Results 1 to 26 of 26
    1989-90 Mongoose IBOC Comp = Real MTB?
    Is my Mongoose considered a real MTB? I currently ride it at the local mountain trails in SoCal Santa Clarita area with varying terrains. Not extreme though - Tapia and Towsley Canyon.
    From what I know from scouring the Internet and looking at my bike - the specs:
    Tange Double Butted Chromoly 4130 Rigid Frame
    Chromo 4130 Straight Forks
    Shimano Equipped: EXAGE 500LX M500 Group; SG? crankset, STI shifters
    ARAYA RX-7 Rims
    Only thing replaced - tires and saddle.
    Real noob here and just started riding trails after 20 years of inactivity - so behind the times. I plan on riding this until disposable money becomes available for an upgrade - so will it last til then?
    Thanks for any info or answers.
    1990 Mongoose IBOC Series Comp - all original
    2010 Cannondale F5
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    yes most definitely a real mountain bike. The IBOC was short for International Bike of Champions based on the usage by the then teammates of John Tomac and someone else whose name has slipped my grasp. They were the true mountain bikes of the Mongoose line and while the comp had lower end components EXAGE and the like everything else should be more than competent for mountain biking a long time.
    You might want to consider getting some new brake pads as the originals are probably pretty dried out and you would probably get better performance out of new ones, alternately you could just sand the braking surface of them which will probably get you better performance.
    I would ride it until you get some thing new whenever that is then I would get a tensioner for the rear and make it a singlespeed for some a different riding experience. That frame should literally last forever, as long as it hasn't sat in a lake or the ocean since being put away.
    Try this: HTFU
    Thanks for the response.
    Nice to know that the Mongoose IBOC is legit when I ride and encounter riders with modern setups. It makes it easier to roll when you hear wise cracks about a 22 year old bike on the trail.
    Yeah about the brake pads - they will be replaced soon.
    Quote Originally Posted by rockcrusher View Post
    2010 Cannondale F5
    Master of the Face Plant
    You are riding full rigid. Anyone making jokes does not understand that learning to ride on a full rigid bike makes you a better rider. You have to learn to pick the right lines and it toughens you up. Not to mention that you will be faster on less technical areas and climbing most of the time. And while those guys are spending money on bleeding hydro brakes and fork overhauls you will be out riding.
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
    Reputation: jimbowho's Avatar
    Dec 2009
    Your way ahead of the game IMO. Cool factor, rock solid, Wishbone stay with brakes up there also. Fork-nice. Keep the period correct pump. Remove all the brittle plastic stuff, & goofy brackets, get V-brakes, maybe a stem that fits you perfect, try to go clipless. Then rock that old mule with envy.
    I understand I may get lip for the V-brakes.
    Quote Originally Posted by sandmangts View Post
    Quote Originally Posted by jimbowho View Post
    Thanks sandmangts and jimbowho. This site has kept me reading past my usual sleep schedule. Learning correct riding techniques and the "anatomy and physiology" of the mountain bike. Those videos in the beginner section has me rewinding and pausing - studying the proper riding positions. LOL. The riding aspect (the different terrains) of it has hooked me definitely and the comments from this thread has got me to just enjoy the ride.
    2010 Cannondale F5
    That's a very cool bike! Don't worry about what anyone has to say, you're going to develop skills far beyond what you would learn on a new FS bike. One thing, If you begin to experience numbness in your wrists or hands you may want to level or even tilt that seat back a bit. Proper fit is very important. Enjoy your bike!
    Mar 2011
    he I worked at one of the largest Mongoose only dealers in New England in the early 90's
    NO OTHER BIKE had the components that the Mongoose line had at the same pricepoint
    those forks you have are point and shoot rock solid
    I second on the v brakes - remove the excess stuff (reflectors)
    My kids have a great line
    "worry about trying to keep up with the 40+ yr old guy on the 20+ yr old bike"
    this came after a Boy Scout single track ride when I got snickers from some of the full sup guys for riding a Yo' Eddy with a BOI
    BTW my 12Yr old twins each have a Yo Eddy put away for them
    Dec 2009
    Quote Originally Posted by yaga View Post
    YAGA, Your welcome! And thanks back, I'm going to check out Towsley. 2nd week of Nov I'm going right bye there on the way back from the valley. The Hiker people mentioned oil slicks on that trail WT-hell? Does the trail stay open at night???
    International bike of champions, Jeepers that's a keeper.
    TrinityRiverKerplunk
    Well put!
    Good friction shifting is getting hard to find nowadays....
    Visitor
    Reputation: hairstream's Avatar
    start putting together a m732/735 group. maybe a t-bone stem. and you are in!
    horn doggie
    Reputation: scooderdude's Avatar
    Sep 2004
    Those are good handling bikes. What I found most interesting is that the seat stays are actually fork legs. Check 'em out!
    Wanted:
    Potts, Potts, Potts
    Schipperkes are cool.
    Reputation: banks's Avatar
    YES! I built many of them working at Exeter Cycles!
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Titanium junkie
    Reputation: Loudviking's Avatar
    Oct 2011
    I miss the simple elements of bikes back then.
    Yes, times they are changing.
    defender of bad taste
    Nov 2007
    I like most steel IBOCs and that is a cool looking one, love that fork. A period correct, mounted level seat would really compliment the bike (IMHO).
    I'd ditch the reflectors and get a helpful wrench at your LBS to remove that redundant piece of clear plastic from your rear wheel.
    Thanks for posting.
    5 is the old new black; 6 is the new new black...
    Mar 2006
    Quote Originally Posted by mechagouki View Post
    get a helpful wrench at your LBS to remove that redundant piece of clear plastic from your rear wheel..
    Or get some dikes and take the pie plate out in pieces while drinking a beer. I third the v-brakes recommendation, they just work better for longer with less trouble.
    Mountain bikers, hikers and horseback riders are not the enemy. Bulldozers are the enemy.
    US Army Vet-Airborne 11B
    Reputation: longhaultrucker's Avatar
    My LBS here in the new town had one of these in the shop for sale last week (might still be there),dirt cheap. Said a dude just left it (needing a front wheel and cables) and a mid '90s Diamond Back (frame/fork only) in the parking lot for trash/donation. Both are CHEAP and have been made ridable buy a skilled mech-dude,and did I mention are CHEAP (he said "no one wants em,they're not new..."). MAN do I wish I had the dogh to buy one of em!
    Nice score,Brother,and welcome back to riding. Sweet looking piece of history I'd love to own and roll down the trail
    '11 Origin 8 700CX
    '14 Surly Troll
    Mar 2011
    I have one that I need to put some tires on it. Reading this post is motivating me to get it done.
    Not sure of the year on mine. I can't post pictures yet. But will soon.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    We sold tons of them in Texas. Solid trail bike and many were raced too. My first race MTB was an earlier version with a U-brake.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    Former Bike Wrench
    My first real mountain bike was a IBOC Comp from the early 90"s (purchased in 1992 but was a closeout model). I rode the crap out of that bike.
    Apr 2005
    Hi! I too have an '89 IBOC, mine is the "team" model, Tange Prestige frame I built up recently with later '91 XT and DX kit.
    There's some history here although no catalogue scan of your bike. MOMBAT: Mongoose History
    Reputation: rudymexico's Avatar
    Aug 2010
    looks really good
    Offer the pie plate to the gods by fire and you will be granted years of gnarly singletrack.
    S.I.M.B.S
    S.I.M.B.S
    The only bad thing about going to V brakes would be changing the brake levers. That IBOC probably has shifters built into the brake lever base, which will make it difficult to do. You can't simply install V brakes on a bike with cantilevers, the levers have the wrong leverage/cable pull to make them work correctly. It could end up having less stopping power, despite the intent. A nice set of Koolstop brake shoes might be the best option.
    gobsmacked Moderator
    I hope he's figured it out since October of 2011.
    Me too. Just thought I would say "something" since no one else seemed to remember Cantilever brake levers and V brakes don't get along very well. I found an IBOC on ebay, and came across this thread searching them.
  1. Mongoose IBOC Comp ID
    By soundz in forum Vintage, Retro, Classic
    Last Post: 10-21-2011, 01:14 PM
  2. Mongoose IBOC Comp ID
    By soundz in forum Mongoose-Schwinn
    Last Post: 04-27-2011, 08:35 PM
  3. Help ID my Mongoose IBOC Comp
    By dt400rider in forum Vintage, Retro, Classic
    Last Post: 04-01-2011, 12:55 PM
  4. Help aging Mongoose IBOC Comp
    By richierich66 in forum Vintage, Retro, Classic
    Last Post: 11-22-2009, 03:06 AM
  5. 1993 Mongoose IBOC Comp
    By TweedleDee in forum Vintage, Retro, Classic
    Last Post: 01-26-2007, 09:38 AM
