Results 1 to 17 of 17
Thread: Alloy Pulleys
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Alloy Pulleys
    Will any of the current 11T pulleys work on an 80's Deore or XT rear derailleur? I saw some on ebay that looked worth trying.
    http://cgi.ebay.com/6061-Jockey-Whee...item35af8dbfad
    Feb 2007
    those look like my Bullesyes
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    Forgive my ignorance, but do alloy pulleys can cause your chain to wear quicker? I know aluminum is softer than steel but it's also harder than plastic.
    Reputation: laffeaux's Avatar
    Quote Originally Posted by Sizzler
    I doubt they would cause any significant additional wear. Chain wear occurs mostly at the pin interface - cross chaining put the most stress on the chain. The pulleys aren't putting any real stress on the chain.
    However, if the upper pulley does not have some float, which some pulleys do not, it will degrade the shifting quite a bit.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    CS2
    CS2 is offline
    Still the question remains, will 11T pulleys work on a derailleur originally equipped with a 10T?
    Reputation: modifier's Avatar
    Quote Originally Posted by laffeaux
    Is this a typo? If you are saying that the alloy pulleys "have" float why is this? Are they not the same width or is it in the bearings?
    I've thought of going to alloy pulleys at times just for the bling. But if they don't work as well probably not worth it.
    Also do they make more noise?
    No it never stops hurting, but if you keep at it you can go faster.
    Klunker Kev`
    Reputation: MERK26's Avatar
    No typo, and he`s correct. Many of the alloy pulleys don`t work as well as the stock...
    Oh. I read it wrong and thought it was a double negative. He is saying that there needs to be float. Why is this? You would think that no float would be more precise.
    Reputation: crconsulting's Avatar
    When the plastic version wore out, we always replaced the top pulley's with the Dura Ace pulley's. They had float, the steel never wore out in mud and grime. They generally tend to last forever.
    I believe they had a later sealed ceramic bushing version too.
    This is the earlier steel bushed version:
    as far as 10t vs 11t
    http://forums.mtbr.com/showthread.ph...83611#poststop
    bonked
    Reputation: IF52's Avatar
    Quote Originally Posted by modifier
    the float allows the pulley to self align a bit after the shift. I think it helps prevent ghost shifting and cuts down on noise.
    Quote Originally Posted by banks
    That is one big f'n dude!
    Yes I am!
    VRC Hound
    Reputation: bushpig's Avatar
    Thats what Suntour thought...
    Quote Originally Posted by bushpig
    And I guess you are saying they were wrong? It's been a long time since I ran a Suntour derailleur. Actually it's been a while since I ran a Shimano except on my commuter bike that has an old 105 on it. I basically never looked back once I tried a Sram. Not saying the new Shim's aren't good, just no experience.
    CS2
    CS2 is offline
    Campy thought the same thing when they entered the indexed era. They thought wrong also. Unlike SunTour they're still in business.
    Reputation: Hardguy's Avatar
    Nov 2006
    On a '80s XT rear derailleur, get the 10 tooth ones. I put some 11 tooth pulleys on my '94 GT w/ LX rear derailleur w/ 10 tooth pulleys and the new chain kept skipping on me every few shifts. I asked the LBS mechanic and he told me to get some 10 tooth ones and the skipping went away instantly. I put the alloy 11 tooth pulleys on my '06 Epic and they replaced the shimano plastic one perfectly with no problem accept a tiny bit more noise. I guess if you're going to upgrade to alloy pulleys, better to go with the same amount of teeth of the stock pulleys.
    Hi.
    Reputation: jtmartino's Avatar
    Quote Originally Posted by CS2
    Yes, they should work fine. I have 11T alloy pulleys on 2 bikes that originally had 10T (XTR M952). No problems, but a bit noisier.
    Check out Toronto Cycle for better prices than eBay.
    defender of bad taste
    Nov 2007
    Shimano have allow a margin of error (they have their own name for it which I forget) in their indexed gearing systems. For the average rider this manifests itself as remarkably reliable shifting regardless of air temperature, contaminants and cable tension. Alloy pulleys look really great, but rarely work any where near as well as decent Shimano ones, the XT sealed units are pricey but worth the extra $$$.
    5 is the old new black; 6 is the new new black...
    CS2
    CS2 is offline
    Quote Originally Posted by mechagouki
    You can still get some of the XT upper pulleys NOS. Problem, like you said, is that they cost almost as much as derailleur and they're a wear part.
    I believe the Ultegra is the same as the XT upper pulley. Price is $14.95
    http://harriscyclery.net/product/shi...p6602-qc49.htm
    A cheaper alternative is the standard 10T Deore.
    http://harriscyclery.net/product/shi...p8350-qc49.htm
    Neither looks as good as the anodized version though.
