Page 1 of 2 12 LastLast
Results 1 to 100 of 163
    Reputation: Krunk_Kracker's Avatar
    Dec 2012
    Turn your Contour Roam into a Contour Roam 2.
    Picked up one of the Contour Roams on Amazon (the watersports kit version) and I've liked it so far, but I wanted better, so I modded the stock firmware to record 720p @ 60fps (versus the stock recording of 720p @ 30fps).
    Messing around, and comparing the differences between the Roam 1 and Roam 2, I came across someone who figured out that the stock firmware for the Roam 2 works on the Roam 1!
    Here's a link to it, but I'm also going to copy-pasta it in case Amazon removes it. Contour Roam 2 FW on Roam 1
    I haven't yet done it, but I am doing so right when I get home. The problem with modding the stock Roam 1 firmware is that you have to use a really old firmware, without all the mic improvements and such.
    It seems the Roam 1 and 2 are either the same camera, or extremely close. I think the Roam 2 uses a better lens, but that might be all that's different.
    I'll be doing this tonight, so if anyone is nervous about trying it, I'll report back my results.
    Here's the post, in case Amazon removes it:
    Hey friends,
    I found a way to install the Roam2 Firmware to the Roam1. Now you have all Roam2 features on the old Roam1
    This is how it works:
    Go to the contour homepage and download the current Contour2 Firmware V2.16
    Download Firmware V2.16 -> you get the file "ContourRoam2.bin"
    Rename the file to "ContourRoam.bin"
    Plug the ContourROAM1 camera into your computer using a USB cable. Check to see that the Record slider is not in the forward (or ON) position. Once connected, the Battery LED on the ContourROAM1 will turn red and the camera will appear as an external USB device on your computer.
    On your computer, navigate to the camera which is mounted as an external storage device.
    Copy the ContourROAM.bin file that you downloaded and renamed in Step 2 to the camera's microSD card. Do not put it in any subfolders on the camera's microSD card.
    On the microSD card of the camera will be a file called FW_RTC.txt. The file may be hidden and you may need to enable the ability to view hidden files in your computer's settings. Open the FW_RTC.txt file with a text editor application.
    Near the top of the file is a line of text that reads `UPDATE_FW:N'. Change the `N' to a `Y' so it appears as `UPDATE_FW:Y' and save the file. This will instruct your camera to update the firmware when it next starts up.
    Unplug the camera from your computer.
    Press and release the Status Button. The camera will beep and the Memory and Battery LEDs will flash while the update is in progress. When the update is completed the camera will beep again and turn off.
    That's it, now you have all Roam2 functions on your Roam1 including 720p with 60 FPS.
    If you want, open the StoryTeller App on your PC and check if a Contour Roam2 will be recognized under "Devices".
    Check some vids under youtube, username "budschidau". Have fun!
    2014 Scott Scale 740
    Dec 2012
    Hey, it works.
    Super simple, the only thing different than manually upgrading the normal firmware, was renaming the ContourRoam2.bin to ContourRoam.bin.
    No reason not to do this
    :EDIT:
    Noticed it no longer records in the ridiculous Quicktime format, and now records in mp4.
    Also has new Lighting options
    Reputation: skiahh's Avatar
    Have you made any videos with the new settings?
    When you replayed them and/or edited them, are they really in 60fps?
    Sounds too good to be true and when something is....
    (But I've downloaded the bin file just in case!)
    Dec 2012
    Yes and yes.
    Everything seems to be working.
    Verified 60fps in Sony Vegas and you can tell from looking at it, it gives a much cleaner and crisper look.
    I'm a member of the club that maintains the local trails, so I'm making "tour" videos for anyone interested in seeing our trails, and here's one I made with the Contour ROAM2 firmware. It was heavily overcast, so I set it to "overcast" in the settings.
    Sent from my XT912 using Tapatalk 4 Beta
    Is there a direct link to download the Roam2 firmware Bin file?
    Dec 2012
    Quote Originally Posted by Dictatorsaurus View Post
    CONTOUR | Firmware - ContourROAM2 (v2.16)
    Didn't work for me.
    I'm coming from ContourRoam Firmware V1.11. When I installed the ContourRoam2 firmware, when I move the record slider, the camera keeps beeping and does not record. Can you guys please share the original ContourRoam FW_RTC.txt file?
    Reputation: Oakeshott's Avatar
    Oct 2012
    According to this article, the mod only works for version 1.01.
    How to Mod a Contour Roam to 60Fps - wikiHow
    Dec 2012
    Re: Turn your Contour Roam into a Contour Roam 2.
    Didn't work for me.
    I certainly can, but it'll be tomorrow, I'm not home tonight.
    If you press the reset button, that'll get you back up and running.
    If you want to try again, downgrade to the ROAM1 1.01 firmware, and then try again. Maybe they locked it with the newer firmware. I was on 1.01 with the 60fps mode when I went to the ROAM2 firmware.
    Quote Originally Posted by Oakeshott View Post
    I'm not talking about the mod, I'm talking about loading the firmware for the ROAM2 on the ROAM1.
    I promise you both it works, and all the additional features seem to work fine as well. It seems the only difference between the ROAM1 and 2 is the 2 has a slide lock for the record slide and has a better mic.
    Well I'll be... that was easy. I upgraded directly from the v1.11 ROAM software and now have all the options for the ROAM2 (which is what Storyteller recognizes the cam as now). I guess that means I have to do some test vids to optimize the settings. Anyone know what they were for the ROAM? Mine worked pretty darn well in most light conditions before this, so I'll start with the defaults and go from there.
    Nope, not true at all. As I said, I went from v1.11 to ROAM2 v2.16 directly. Piece of cake.
    But be careful now on long rides. 60fps uses 1gb for every 7 minutes of video vs 1gb every 15 mins with 30 fps.
    And what the hell is with the stretched out page width??
    Dec 2012
    Quote Originally Posted by skiahh View Post
    Glad it worked!
    Stretched out page width?
    Sent from my Nexus 7 using Tapatalk HD
    Jun 2013
    This has stuffed my camera up bad. I've come from the v1.11 update and all my camera does now if I press the record or status button is have the SD card LED flash red and do nothing.
    I urgently need the camera for Monday and have tried everything to get it working again to no avail, anybody any ideas? Could somebody please upload the original FW_RTC.txt file? I'm hoping this will allow it to accept the previous firmware again.
    Dec 2012
    Quote Originally Posted by KonaCC View Post
    Format the SD card.
    Jun 2013
    Funny enough I did that just after I posted! Success. Thought I'd already tried it before, but hadn't waited for the yellow SD card light to appear.
    Now works and the settings look great, thanks.
    NB: To anyone else having the same problem, you must format the card using the camera (small pinhole button under the SD card slot), it won't work it you format it on your computer. Hold it down for around 10 seconds until the yellow SD led appears.
    Dec 2012
    Awesome!
    Glad you got it figured out :-)
    Jun 2013
    Hi all,
    I came across this thread the other day and just registered so I could share my experiences so far.
    I have two Contour ROAMs which I just purchased this week (good price on Amazon), so I decided to test out this firmware upgrade. I loaded the ROAM2 firmware on one of them and ran a few quick comparison tests.
    Holding both cameras in the same hand, I just walked around my back yard for a few minutes and then into the house. For the ROAM1 firmware, I left it on ContourHD (720p/30). For the ROAM2, I did the following in my 3 tests:
    • ActionHD (720p/60), Center Metering
    • ActionHD (720p/60), Average Metering
    • ContourHD (720p/30), Center Metering
    Sound levels were set the same in both (mic sensitivity 34).
    My observations so far:
    • ActionHD is indeed 60fps
    • The ROAM2 firmware does significantly worse indoors. After walking inside the house, everything was much darker compared to the ROAM1. This was true across all 3 tests (I was hoping that changing those settings might alleviate the problem, but no).
    • Background noise is filtered out much more on the ROAM2 firmware. I didn't get enough sound in my tests to really say whether both picked up "desired" sounds equally well.
    • ActionHD (60fps) on the ROAM2 was about 11.9 mbit/s, or about 11.5 minutes per gigabyte - better than the advertised 7 min/gb.
    • ContourHD (30fps) on the ROAM1 was 10.8 mbit/sec, or about 12.6 min/gb.
    • ContourHD (30fps) on the ROAM2 firmware was about 9.9 mbit/sec (13.8 min/gb).
    • The ROAM2 firmware consistently started recording about 1/2 to 1 second faster than ROAM1.
    I haven't had a chance to test and compare 1080p modes, but I would expect similar results to what I saw in the two ContourHD modes.
    If it weren't for the indoor / low light performance issue with the ROAM2 firmware, I would definitely go with it for everything. As it is, though, I'm torn. I haven't had a chance to take these cameras out on any rides yet (that's next) so I don't know if the low light performance will even be an issue outdoors (shadows etc) or if there will be plenty of light as long as I'm recording in the day time.
    I could also try adjusting other lighting settings on ROAM2 (particularly bumping up exposure), but I assume that would wash out any bright light recordings. I will try to report back with any other findings.
    Thanks to whoever it was that originally discovered this trick.
    Dec 2012
    Quote Originally Posted by bankshot View Post
    Hi all,
    Awesome input!
    Did you notice the lighting settings under the ROAM2 firmware? There's an indoor setting. Did you give that a try?
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Worked like a champ- upgraded my ROAM with 1.11 firmware on it (that I bought from Amazon a couple years ago for ~$75!).
    I'm going to try some actionHD today on the trails and see what happens.
    Thanks for posting all the excellent info!!!
    Reputation: shiggy's Avatar
    Dec 1998
    Didn't work for me.
    You need to reformat the SD card. Then it works fine. Had to do this with both of my Roams.
    mtbtires.com
    psycho cyclo addict
    One thing I've found running 720p/60 fps "Action HD" mode: let the camera run a few seconds longer (than you typically would with the Roam v1 firmware) before turning it off. A couple of awesome videos ended up a bit too brief :/
    Dec 1998
    Quote Originally Posted by edubfromktown View Post
    I have not noticed that, but I tend to let the cameras run a bit long in the first place.
    My Roam2 does seem to take longer to start recording than my Roam1s (with the R2 firmware).
    mtbtires.com
    Jul 2013
    It works astonishingly well. So far I can tell that the following ROAM 2 features work on the ROAM:
    • Contrast
    • Sharpness
    • LED On/Off - ALL LEDs
    • Laser On/Off
    • White Balance
    • 720P 60 FPS - Photoshop shows different images each frame
    Exposure values seem like they work but it is very very subtle.
    Auto exposure metering selections may appear to work as well. Amazing what a camera can do with proper firmware.
    Mar 2012
    THANK YOU so much for posting this.
    Works flawlessly!
    Thanks for posting this, was getting ready to order a Roam2, but I'll go the cheaper Roam1 after seeing this.
    Are they all the same camera, just different kits? On Amazon there are different descriptions and prices. Ironically this one is cheaper and from what I can tell comes with the waterproof case.
    Amazon.com: ContourROAM Waterproof HD 1080P Hands-free HD Camcorder Watersport Kit: Camera & Photo
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Dec 1998
    Quote Originally Posted by TwoTone View Post
    There are detail changes between the 1 and 2. Most noticeable being a lock for the on-off slider on the 2. Useful if you just toss the camera in your pack between uses. The 1 is easy to accidentally turn on.
    No need for the waterproof kit unless you use it in the water.
    Also looks like the water sports kit includes only the surfboard mount
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Thanks Shiggy, when I was asking about a difference I meant the original Roam, since Amazon has different descriptions for the different prices I just wanted to make sure all the Roam1 cameras are the same, it's just the accessory packs that are different.
    I thought the case might be nice to keep crap from scratching the lense. How have yours held up?
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Jul 2013
    The price of the waterproof ROAM kit has gone up 20 dollars since I bought mine a couple months ago. Apparently it's quite popular still. I could have gotten one with a bunch of mounts for that price.
    Relevant stuff below
    That thing on the front of the ROAM is actually a lens protector so it's okay for it to be scratched.
    A new lens protector is 5 dollars from Contour's website while that waterproof enclosure is 40. I'd go for the regular version with useful mounts unless you're specifically going snorkeling or diving.
    Slightly related, a lens cover is also 5 dollars.
    Dec 1998
    The differences are the accessories.
    The stock lens cover does not get scratched, and it is replaceable. I carry a microfiber cloth to wipe the lens on the trail: dust, rain, mud--no problem. There is a rubber lens cap for transport protection.
    The profile and rotating flat mounts are good for a helmet, but is use the Flex mount and Rollbar mount much more.
    mtbtires.com
    Thanks all I ordered the last one at $139 with the normal mounts, went ahead and bought the Bike mount kit for $59 since the flex mount alone was $27
    Should have put more thought into before I hit the button. Since I ended up ordering the bike mount kit anyway, I should have bought the cheaper one with the waterproof case, that way I'd have it, spent a little less and still had all the bike mounts.
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Jul 2013
    Can someone explain how I can do this on a MAC or is it the same directions
    Dec 1998
    Quote Originally Posted by esteroali View Post
    No difference. I use a Mac.
    mtbtires.com
    Thanks to everyone in this thread. Got my camera and mount kit today. The update to Roam2 firmware went flawlessly. So it saved me a bit of cash. Can't wait to try it out on my next ride.
    Question for you all. Which mode do you use 1080p @ 30fps or the 720p @ 60 fps? Wondering if the higher quality makes up for the slower frame rate as long as you don't want to do slow mo effects.
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Dec 1998
    Be sure to reformat the card.
    I have noticed better quality image at 60fps vs 30fps @ 720. Have not tried 1080
    mtbtires.com
    And it seems the sound is better, too. I haven't messed with the mic sensitivity, so the "factory" setting is more sensitive than the ROAM 1's.
    Jul 2013
    New member and I found this how to after purchasing the Roam. I got the ROAM within the past two weeks. I did all of the steps and after I hit the "Status" button my camera completely and totally died. It doesn't turn on at all, it doesn't show up on my computer when plugged in, I can't format the SD Card to return to the original settings. Any suggestions? Do you think Contour caught on to this and this is the solution?
    Jul 2013
    As a quick follow-up, the only thing that seems to get any response out of the camera is hitting the reset button which makes the battery light flash red? Any ideas? I'm not really trying to shell out another $100 for another camera.
    Jul 2013
    I just did mine tonight and works fine
    Jul 2013
    Well, then I guess that's not the issue. I did everything step-by-step and formatted the card prior to the whole process. Now, the camera is completely dead(I don't know that it was fully charged before but it shouldn't have been very low either). Like I said, the only response I can get out of it is the battery light lights up red when I hit the "Reset" button but that is only while it is plugged in. I'm going to let it charge overnight and see if that does anything but I'm concerned as it died right after the update(the blinking yellow). I'm wondering if any more tech-savvy people have any idea what is wrong.
    Jul 2013
    Additionally, the biggest complaint I've read about Contour is how awful their customer service is.... so, I'm not looking forward to that.
    Did you reformat the card after the update?
    Not reset, but reformat.
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Jul 2013
    Nothing happens at all when I hit the format button either. Even with the card out, the camera is completely dead.
    Jan 2013
    okay, i ordered one from amazon... will be here today.
    can't wait to try this!
    joel
    Quote Originally Posted by Cadent3 View Post
    Try fully charging the camera before you do anything else.
    Put the card (in an adapter, most likely) in your computer and copy the FW_RTC.txt to your desktop (or wherever you want it), then format it (FAT or FAT32) then put the two files back on the card (FW_RTC.txt and the firmware file) and try and restart the camera. Then reformat using the "FORMAT" button (NOT the "RESET" button!!!) and it should work fine.
    Jul 2013
    I'll try that when I get back from work, but even out of the box the camera would turn on without a card in it. It literally does nothing at all after I charged it overnight.
    Dec 1998
    Did you read this?
    http://help.contour.com/customer/por...ge-or-power-on
    You have to press the reset button for a loooong time.
    mtbtires.com
    Jul 2013
    No luck yet, the card comes up in a Card Reader just fine with all of the info on it, it just seems to be the camera itself. It's possible that it is completely dead if the charging cord is bad because I haven't had it all that long so I may have used up that initial charge by now. I will try to find another cord and go from there, but this isn't looking good.
    Jul 2013
    However, it definitely seemed to be charging in the past and now it does not charge at all when plugged in nothing lights up. I think it's screwed, not sure if it had anything to do with this update, but it was blinking yellow(after updating and pressing status button) and then it just died completely. I guess I'm gonna have to give their customer service a try and any replacement will take forever as I got it off of Amazon.
    Jul 2013
    I can now attest that their customer service is not great. All tech support is done on a call back basis so you have to leave a message and they will get back to you "in the order that your call is received." Fantastic.
    Jan 2013
    i would simply return it to amazon and order a new one.
    when returning to amazon tell them DOA or whatever and you can print the return shipping info out and drop off at a UPS or whatever you choose.
    then get back online and order a replacement for yourself.
    i just picked up my contour and will charge it before trying the update.
    the packaging pretty cool - lol.
    i got the contour roam waterproof for $129 from amazon.
    i didn't know it came with the water proof case!!!
    joel
    Dec 1998
    Replace through Amazon.
    mtbtires.com
    Jan 2013
    Quote Originally Posted by JAvendan View Post
    joel
    i charged my camera using a wall outlet... took a bit of time.
    i had already inserted the 32gb micro sd card into the slot, read and reread the directions about formatting the media.
    after the green light lit up i grabbed the camera and connected to my mac... mac os x 10.8.4.
    i had downloaded the firmware and copied it to the micro sd card and modified the file to tell the camera to update its firmware.
    dismounted the camera from the mac and started it... it did its thing and after a few seconds the firmware updated!!!
    i messed with it a bit.
    i learned that rotating the lens thingy changes the orientation of the lens - ha ha.
    also, the low light performance is not that great indoors.
    i will test tomorrow outside leaving the white balance to auto.
    thank you for this thread!!!!
    joel
    Jul 2013
    So what's everyone's opinion on doing the roam2 firmware upgrade vs not doing it? I'm expecting mine to show up today. I will be mounting it on my archery bow for hunting whitetail deer among many other uses depending on its performance. So low light needs to be filmable. Just wondering was it real worth the risk. Thanks guys. Great info here
    Jul 2013
    Also does anyone know if u can plug the camera into a phone and view the videos? I looked a little on the android market and didn't find anything yet but that would be awesome. Or even if u could just upload them to the phone through USB and then view them. Thanks again
    Jul 2013
    Seemed to work fine for everyone but myself. I'm going to try a couple more troubleshooting options, maybe wait for their tech support to call me back, and then most likely end up replacing through Amazon. I already used a helmet mount so hopefully that won't be an issue.
    You could always order new one first then stick the new helmet mount in there.
    OG Ripley v2
    Mojo 3- For Sale
    Carver 420 TI
    Jan 2013
    Quote Originally Posted by bowhunt2005 View Post
    I don't know about plugging directly into a phone.
    But the low performance inside my house just walking around was not very good using my house lights.
    The camera was set for Auto.
    Also, I am running with low watt bulbs for energy conservation
    I just tested outside using a bike mount... Camera was still set to auto.
    Looks great!!!!
    I really was surprised with the quality for what I paid. I had a $50 Amazon gift card and $25 'credit' via my Amazon credit card - winnah winnah chicken dinnah
    Good luck w bow hunting and I'm sure you'll be testing before you go out.
    Joel
    2013 Trek Fuel EX 7
    IMBA Member
    Jul 2013
    So basically its worth a try? And if the results r less than expected, I can just hold the reset button and it will go back to the original firmware?
    Jan 2013
    I would say it is worth it.
    Unfortunately, I don't know that hitting the reset button will bring you back to the original firmware... I'd rather not test
    Maybe someone has tried???
    Joel
    2013 Trek Fuel EX 7
    IMBA Member
    Jul 2013
    Mine arrived yesterday and I just installed the Roam2 firmware right off the bat. Records fine at 60 fps. Don't have anything to compare it to. Agree low light not so good but had it out on the boat today and in bright conditions looks great! Had it in the waterproof housing which it came with ( surprised!) on the Amazon deal for 129...
    Beats the go pro at 300 bux!
    Dec 1998
    The lighting setting can be changed.
    Experiment. They make a difference on the trail, too.
    Note that full HD-1080p 30fps mode uses a 125 degree field of view while action HD-720p 60fps uses 170 degrees
    mtbtires.com
    Jul 2013
    Can the cameras audio "beep" noise still be turned completely off with the newer firmware too? Very important while hunting.
    Jan 2013
    good to know... i will see about changing the settings.
    i think i will leave the camera at 760p 60fps.
    just looks gorgeous!
    i agree about the price compared to the gopro, too.
    the best deal out there... FTW!!!!
    joel
    2013 Trek Fuel EX 7
    IMBA Member
    Dec 1998
    Yes
    mtbtires.com
    The light settings can be changed. But it's still a camera designed for daylight videography, so it will have some limitations as you might expect.
    Here is a night video I shot with mine. It's 720p/30fps and I used manual settings of Lighting: 60, Sharpness: 3, Exposure +1.
    The first and last parts were in a park (Garden of the Gods) with no external streetlights, so the only illumination was from other riders and my Niterider Rage (HID helmet light). You can see it mounted below and in front of the camera in some parts of the video. The sections lighted by streetlights came out pretty darn good, however, for what this camera is.
    <iframe width="640" height="360" src="//www.youtube.com/embed/FYAqdFg-Cio" frameborder="0" allowfullscreen></iframe>
    Dec 1998
    Those are the same as the preset "dusk" setting. You can run the expose up to +4. Not a big difference, but a difference.
    This is raw video. Night ride on an open hillside. Camera on the headtube. Default setting, 30fps. LED lights on bar and helmet.
    <iframe frameborder="0" scrolling="no" width="425" height="240" src="http://api.smugmug.com/services/embed/2569436152_xSRSFxb?width=425&height=240"></iframe>
    mtbtires.com
    That's pretty good. On my road bike I don't have a ready mount. Down on the headtube, I suspect it would have picked up a bit more. Did you have that one run up to +4 exposure?
  67. #67
    Dec 1998
    Used the same settings as daylight. Will change them for another night ride. But that is pretty much how it looks while riding.
    mtbtires.com
  68. #68
    Sep 2004
    Ordered the Roam yesterday from Amazon and it was here today! I have already done the update and it seems to be working. I have made over 100 MTB vids with the Contour HD and love the 60fps. But I"m looking forward to the Roam with the auto power on, the waterproof and hopefully more dust proof.
    Also, my experience with Contour has been great. They have replaced the HD 2x's each time in under a week, paid for shipping and replaced rather than repaired. And the cameras had been used very hard and I'm impressed with the camera and with the warranty, but can't speak to phone support beyond replacement. I can't wait to take the camera out tomorrow for the lunch ride.
  69. #69
    Jan 2013
    well, i found this...
    iPad mini usb camera adapter -contour roam camera - YouTube
    not a phone and not android based.
    but i think it will show some possibilities
    joel
  70. #70
    Dec 1998
    joel
    You can use the USB adaptors to download video and view it on the iPad. Can not change camera settings or view the video directly from the camera.
    mtbtires.com
  71. #71
    Dec 1998
    Quote Originally Posted by K2D2 View Post
    The Roam is vastly better than the HD. My HD videos are fuzzy around the edges. The Roam is sharp in the whole frame. Longer battery life, too.
    I do wish the Roam had the 2 mode switch of the HD.
    mtbtires.com
  72. #72
    Sep 2004
    First effort with my new Roam and trying out my new ramp!
    I ordered the Roam on Monday from Amazon Prime, got it on Tuesday and was able to go for a ride at lunch yesterday and edit some video last night of me hitting my new practice ramp on my E29 and my usual lunch loop. Here's the video.
  73. #73
    Jan 2013
    that's awesome!!!
    if i rode at lunch it would be on the streets
    also, i bought the contour bike mounts and that's a very cool set.
    i love the extra long strap and the helmet mount is awesome.
    i can't wait to play around some more!!!
    joel
  74. #74
    Sep 2004
    Thanks, just re-read this and have noticed that too and I'll let it go a little longer.
  75. #75
    Jan 2013
    i recorded my ride with my roam with the roam2 firmware...
    the ride was about 1 hour 15 minutes.
    i noticed that the video was split over 2 files.
    the first one being about 45 minutes or so.
    is this typical?
    thank you,
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  76. #76
    Dec 1998
    is this typical?
    thank you,
    joel
    Yes.
    From experience, turning the camera on and off several times during the ride makes it MUCH easier to view and edit later.
    mtbtires.com
  77. #77
    Jan 2013
    Yes.
    Thank you for the reply.
    Yes, I think that would be easier to have smaller clips to import.
    45 minutes of 720@60 takes a while to import!!!
    Joel
    Sent from my iPhone using Tapatalk 2
    2013 Trek Fuel EX 7
    IMBA Member
  78. #78
    is this typical?
    thank you,
    joel
    That's interesting. I looked back through my clips and I have several that are over 45 minutes. But no files over 4GB.
    Maybe it's a file size limitation?
    [Update]Found the answer on the Contour site:
    Quote Originally Posted by Contour Support
    Thank you for contacting Contour support. With regards to your video files splitting, thiis occurs because our camera records in FAT32, and the inherent file size limitation of FAT32 is 4GB. So that no video is lost when a new file is created, the camera creates a new file once the video reaches around 3.8GB. These videos can be joined together with 3rd party software later, but unfortunately due to the FAT32 file size limitation, videos on the camera must be split up once they reach this size. If youíre looking to join clips, I might recommend using a free program called MPEG Streamclip, which can be found here: Squared 5 - MPEG Streamclip video converter for Mac and Windows. Thanks again for asking, Stephen, and please let us know if there is anything else we can do for you.
  79. #79
    Jan 2013
    ah!
    makes sense... now
    thank you for that.
    i will actually stop recording intermittently to create smaller files.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  80. #80
    Jan 2013
    well folks,
    during my first ride with my roam i knocked it with my knee and it popped out of the strap mount over the frame of my bike.
    camera survived but the protective lens cover took a few dings as did the rotating bezel.
    luckily, again, the camera was good and the dings in thee lens cover do not interfere with the video.
    the bezel rotates with no problems.
    BUT, it is a little ugly to look at - ha ha.
    i looked online and found the replacement lens protectors and even found a company that USED to sell kits with included lens protectors, o-rings and replacement bezels of different sizes for filters.
    unfortunately, no longer offer that kit - booooooo.
    i emailed contour and the are sending a free bezel - WIN WIN.
    so, right now, contour customer is on my pedestal.
    i hope to update this after i receive my replacement bezel.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  81. #81
    psycho cyclo addict
    New cam owners be careful... I did this not long after getting mine. Too busy messing with camera when I should have been paying full attention to the (very technical and steep) trail. I somehow managed to walk away without sustaining camera, bike or body damage
  82. #82
    Jan 2013
    Oh, no!!!
    I did that earlier this year... When I didn't have a camera
    Glad you're okay!
    Joel
    2013 Trek Fuel EX 7
    IMBA Member
  83. #83
    I don't know... from the angle, that trail looks neither steep, nor very technical. But a great crash!
  84. #84
    psycho cyclo addict
    That was at the bottom of a rocky/twisty DH trail that has sizable gap jumps at the top and lots of ramps along the way down.
    【ツ】 eDub 【ツ】
  85. #85
    Jan 2013
    for those of you that are subscribed to this thread and have not seen this post...
    RIP Contour
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  86. #86
    Aug 2013
    Has anyone found a site that offers alternative lenses for the contour? I want to get rid of the fisheye and could use a standard lens or Night vision if they are available. I realize these mods would most likely be 3rd party but I think it could be done right to upgrade the camera.
  87. #87
    Jan 2013
    Quote Originally Posted by gapjump View Post
    the only thing i have seen is this...
    Amazon.com: Contour 3400 Lens Kit: Camera & Photo
    you replace the ring and can add filters.
    the price seems to have at least doubled from when i last saw it!
    [edit] doesn't appear to thread correctly.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  88. #88
    Aug 2013
    That kit looks useful but it only contains covers and I want a new lens. I did a bit more searching and I found this place called ragecams.com and they have all sorts of camera mods. I found this lens which says it will work form contour and go pro Sony HDR as15 hdr as10 flat lens no fish eye contour plus contour roam contour p | HD Wearable Video Custom Mods By RageCams
    They only have one lens listed for contour but if the threads to this lens match up to a go pro than any of the go pro lenses should match up and work on the contour.
  89. #89
    Jan 2013
    nice. are you going to get it???
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  90. #90
    joel
    Methinks he may actually be selling them.
  91. #91
    Dec 1998
    Do you trust a company that sells the Roam2 for double the list price?
    mtbtires.com
  92. #92
    Reputation: sand wedge's Avatar
    Sep 2012
    After reading this, I ended up ordering the waterproof bundle for $107.77 from Amazon and updated the firmware without any issues. Unfortunately I didn't pay attention and found the waterproof bundle does not come with any helmet mounts, only a surf board mount...
  93. #93
    Aug 2013
    Nah I'm not selling them and I havn't ordered anything yet. I want to try and find a cheaper place to get them from because like someone pointed out they are selling roam 2 for twice the retail price so I could most likely find a lens kit cheaper but so far no results. I'll keep you updated if I find a better price.
  94. #94
    Jan 2013
    Quote Originally Posted by sand wedge View Post
    i bought my second ROAM the waterproof bundle
    before this i bought the bike mount set... or, whatever it's called.
    so, i'm good-to-go!
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  95. #95
    I bought my second ROAM with the surfboard/waterproof kit, too, for $102 at Amazon. I'll use the housing and probably will find a place to use the surfboard/flat surface mount.
    But think of it this way. The housing is about $20 or so and the mount about $15 (both separate retail prices), so you got the camera for about $70 - quite a bargain. Now go buy your preferred bike mount kit and get video-ing! (And you'll still be ahead of the game)
  96. #96
    Flashed my new Roam with Roam2 firmware today.
    Easy easy.
    I did format the card (with the cam) before and after the update.
    Original firmware version was 1.10.
  97. #97
    Jan 2013
    no need to flash the ROAM to get ROAM2 performance... get the ROAM2!!!
    Contour - ROAM2 Action HD Camcorder - Black - 1801K
    $100.
    great price
    joe
    2013 Trek Fuel EX 7
    IMBA Member
  98. #98
    And the dumping begins?
  99. #99
    Dec 1998
    $100.
    great price
    joe
    In store only
    mtbtires.com
  100. #100
    Aug 2013
    I'm in the same boat, did you ever resolve the problem?
    Does anyone have any suggestions?
  1. Contour Roam, Lens Kit?
    By cmg71 in forum Videos and POV Cameras
    Last Post: 03-30-2012, 11:07 AM
  2. $89 Contour Roam Camera Offer
    By o3zone in forum California - Norcal
    Last Post: 01-31-2012, 08:51 AM
  3. Contour Roam and iMovie
    By cowboygrrl in forum Videos and POV Cameras
    Last Post: 12-30-2011, 11:36 PM
  4. How do you like your Contour Roam
    By csermonet in forum Downhill - Freeride
    Last Post: 12-24-2011, 01:34 AM
  5. Contour Roam for 89$ at amazon
    By etal in forum Where are the Best Deals?
    Last Post: 12-22-2011, 08:32 AM
