Results 1 to 7 of 7
Thread: 1" x fatter.
    1" x fatter.
    Anyone have a clue if any 1" threaded forks (not suspension)
    Can accommodate a 2.6 to 3" tire? I could care less if it's time period correct. Rather just ride it. (26" early 90's m950 build, frame is probably designed around 80mm fork. Or was it 60mm back then?
    Sometimes Rickety, not a turd
    Dec 2015
    You maybe could try a PACE RC30: GoatSurfer Retro MTB - Pace Forks Timeline
    It might work with 2.6" unlikely with any fatter tire... The mid 90s frames where usually designed around 60mm suspension forks... You may look into the custom forks option as well
    What kind of rims you're planning to use?
    Cheers
    artistic...
    Reputation: colker1's Avatar
    Is this for an old frame? Some, few, could acommodate a 2.3 tire in the back. IME there is no old steel fork that would acomodate a 2.6 tire. Any way.. just ask a custom builder the fork you want. Who cares if it´s 60 or 80? The big tire will tell the builder which A-C it needs. And you need disc brakes: v brakes won´t let that huge tire pass thru.
    Just build a whole new frame was it me.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    1” Doesn’t need to be threaded, don’t know why I typed that. Also, have this frame hanging in the rafters so 1 -1/8” could fit the bill.
    (1997 Team Issue. Pic is from 2005, group set is scattered around on other project bikes, fork is toast.)1" x fatter.-97.jpg
    2.4” might be more appropriate goal up front.
    Project is just tinkering around to try out a low 20ish lbs, slow speed, and tight bushwhack/hike-a-bike rig.
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    These have to have some solid clearance: https://www.carboncycles.cc/?p=886&
    If the 83mm inner width is correct, you should easily be able to fit a 2.5 - 2.6in tire. You're probably going to want the 42.5cm version which is out of stock right now. But, I think this or a pace if you can find one, would be about perfect.
    Other 1in versions:
    https://www.carboncycles.cc/?s=0&c=82&p=966&tb=001
    V brake compatible:
    https://www.carboncycles.cc/?s=0&c=82&p=789
    https://www.carboncycles.cc/?s=0&c=82&p=887
    You're going to have to deflate the tire before putting the wheel on if you want to keep using rim brakes with anything larger than about 2.25.
    WTB: Med Bontrager Ti Lite, PM Me...
    artistic...
    Quote Originally Posted by Turd View Post
    (1997 Team Issue. Pic is from 2005, group set is scattered around on other project bikes, fork is toast.)Click image for larger version.
    nice bike. Good steel tubes there.
    Thanks for the suggestions all.
    Opened my mind to look around at the new stuff available.
    Originally focused on what bikes might have had a fork that could accommodate and was thinking donors because 90’s bikes are aplenty and cheap regionally.
  1. Fatbike future; why not fatter 29" tires
    By dosboy in forum Fat bikes
    Last Post: 01-29-2015, 01:10 AM
  2. Sandman gets fatter
    By Andy FitzGibbon in forum Fat bikes
    Last Post: 02-28-2012, 12:35 PM
  3. Fatter Hutchinson Python equivalent
    By Henzel in forum Wheels and Tires
    Last Post: 07-14-2011, 09:16 AM
  4. Why is my Tallboy fatter than most????
    By dapozer in forum Santa Cruz
    Last Post: 05-20-2011, 11:55 AM
  5. Replies: 6
    Last Post: 05-08-2011, 03:29 PM
Members who have read this thread: 46
