Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 125 of 163
  1. #101
    Jan 2013
    Quote Originally Posted by rrmiller View Post
    I'm in the same boat, did you ever resolve the problem?
    Does anyone have any suggestions?
    did you two try the reset button near the format button???
    i had second roam lock up on me and i was able to hit the reset button and it worked.
    i was then able to update the firmware to ROAM2 and all is good.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  2. #102
    Reputation: Krunk_Kracker's Avatar
    Dec 2012
    You have to hold the reset button for a very long time, like 10-12 seconds.
    2014 Scott Scale 740
  3. #103
    Aug 2013
    Quote Originally Posted by Krunk_Kracker View Post
    I held the reset button down for 60 seconds, timed, no result.
    What is the "reset button near the format button?" I only have one reset button at the top of the camera.
  4. #104
    Jan 2013
    oh!
    sorry, there is ONLY one reset button.
    i didn't have my camera with me so i just guessed the location
    sorry!
    i copied this from the contour site...
    + RESETTING YOUR CAMERA
    If your camera is locked up or it will not stop recording,
    you can reset the camera.
    - Slide the Record Switch back to the Stop position.
    - Press and release the Reset Button (See ‘G’ on page 1).
    - The camera will shut off all LEDs and power off.
    - Your camera will be ready to operate again.
    also, i didn't have to hold my reset button to long... just a few seconds or so.
    also, make sure the battery is charged.
    if you can't successfully reset the camera can you return it????
    joel
    2013 Trek Fuel EX 7
    IMBA Member
  5. #105
    Aug 2013
    Quote Originally Posted by JAvendan View Post
    joel
    I tried all those things, with no luck. With Contour on shaky ground (out of business?) I'm not optimistic about my chances of returning it.
    Ah well, live and learn I 'spose.
  6. #106
    Sep 2013
    So this actually worked! Thank you so much for the walk through.
    I was given a contour roam for my birthday a year ago and was slightly disappointed that my friends older model could record at 60fps and my newer model couldn't.
    This worked exactly as described. Had a minor panic when I updated the firmware and my camera wouldn't work. But then I formatted the SD card and it worked like a charm!
    Thanks so much for sharing. You've made my day!
  7. #107
    Sep 2013
    Anyone can share their firmware?
    Hi guys, as of today contour's site is officially taken down, together with all the firmware files and Storyteller link.
    I blame my own tardiness for not having downloaded it earlier.
    For those of you who have downloaded and updated roam2 firmware onto their roam, do you still have a copy of it? If yes, would you please share it? Plus if anyone has roam1 firmware and Storyteller installer files i would appreciate it very much to share it with me too so that if roam2 firmware update went wrong i still have the stock firmware to fall back on.
    Thank you in advance!
  8. #108
    Sep 2013
    I need the firmware too!!
  9. #109
    Sep 2013
    I'm in the same boat. I need Roam 1 and 2 firmware and the story teller app install. =( Somebody has to have it, please help us unfortunate souls!
    Steve
  10. #110
    Reputation: skiahh's Avatar
    Send me a PM with your emails. I have both.
    I also have Storyteller, but it's 42MB, so not easily emailed.
    www.teamnavycycling.org
    10 Pivot Mach 429
    09 Felt Nine Race
    03 Litespeed Tuscany
  11. #111
    Sep 2013
    Quote Originally Posted by skiahh View Post
    ˇThank you very much! The true is that I already found the files.
  12. #112
    Sep 2013
    Somebody in amazon recommend me to go to the contour facebook page and there I get a dropbox url to the firmwares.
  13. #113
    Sep 2013
    Quote Originally Posted by RobertoEnrique View Post
    Oh that's beautiful, thanks!! I found the link and was able to grab everything. Thanks so much. And thank you skiahh for offering to email everything!
    I'm leaving the drop box link here since this is one of top 5 hits on google for contour firmware:
    https://www.dropbox.com/sh/qlr5xtb36uxj7jj/wpX5nY3kU-
    Thanks all,
    Steve
  14. #114
    Dec 2012
    I'll permanently host them on my Drive as well.
    https://drive.google.com/folderview?...Xc&usp=sharing
  15. #115
    MTB is for animals
    Oct 2013
    I have a doubt: if I want to go back and install the ROAM1 firmware again, is that possible ?
    Once I have sent an e-mail to Contour Support, asking about the version 1.01 MOD. They told me: "Thank you for contacting us. With regards to firmware 1.01, while it was true that this firmware version would allow the camera to film in 1.01, this was removed as the hardware in the original Roam is not approved for 60fps, and filming in this resolution can permanently damage the camera. This being the case, we are unable to provide this firmware for the original Roam."
    Until now, nobody had any problems keep filming at 60fps with ROAM2 firmware ?
    Thanks !
  16. #116
    Dec 2012
    Quote Originally Posted by Pikachu_MTB View Post
    Thanks !
    Of course they're going ot say that, why would they say anything different? lol
    I've been using mine since the day I made this thread and it's still fine.
    To go back to the original firmware, just flash the ROAM 1 firmware.
  17. #117
    Reputation: sand wedge's Avatar
    Sep 2012
    Thanks !
    I would expect nothing less than that statement from Contour. My interpertation is that you can brick this if you load the firmware or update it down the road if you don't know what you are doing.
    This thread was the reason I purchased a Roam and it has been working flawless since updating the Roam2 firmware.
    My buddy has a Roam+2 and my modified Roam video quality is every bit as good as his. In fact my Roam's battery life lasted hours longer than his when we were in Whistler because he left the Bluetooth/GPS feature on.
  18. #118
    MTB is for animals
    Oct 2013
    I was thinking the same... But it's good to share information...
    By the way, thank you all for sharing the firmwares !!!!
    Quote Originally Posted by sand wedge View Post
    off-topic: man, don't talk about Whistler... Everytime I see videos of BC trails... when I get back to the real world... I'm drooling... lol
    I'll try to update my ROAM's firmware. I was thinking about to get the Hero 3, but may be I buy another ROAM...
    Thanks !
  19. #119
    Sep 2013
    Many thanks for the links guys. Now i just need to get back home and start downloading.
  20. #120
    MTB is for animals
    Oct 2013
    Just did it. Working fine !
    Tomorrow I'll put it to a field test. Let's see what's gonna happen !
    Thanks guys !!!!
  21. #121
    Reputation: killjoyken's Avatar
    Much thanks to everyone in this thread! You guys rock!
    Ibis Mojo HD3 - Santa Cruz Chameleon - Specialized Roubaix
  22. #122
    Oct 2013
    Date and Time off??? (2.16 firmware)
    Had 1.10 firmware, upgraded directly to 2.16 did reset and works GREAT! Light performance is bad but CUSTOM setting may result better HOWEVER: Guys how to set DATE and TIME on the video to OFF? I couldn't figure this out! PLS HELP!!
  23. #123
    Oct 2013
    oK GUYS ı AM SORRY it was my players date and time.. Shame on me New 2.16 firmware look OK better outdoor performance for sure.. But I would be really pissed of if I had bought contour 2 a year ago around 200 usd and realized this low light performance. BTW ı recommend everyone SJ1000 action cam as well for 80 usd is is amazing. Not Contours build quality but lots of mounts LCD and camera shoots great.. Recommended!
  24. #124
    Sep 2013
    Sj1000 or mobius as recommended by techmoan.
  25. #125
    Oct 2013
    Quote Originally Posted by andrewhtf View Post
    SJ1000 if wants more mounts and lcd screen MOBIUS if weight is important (RCs or spying ) Both are great!
  1. Contour Roam, Lens Kit?
    By cmg71 in forum Videos and POV Cameras
    Last Post: 03-30-2012, 11:07 AM
  2. $89 Contour Roam Camera Offer
    By o3zone in forum California - Norcal
    Last Post: 01-31-2012, 07:51 AM
  3. Contour Roam and iMovie
    By cowboygrrl in forum Videos and POV Cameras
    Last Post: 12-30-2011, 10:36 PM
  4. How do you like your Contour Roam
    By csermonet in forum Downhill - Freeride
    Last Post: 12-24-2011, 12:34 AM
  5. Contour Roam for 89$ at amazon
    By etal in forum Where are the Best Deals?
    Last Post: 12-22-2011, 07:32 AM
