Results 1 to 6 of 6
    Jul 2013
    7 speed hub for a 90's Yo Eddy
    I'm looking to get back on my 90's Yo Eddy after years of neglect. I last put some more road-friendly tires on my original rims and would like to keep that option but also have a quick switch to off-road tires. Which means looking for a 2nd set of wheels.
    In looking for a new set of wheels, I'm realizing the obvious that the specs have moved on from my 7 speed rear hub.
    Basic question, would the 8/9/10 hubs today be of a compatible dimension for a old 7 speed cassette?
    Feb 2005
    Yes, you just need a spacer top take up the extra room left by the missing gear.
    8, 9, 10, share the same spacing, all will fit on the same hub.
    7 speed used 130mm spacing (as opposed to the modern 135), and was a narrower freehub body as well.
    So you may find the fit a bit tight on a new hub as well, but spreading it the 5mm with your hands during install shouldn't be too tough.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Quote Originally Posted by MendonCycleSmith View Post
    Back in the 90s, MTB hubs with 135mm width using narrower 7-speed casette body were fairly common. Shouldnt be hard to find one on e-bay or at a local bike co-op to swap if your current 7s hub is a 135mm width.
    I bet you hub is 130mm wide...
    Actually finding a 7 speed hub is really easy and cheap, what you really need is to find a rim of the exact same dimensions (can be a different brand/model), so you don't need to adjust the brakes every time you change wheels..
    Stokeless Asshat
    Reputation: jeff's Avatar
    90's Yo Eddy would be 135 no matter what the cog count.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Reputation: yo-Nate-y's Avatar
    Quote Originally Posted by jeff View Post
    x2
    It'll be 135mm not 130mm.
    Somec is like the digital Zunow
    And this: http://www.youtube.com/watch?v=JD5h3y0a9AU
  1. Big One Inch for my Yo Eddy?
    By Jeffva in forum Vintage, Retro, Classic
    Last Post: 10-18-2012, 09:30 PM
  2. Hard Eddy
    By 45ronin in forum Intense
    Last Post: 11-21-2011, 02:23 PM
  3. Yo Eddy on SF bay CL
    By TheMachinist in forum Vintage, Retro, Classic
    Last Post: 09-11-2011, 03:19 PM
  4. Oh Fast Eddy, are you hiding something?
    By norton55 in forum California - Norcal
    Last Post: 05-12-2011, 11:45 AM
  5. Fat Chance Yo Eddy 1993
    By Dhphat in forum Vintage, Retro, Classic
    Last Post: 01-16-2011, 10:03 AM
