Results 1 to 11 of 11
    Converting 1 1/4 threaded to threadless-anyone make a converter?
    Howdy,
    I have a Manitou FS that has a threaded fork with a long ATAC quill stem.
    I have a Manitou threadless stem that I would like to use.
    I know Profile makes a 1 1/8th and 1" converter but no 1 1/4.
    Does anyone know if there is another mfg that makes something similar?
    Nitto MT Column SM1143
    The Crazy Cat Lady of VRC
    Reputation: eastcoaststeve's Avatar
    Plans for old stem?
    Steve
    Certified Bike Junkie
    Reputation: muddybuddy's Avatar
    That would work, but if the threadless stem is also 1-1/4" you'll need a shim between the adapter and the stem.
    Need: McMahon brake for roller cam mounts, Mountain Goat fork.
    Sergeant Spandex
    Reputation: lewisfoto's Avatar
    Nov 2013
    Swap out the fork crown and steerer?
    Thanks, but the Threadless Stem is 1 1/4 as well so......I would have to shim the stem.
    Thought about replacing the crown and steerer but a am afraid to remove the headset and replace it. I can hear the "crack" in my nightmares.
    Steve, if I figure it out I will PM you.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Know any machinists? Making a shim for the Nitto mentioned above would not be too hard. I have made several for handlebars and stems.
    frog
    Reputation: mfh126's Avatar
    What kind of headset are you running? I assume not a King since it would be easy enough to leave the cups in the frame and just convert it to a threadless setup.
    Unless he wants to keep the fork with the threaded steerer, then the headset doesn't matter.
    He could swap the crown/steerer to a threadless one, and keep the fork.
    So, as luck would have it, the Manitou stem that I picked up is 1 1/8th, not 1 1/4th like I was told. What that means is, I ordered the Nitto column, installed it today and with the stem and it works perfect. It has a XT headset and would love to swap it but it scares me to think about taking it out and replacing it. I can just hear the cracking sound.
    Thanks for all the replies.
    I will post photos once it is done.
  1. threaded to threadless?
    By sbarnhart in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2013, 07:27 AM
  2. Converting 1" threaded to 1" threadless
    By Thumpy69 in forum General Discussion
    Last Post: 05-07-2013, 08:06 PM
  3. 1 1/8 threaded to 1 1/8 Threadless?
    By CharleyGnarlyP290 in forum Shocks and Suspension
    Last Post: 02-11-2012, 10:04 PM
  4. Threadless or threaded fork
    By jackspade in forum Singlespeed
    Last Post: 06-20-2011, 06:56 PM
  5. Threaded fork with threadless headset?
    By jesseb55 in forum Shocks and Suspension
    Last Post: 03-01-2011, 07:57 PM
