Results 1 to 5 of 5
    Bent axl or bent hub?
    Just had the bearings replaced on both wheels and while I was mounting up the rear wheel yesterday and I noticed that the chain rings wobble slightly. Doesn't appear loose like the broken hub I experienced on my other bike. Just a slight wobble. Not noticeable when riding, but you can see it and hear it when the wheel spins freely.
    Something is bent. Please god not another rear hub issue
    Any ideas what it is?
    Reputation: chefmiguel's Avatar
    Don't panic all is well. Alot if not all cassette bodies have a wobble in them, nothing for you to worry about, go ride.
    Stokeless Asshat
    Reputation: jeff's Avatar
    What Miguel said. The cassette and free hub don't spin on the axle, they spin on the bearings. If it was an axle the wheel hop.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Reputation: sbsbiker's Avatar
    The cassette may not be totally seated onto the freewheel body, I would check to make sure it is tight, but as stated above, slight wobbles can be expected.
    Schipperkes are cool.
    Reputation: banks's Avatar
    Freewheels are infamous for the cogs not being 'true' while coasting.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
  1. bent rim:(
    By Rabbit7 in forum Passion
    Last Post: 09-11-2012, 06:37 PM
  2. Bent cog
    By Glynn Sluder in forum Singlespeed
    Last Post: 05-06-2012, 10:33 AM
  3. Bent rim
    By Koin in forum Wheels and Tires
    Last Post: 03-12-2012, 11:22 PM
  4. Bent my rim... need new ones.
    By polecats03 in forum Wheels and Tires
    Last Post: 08-18-2011, 07:52 PM
  5. how wet is too wet at bent creek?
    By grodo in forum North & South Carolina
    Last Post: 05-30-2011, 04:03 AM
