Results 1 to 6 of 6
    Oct 2013
    Motion blurred Video - contour +2
    Hey everybody,
    i own a Contour +2 with the latest firmware.
    Sadly my recordings are often motion blurred. In 1080p as well as in 720p60. Especially in situations with indirect sunlight (biking in forest).
    Do you have any recommendations for the settings or shooting setup to get better results.
    Is it possible to control the shutter speed in any way? Maybe with a hacked firmware.
    Thanx a lot for the support
    greetings
    Pascal
    Rabid Lana fan
    You could try using 30 fps instead of 60 fps. It might help....the camera would have twice as much time to render each frame.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Oct 2013
    Thank you for this tip. I will try it next time. Hopefully the cam will really use the time to render a improved image.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    adjust the light setting to the lighting you'll be riding in.
    60FPS should be fine.. I find it cleaner on mine (older HD 1080 unit)
    set the image quality to high..
    try a faster card.. (probably not the problem but I found a faster card give cleaner image and if nothing else downloads to the computer faster)
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Oct 2013
    Hey, I have a class 10 Card. Should be fast enough!? I will try the different light settings next time. Thanx for your tip.
    Oct 2007
    ya, class 10 is as fast as they go last I knew
  1. Light&Motion Seca 800 vs LuminTrek TB-1000 (video)
    By skurfer333 in forum Lights and Night Riding
    Last Post: 09-30-2013, 01:58 PM
  2. Short Video with a Contour HD Roam2
    By Shakester in forum Videos and POV Cameras
    Last Post: 02-26-2013, 04:57 PM
  3. Contour hd video recorder?
    By mtnbikeking in forum General Discussion
    Last Post: 12-14-2011, 05:17 PM
  4. Contour HD video of Mountains of Mayhem pre-ride
    By sworkspilot in forum Videos and POV Cameras
    Last Post: 02-28-2011, 05:40 PM
  5. Video editor for Contour .mov
    By bushido5 in forum Videos and POV Cameras
    Last Post: 02-19-2011, 01:13 AM
