Ok, now I know this never was a stout bike, but my parents bought it for me new back in 1993 and every time they stop by or I visit them, it seems like the first thing the ask me is "how's the bike" .
Anyway, I'm trying to upgrade it to an 8 speed rear (up from the stock 6 speed) and I've got all the parts procured, other than the rear derailleur. I'm not sure what 8 speed rear derailleur I need for this old-school bike. The stock unit is hooked around the axle stud, with a screw into the frame just to the left oft the axle. I've attached a photo.
What I need to know is whether or not I need some sort of adapter, or if there is a currently available 8 speed derailleur that will fit my frame.
It was fairly common to have this set up on lower end road bikes prior to the early 80s. That is an old school set up. Anyway, no higher end MTB derailler ever came with set up. You maybe able to try and use the integrated hanger with a newer derailler and see if it might somehow be made to work. Or better yet, try that one and see how it does with an 8-speed.
First off, thanks for the reply. Second, it is a lower-end bike.. Is there anyone who can give me pointers on how to mount a newer derailleur to this integrated hanger?
Maybe I'll try the old one, once I get everything including the shifters later this week, but I'd rather get a nicer (read newer) derailleur if I could.. Does anyone have experience with using a higher level gearset with a lower level derailleur?
You can order a bolt on hanger like the one that is built into your derailleur, however it will have a regular threaded hole so you can attach any derailleur to it. They cost about $10.
many deraillers came with adapter style derailler back in the day. your local bike shop should have a box of old deraillers and parts. most likely the piece you need it attatched to a derailler in that box. they'll probably just give it to you if you ask nicely.
Thanks guys. I'll get the adapter. I really want to replace the derailleur, since the spring in it is pretty weak.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
