Results 1 to 12 of 12
    Best way to remove 30 year old grips?
    I just bought a Bullmoose bar for my 1984 Stumpjumper to replace the slingshot neck and bars. The original black foam grips are on the current bars, and if I can, I'd really like to reuse them. My question is, what would be the best way to remove them without damaging them?
    That would be fine, if I wasn't trying to reuse them on the Bullmoose bars.
    Oct 2007
    Peel up the grip on either end and with a squirt bottle, get some water between the grip and bar, twisting the grip work it around and it should come off.
    Oldest daughter doesn't ride.
    Feb 2010
    If you've got an air compresser then use the air duster nozzle to "float" them off. This is the easiest way to install / remove just about any grip.
    I Tried Them ALL... Moderator
    Reputation: Zachariah's Avatar
    Reuse 30 year old grip? Seriously?
    "The mind will quit....well before the body does"
    Thanks guys, both ideas sound good to me. I think the air blast idea will probably work best, I've seen it work, forgot all about that method. The Bullmoose bars really represent what the Stumpjumpers of my youth meant to me, I had an '83 and an '84. Both were stolen, the '84 in 1986 when the scumbag thief cracked open my Kryptonite lock. They both had the Bullmoose bars, so by swapping the slingshot stem and bars out, some warm feelings should return. In trying to keep all the original parts, I'm going to try and get the grips off carefully. 30 year old foam might not cooperate the way I need though. If not, I'll just get some current Specialized black rubber grips.
    ong
    ong is offline
    Warm soapy water really helps me get old grips off intact.
    Phobia of petting zoos.
    1. Wait for a rainy day.
    2. Go ride a technical descent in the rain.
    3. Grips will come loose as if by magic.
    It happened to me all the time until I started using lock on grips.
    Grumps
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Cut them off with a blade and throw them in the trash, Grab-On foam grips are still available.
    -eric-
    http://www.rumpfy.com
    I'm happy to say the grip transplant worked without any problems. I used the soap water method and they came off intact with just a little gentle twisting. The old foam is still nice and spongy. The bike is 100% original parts(except tires), so that's why I wanted to keep the grips. Replacing them with modern rubber Specialized grips was my back up plan. Too me a vintage Stumpjumper just doesn't look right unless it's got Bullmoose bars. Glory has been restored!
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Quote Originally Posted by Rumpfy View Post
    That's what I usually do.
    A garage full of steel frames means happiness.
    Windex between the grip and the bars works great for this, too.
  1. Help me remove these grips
    By husonfirst in forum General Discussion
    Last Post: 04-28-2013, 09:28 AM
  2. How do YOU remove grips from your bars?
    By Robbieisbobert in forum General Discussion
    Last Post: 04-26-2012, 09:41 AM
  3. How to remove handlebar grips
    By edesros168 in forum General Discussion
    Last Post: 04-03-2012, 03:59 AM
  4. How to remove non-lock on grips
    By csermonet in forum Downhill - Freeride
    Last Post: 10-30-2011, 06:43 AM
  5. Easiest way to remove old hand grips ?
    By Tidezealot in forum General Discussion
    Last Post: 06-06-2011, 11:50 PM
