Results 1 to 6 of 6
    Nov 2006
    New question here. cassette mechanism on suntour xc pro 7spd hub: adjustable?
    I like thes old hubs, just reinjected the bearing grease, notice some play in freewheel mechanism, It looks adjustable for bearing play {these are not the actual axle bearings}, I just cant get the axle bearing race that holds on the freewheel mech to budge. is this adjustable, do I just buy fresh bearings to slightly reduce play or find another cassette mech? Thanks much in advance
    locked - time out
    Is it a cassette or a free wheel?
    Nov 2006
    It's a 7 speed cassette
    Not a regular
    It may be similar to freewheels that use a micro-shim system to adjust the bearings in the mechanism. You would have to totally disassemble the cassette shell from the inner race by removing a very hard to remove lock-ring. Unless, the play is detrimental, I'd leave it alone. Cassette bodies and freewheel bodies never seem "right" after going through that much disassembly and reassembly.
    mountaingoatcycles.com
    Reputation: First Flight's Avatar
    Quote Originally Posted by Mike Rose
    We have replacement free hub bodies @ http://www.firstflightbikes.com/wheels-r.htm
    Nov 2006
    Thanks much, I figured as much seeing the mechanism......Peace
