git View Post
    Yup. 2011 Loop.
    Attachment 618730
    Dec 2005
    eBay....I looked at a several 1" forks over the course of two months to find this marzocchi....a bit more travel then I needed, but a very nice fork... My first complete new build project...just finished
    Converting 1" head tube to take a 1 1/8" steerer- question-img_5657.jpg
    Reputation: Hardguy's Avatar
    Nov 2006
    Nice frame but it looks like a 120mm travel fork. I think it's about 40mm too long. Kinda jacks up the front end too much. How's the ride with that fork? Reminds me of this a bit...
    Attached Thumbnails Attached Thumbnails Converting 1" head tube to take a 1 1/8" steerer- question-chopperiia.jpg
    Dec 2005
    It is 100/105 mm....80 would have been ideal. With some weight on the fork, it drops down a bit....sag. Modern forks are amazing.....no issues with the handling.
    taste death, live life.
    Reputation: super_stein's Avatar
    Quote Originally Posted by misterdangerpants View Post
    Yup. 2011 Loop.
    Attachment 618730
    How do you like the 2.4 MK Supersonics? I use the 2.2's and have been very pleased. Did you happen to weigh them (I know - wrong question for the VRC forum)?
    Aug 2013
    I found a conversion kit if the Inside measurement of the head tube is 32mm. Genuine Bicycle Produsts: Parts and Accesories.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: Converting 1" head tube to take a 1 1/8" steerer- question
    Quote Originally Posted by thatjohnguy View Post
    One of those showed up in my mailbox yesterday. I only had a minute to look it over but it looks good so far.
    No moss...
    Show us some pics of it through assembly and hopefully on to successful installation. This would be very interesting. Thinking about spending the $45 bucks on one just for the ability to try it out. This is a good thread to bring back from the dead.
    The White Jeff W
    Quote Originally Posted by datmony View Post
    Will do. It will be Thursday at the soonest before I get a chance to do it. To be honest I don't even know for sure that it will fit my bike. I bought it on the assumption that it would. If it doesn't it will be for sale!
    No moss...
    Reputation: az45's Avatar
    I turned down some 1-1/8 XT cups to fit a Schwinn frame a couple of years ago so I could use a Manitou threadless fork. It worked fine, but it was a cruiser that didn't take much abuse. If you're using hard it I'd bet they'd crack.
    the Genuine part looks like the way to go.
    Like most things, it looked cool but was more of a pain in the a$$ than it was worth.
    Jeff
    Www.upr.com
    I like that these are steel, you can get away with a pretty thin wall on good steel without it cracking. Really hope it works for you Jeff, going to try to measure a few frames I have around to see if they would be a candidate. Not really an issue as I have found quite a few 1" forks that are still working good but would be nice to have additional options.
    The White Jeff W
    There ya go... Retro Ryder klunker headset install
    No moss...
  1. converting 1" steerer to 1 1/8"
    By rguy in forum General Discussion
    Last Post: 04-24-2011, 07:22 PM
  2. Thomson X4 Steerer Tube Clamp "Window"
    By Raybum in forum General Discussion
    Last Post: 08-06-2010, 11:03 AM
  3. Converting 1 1/4" head tube to 1 1/8".
    By Braulio in forum Vintage, Retro, Classic
    Last Post: 09-14-2009, 08:06 PM
  4. 5" headtube and 7.5" Steerer tube...can it work?
    By shockfinder in forum Tooltime
    Last Post: 09-04-2009, 08:16 AM
  5. 7.5" Steerer and a 5" head tube?
    By shockfinder in forum Shocks and Suspension
    Last Post: 04-28-2009, 12:25 PM
Members who have read this thread: 7
